Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jun 1, 2020 at 7:43 PM
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    it didn’t take long to get there. This truck if fast with this tune!
  2. Jun 1, 2020 at 7:53 PM
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    on latest 04B04 91-5.29-34-37 its a little over 92 MPH and 86 MPH indicated.
  3. Jun 1, 2020 at 8:04 PM
    MacFly
    MacFly Well-Known Member
    2018 Cement Tacoma TRD Off Road AT
    OVTune, AT Habitat, Firestone RRs, ARB CKMA12 compressor
    But why? Is it intentional for some reason? Does re-gearing cause it, or the tune, or both?
  4. Jun 1, 2020 at 8:08 PM
    Glenn_R
    Glenn
    not sure what causes it, but didn't see it until I went to 5.29s and 35s. I have asked @OVTune here if its going to get removed and others have as well, I have not seen an answer.
  5. Jun 1, 2020 at 8:14 PM
    MacFly
    Ok, so it's not an intentional thing for safety of the driver or the truck then? Be interesting to hear if it'll get resolved.
  6. Jun 1, 2020 at 8:39 PM
    Glenn_R
    Glenn
    I think the truck has some kind of speed limiter built in and it shows with the gears and tires. Not sure though. I hope Matt can pull it out.
    houser1995 likes this.
  7. Jun 1, 2020 at 8:58 PM
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    that’s a bummer to hear. I never tested wot while I was on that tune. I’d be curious to hear from someone on the latest 2.0f test tune with 5.29’s and the tire size specific Tunes to see if that rev limiter stumble from 2nd -3rd At WOT is still there.
  8. Jun 1, 2020 at 9:01 PM
    MacFly
    agreed. I don't plan on ever going over 90, but I don't like having an arbitrary rule imposed on me.
    blitzkrieg3002 likes this.
  9. Jun 1, 2020 at 9:32 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    The limiter exists on all trucks, but is "lowered" with gears. The truck thinks you're doing 110mph (or whatever the stock tune limits you to), but with gears you're doing 86mph
  10. Jun 2, 2020 at 4:35 AM
    dwillhere1
    dwillhere1 Well-Known Member
    Dan
    Surprise, AZ
    2017 TRD OFFROAD
    I have 5.29 gears running 295/70-17’s. I’m running the 2.0 base 91 5.29 with 31-33” tire selection. I have the Hypertech speedometer calibrator and max out at 96mph. The truck sounds like it is trying to do more but will not accelerate past 96mph. 2017 TRD off-road 4x4 AT 04B04
  11. Jun 2, 2020 at 5:09 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    with those tall gears, do you guys think, you might just be out of gear, and it wont pull anymore? mechanical limit? food for thought. Ski
  12. Jun 2, 2020 at 7:06 AM
    MacFly
    That's one of the things I wondered, that maybe putting in such different gears might actually be pushing something to it's limit? I wouldn't be surprised if it's programmed in for "safety" though.
  13. Jun 2, 2020 at 7:09 AM
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    any stumble / hitting rev limiter on WOT from a near stop from 2nd to 3rd gear?
  14. Jun 2, 2020 at 7:12 AM
    RustyTacoVT
    RustyTacoVT Well-Known Member
    Higher numbers actually mean shorter gears. Similar to the aperture on a camera, the number is inverse to what would make sense (bigger number is a shorter gear, and bigger number is a smaller aperture). So 5.29 is actually shorter than the stock ratio.
    In this case, if he was running out of gear he would actually be beating the truck against the rev limiter. What he's experiencing is an electronic governor.
  15. Jun 2, 2020 at 7:18 AM
    MacFly
    Makes me wonder why the shops that put in gears don't fix it, unless it's not easy to fix... Hopefully Mat can chime in and tell us whether it's something he can tweak, or if it can be done in vF
  16. Jun 2, 2020 at 7:19 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    I can fix it, it's in the programming. I thought I did last time, a few people confirmed that it was gone, but sounds like it isn't now.
  17. Jun 2, 2020 at 7:24 AM
    MacFly
    Cool, thanks for the clarification.
  18. Jun 2, 2020 at 7:25 AM
    Shellshock
    Iowa
    Because the shops don’t program the ecu
    johntoyota, inksin, rlx02 and 3 others like this.
  19. Jun 2, 2020 at 7:30 AM
    MacFly
    I figured that it wouldn't be their bailiwick, but if I was installing something that then affected another aspect negatively and *possibly* endangered the driver (like if you had to get on the gas to avoid a semi where they're doing 80+), I'd take the time to fix it if I could so the customer had the best experience with my product as possible.
  20. Jun 2, 2020 at 7:35 AM
    KanPanic
    KanPanic Rock Stacker
    State of Jefferson
    2018 OR
    Come on McFly! Traveling at 88mph could result in accidental time travel and altered time lines.
    or
    check this thread...
    SC4333, PhogDog, Abelgonz and 3 others like this.
Thread Status:
