Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. May 22, 2020 at 4:10 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Any version except 1.05.
    the 2.0s available on flash manager right now are really good
    guys we are 99% there with 2.0 final. Lets get this last bit solved and done. I want it done as much as you guys do.
  2. May 22, 2020 at 4:12 PM
    2017TRDpro
    2017TRDpro Well-Known Member
    2017 TRD Pro
    Are we getting 04B04 treat this holiday weekend?
  3. May 22, 2020 at 4:15 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Seriously, at this point, any 2.0 file. This startup "issue" is not much of an issue other than it's annoying. It's not going to hurt your truck. Pick a file and run it.
    Mat, we're you planning to release 04B14 with everything else for VF right? Should we just go ahead and flash that TSB file that @Saeros posted for us?
    Saeros, SC4333, tonered and 1 other person like this.
  4. May 22, 2020 at 4:29 PM
    Shellshock
    Iowa
    ^ also curious. I’ll update to 04b14 if we are getting the goods for it. Otherwise I’ll stay one 04b13 even though I don’t really want to
    Saeros, tonered and lapoltba[QUOTED] like this.
  5. May 22, 2020 at 5:01 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Tell me more. Is this an issue only when in 2lo, or at all times? I have the mod (mostly for insurance and cool factor) but would like to know.
  6. May 22, 2020 at 5:12 PM
    BigBeej
    BigBeej Well-Known Member
    Bryan
    Vista, Ca
    Hoping to get a straight answer cause I am very confused. I have a 2018 AT 04061 truck and I have the orange dongle ovtune kit. Will there be a final 2.0 tune for my truck without purchasing VF stuff or is 1.05 the last and only tune I will have?
  7. May 22, 2020 at 5:15 PM
    RushT
    North Texas
    Do you have a separate usb stick; either micro black, or larger purple? If not, then you're good to go. If you have a true dongle... a usb key separate from the connection to your truck, then you won't get the final 2.0 until you trade in.
    xxTacocaTxx likes this.
  8. May 22, 2020 at 5:17 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    What's the deal w 14? What makes it desirable
  9. May 22, 2020 at 5:18 PM
    BigBeej
    Bryan
    Vista, Ca
    I have the newer orange one that plugs into the computer with usb cable. Was purchased at christmas last year.
  10. May 22, 2020 at 5:18 PM
    lapoltba
    CT - 06076
    New hotness.
    tonered and Shellshock like this.
  11. May 22, 2020 at 5:29 PM
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    How do you know the startup issue is not doing anything to hurt the truck? Have you determined the cause? I have run every 04B04 and 04B03 from the first release. Never had any of the tunes do this, but the last two betas.
    I have noticed after 200 miles it will do it warm or cold. It takes about 15 minutes or greater sit time and it will do it. It does seem to be getting longer duration (longer rotation without firing) skip as miles have increased.
  12. May 22, 2020 at 5:30 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    There will be a 2.0 final for your 04A61 ECU. You will be able to flash it with the kit you have using Flash Manager.
    BigBeej[QUOTED] likes this.
  13. May 22, 2020 at 5:35 PM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Nope. I have the stumble on both versions of 2.0.
  14. May 22, 2020 at 5:36 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    It's an OEM MT tsb tho right? What's better about it
  15. May 22, 2020 at 5:36 PM
    Shellshock
    Iowa
    If you have an issue with it, flash to a previous tune and wait for a new revision.
  16. May 22, 2020 at 5:41 PM
    Glenn_R
    Glenn
    NO SHIT, I CAN DO THAT? Tired of guys making off handed statements with no factual information behind it. Bottom line is, we don't know what is causing the start issue or what it is doing. I know it clears as soon as I load another tune.
    gumpjr23 likes this.
  17. May 22, 2020 at 5:43 PM
    lapoltba
    CT - 06076
    No one can say for sure except Toyota. According to mat they didn't touch any of the tables, just background code. My bet is it had to do with fuel pump issues or the limp mode some people were getting.
    tonered likes this.
  18. May 22, 2020 at 5:45 PM
    lapoltba
    CT - 06076
    Don't you think Mat has logged all of his tunes for way more hours than reasonable? Don't you think if he believed for one second it was an issue he would have told everyone to flash back to stock or a different tune while he fixes it? This alarmist bullshit is part of the reason 2.0 final has been dragged out so long.
  19. May 22, 2020 at 5:54 PM
    Glenn_R
    Glenn
    nothing alarmist about it. I didn't say it is harming anything. I asked you if you know what is causing it, do you?
    Edit, what truck are you running the at issue tune on?
  20. May 22, 2020 at 5:55 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I don't get why anyone would update then?
Thread Status:
