Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Oct 14, 2017 at 6:32 AM
    #6521
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    I wonder why my stock automatic works so well in the mountains. I have made 2 trips to the Blue Ridge and my cruise works flawlessly. Hardly ever drops more than 1 gear generally and mildly upshifts 1 gear after cresting. Am I just that lucky. For 2 years I have read the same issues with dropping to 4 or 3 and hanging up in the lower gears. The only complaint I have is the tendency to find 5 or 6 on a 42 mph flat drive.Performance wise mine runs pretty damn good with a CAI and catback. I do still plan on ordering a 102c or newer in the upcoming weeks.
    Herniator and bshammer0 like this.
  2. Oct 14, 2017 at 7:22 AM
    #6522
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Trust me, I'm right there with you haha. I have to drive 250ish miles later today so I was hoping the new iteration would be available for me to test on that drive!
    MOC221_[QUOTED] likes this.
  3. Oct 14, 2017 at 7:28 AM
    #6523
    Shellshock
    Iowa
    Tracking info finally updated. Scheduled to be delivered on Monday :goingcrazy:
    MESO, MOC221_ and DES2009 like this.
  4. Oct 14, 2017 at 7:31 AM
    #6524
    Livinserene
    Livinserene Thejerkyguy
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    JEALOUS!!! What order number are you?
    MOC221_ likes this.
  5. Oct 14, 2017 at 7:31 AM
    #6525
    Shellshock
    Iowa
    2050
  6. Oct 14, 2017 at 7:54 AM
    #6526
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    It makes the AT drive like an AT should. Want to be in a lower gear? Press down the pedal a bit. Want to do lower? Press a little more. Its still gonna shift, but it's predictable and you at least FEEL in control of it with the throttle giving the orders...
    Deucer01 and DES2009 like this.
  7. Oct 14, 2017 at 8:01 AM
    #6527
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    I’m with the crowd that is waiting for the MT specific tune before I pull the trigger. I really want to see 1:1 throttle response and as much engine braking as possible. More power will just be an additional bonus. I do like to see the reports of emproved fuel economy.
    I tow almost daily and the one thing I really wish these trucks had is more engine braking. It almost feels like the VVTI lets the engine freewheel. @nevadabugle is definitely on point with his statement about the predictable engine braking.When I do pull the trigger on this I will definitely send in towing data logs if it will help Matt in any way.
    MOC221_ and Livinserene like this.
  8. Oct 14, 2017 at 8:11 AM
    #6528
    stevotivo12
    Stephen
    Unfortunately engine braking is largely a function of compression and large cylinders, neither of which the 2016 Tacoma has while coasting. The psuedo-atkinson cycle that the engine runs at low load pillages compression for the sake of using approximately 60-70% of the normal intake charge for efficiency reasons by leaving the intake valve open during part of the compression stroke. There is no way to make up for that but to get rid of the pseudo Atkinson cycle and run full compression during low load since bigger pistons arent an option.
  9. Oct 14, 2017 at 8:18 AM
    #6529
    BallsDeep09
    BallsDeep09 Well-Known Member
    '16 DCSB TRDOR 6 spd.
    same
  10. Oct 14, 2017 at 8:18 AM
    #6530
    RedBeard1
    Red
    These engines are fully capable of building high compression as per the specs. Matt has stated he can fully manipulate the valve timing on them as well. Hopefully he can shut down some of the intake valve duration on the deceleration to give us an improvement in the engine braking. As it seems he was able to do the opposite for the auto transmission crowd.... fingers crossed.
    MOC221_ and stevotivo12[QUOTED] like this.
  11. Oct 14, 2017 at 8:27 AM
    #6531
    stevotivo12
    Stephen
    Wow, I didn't realize that he had that much control.
    It would definitely be nice to be able to crawl down descents with no input required but with the engine braking being as non-existent as it is I'm not exactly holding my breath. Working on my left foot braking technique seems like a better use of time
    MOC221_ likes this.
  12. Oct 14, 2017 at 9:16 AM
    #6532
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I like where this discussion is going - a lot.
    When DFCO shuts the fuel off, put the engine in full OTTO mode. Surely 11.8:1 compression in an engine that's not actually "running" would produce good engine braking.
    On top of this, lower the fuel "back on" RPM to something much closer to idle, and change that silly cycle where the engine needs to rev up to 2000+ RPM before shutting down fuel again.
    I don't tow (right now, anyway), but can see where the stock situation would be extremely annoying and even dangerous.
    I foresee lots of testing on this to get it right, and perhaps even differing versions of the tune for ppl who offroad/tow/stay on the blacktop and don't tow.
    Edit: I wonder if there's a way to link the selection of 4lo to a different "DEFCO" map/maps? I mean, when you think about it, the A/T guys get different shift maps and whatnot when they hammer the magic ECT button. Maybe even a tow mode for us that's enabled when using the same ECM input as the auto truck's ECT input. Mat tunes it, we just have to add a switch to the dash/overhead console. I bet our ECMs are identical as far as I/O pinouts go... HMMMMM
  13. Oct 14, 2017 at 9:17 AM
    #6533
    MOC221_
    Frank
    You will be impressed with the differences! :goingcrazy::goingcrazy::goingcrazy::goingcrazy:
  14. Oct 14, 2017 at 9:20 AM
    #6534
    bshammer0
    Brandon
    Nashville, TN
    I gotta tell you... ECT on 1.02C-A/93 Octane. Wow. If you don't know what folks mean by "butt dyno" get your self educated, load the tune and hit that button! I would NOT want it on all the time it's so powerful but damn it's truly "fun mode" now!
    Tacoma2GR, TRDOBSESSED and MOC221_ like this.
  15. Oct 14, 2017 at 9:23 AM
    #6535
    MOC221_
    Frank
    Dammit man, you're making me :drool::drool: even more over 1.02C and it's not even a true M/T tune!!
    :annoyed:
    bshammer0[QUOTED] likes this.
  16. Oct 14, 2017 at 9:33 AM
    #6536
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    *rolls eyes*
    Rly...
  17. Oct 14, 2017 at 10:06 AM
    #6537
    bshammer0
    Brandon
    Nashville, TN
    To each their own. I love ECT esp in hilly, mountain, heavy load situations, but for daily driving in often slowmoving traffic it’s unnecesary for me...
    I will say though D on the new tune feels like a more refined and smoother ECT from 1.01b in many respects
    Tacoma2GR, sig916 and mateo_roberto like this.
  18. Oct 14, 2017 at 10:13 AM
    #6538
    MESO
    State of Jefferson
    I agree it's a little aggressive, but that's what this truck needs
    Tacoma2GR and bshammer0[QUOTED] like this.
  19. Oct 14, 2017 at 10:37 AM
    #6539
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    @OVTune I hav about 200 miles on 1.02C. I am a 04B11 ECU and I just got the following engine code associated with TRAC OFF and a CEL.
    The code is P0607
    This diagnostic trouble code (DTC) is a generic powertrain code, which means that it applies to OBD-II equipped vehicles. Although generic, the specific repair steps may vary depending on make/model. This code basically means that the programminging the PCM/ECM (powertrain/engine control module) has failed. This can be a more serious code and may also be refered to as "ECM Internal Circuit Malfunction".
    Read more at: https://www.obd-codes.com/p0607
    Copyright OBD-Codes.com
    I am reflashing to 1.01b which I ran for 900 miles with no issues.
    Please advise ASAP.
  20. Oct 14, 2017 at 10:42 AM
    #6540
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    I will look into this right away. Please flash back to your stock file / 1.01b
    For anyone else who has any issues please EMAIL me I will see that faster than posting here. Posting here instead of emailing me directly means there is a Chance I will not see it.
    su.b.rat and Trident904[QUOTED] like this.
Thread Status:
