Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jun 17, 2020 at 10:09 PM
    smikec
    smikec Well-Known Member
    Dude, this is TW. Most are truly trying to be helpful. Some dcks, sure.
    Don't bite the hand, politely correct when appropriate, but don't come out swinging since you might get hit back.
    Just my opinion
    But as many have suggested, you could just follow OVTUNED posts. Appropriately, consider those posts as the source of truth.
  2. Jun 17, 2020 at 11:38 PM
    xGRIMEYx
    xGRIMEYx Go follow #RheaTheGray on IG!
    RheaTheGray
    fort worth, tx
    17’ TRD PRO
    Fox 2.5s w/resi SSO slimline front bumper OVTune 1.05 SCS ray10s 285/75/17 KO2s JL Audio C5s Rigid Industries ditch lights & light bar Warn VR8-S gen II RCI rear bumper 5.29 nitro gears UpTopOverland roof rack TJM sliders ARB twin compressor bed mounted
    my PCMflash has always been the only thing highlighted for me to select to flash my truck in the past so can i not use that still with the 2.0 file? if not how do i get the P5flash to work???
    and how do you clear the values as recommended, ive never done that before either on all my tunes previously flashed.
  3. Jun 17, 2020 at 11:44 PM
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    PCM is dongle, dongles will not be getting 2.0
    To get 2.0, you have to turn in your dongle to OVtune, which then OVTune will give you a license for P5F and a master key for VFTuner.
  4. Jun 18, 2020 at 12:00 AM
    xGRIMEYx
    RheaTheGray
    fort worth, tx
    17’ TRD PRO
    the orange box with the usb cable to the computer is a dongle? i thought that was just a flash cable and when people referred to the dongle is was some older device, no?
    KrnTaco08 likes this.
  5. Jun 18, 2020 at 12:02 AM
    Rainoffire
    No, the dongle is the small USB key that you stick into the computer to run the flash.
    The Orange Box is the Tactrix OBD2 Adaptor.
  6. Jun 18, 2020 at 12:06 AM
    xGRIMEYx
    RheaTheGray
    fort worth, tx
    17’ TRD PRO
    ok yea i have the OBD2 then, maybe i need to relook at the P5flash and maybe it’s clickable but nothing happens when i click it
    can i not flash the 2.0 file with the PCMflash like i did with 1.05?
  7. Jun 18, 2020 at 12:11 AM
    Rainoffire
    I don't think so, PCM was meant for dongle users.
    Try "Config" > "Install All Software"
    Your AntiVirus must have deleted the P5F exe.
  8. Jun 18, 2020 at 12:13 AM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    If your flash too is grayed out, check you antivirus software. I know I had to add an exemption to get my to work after the most recent windows update.
    xGRIMEYx[QUOTED] likes this.
  9. Jun 18, 2020 at 12:51 AM
    dustynaka
    dustynaka Active Member
    Dustin
    2016 Magnetic Grey Metallic Tacoma DCSB, TRD Off Road, Prem. Tech Pkg w/ JBL
    Two questions for you guys.. Does anyone have OV’s mailing address to return dongle? Can’t seem to find it on the website.
    Also, are all ECU tune files the same now in 2.0? Or is there still more benefit to upgrade via tech stream first? I’m currently on 04B02.
  10. Jun 18, 2020 at 1:07 AM
    Rossejam
    Rossejam New Member
    Georgia
    2018 quicksand TRD off road
    ov tune, meso tail lights/interior lights
    Ov tune
    PO BOX 603
    Abingdon VA 24212
    It is more beneficial to upgrade but not mandatory
  11. Jun 18, 2020 at 1:07 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    dongle trade info:
    Please send your dongle to:
    OVTune
    PO BOX 603
    Abingdon VA 24212
    (USPS ONLY)
    please include your name & forum name with the dongle in the package.
    Then, please place your FREE order for dongle trade in of vF
    https://www.ovtuned.com/products/vforest-tuner-for-tacoma-flash-kit-owners?variant=31765449015383
    Skydvrr likes this.
  12. Jun 18, 2020 at 1:10 AM
    dustynaka
    Dustin
    Perfect. Thanks guys for the quick reply!
  13. Jun 18, 2020 at 2:14 AM
    godzilla888
    godzilla888 Just a plain white T
    Paradise
    2017 Super White SR5 DCSB AT
    Just trying to summarize...
    I may not be 100% correct here. I am known to be wrong, especially at home :angrygirl:
    ymmv
    for entertainment purposes only :goingcrazy:
    If I made a boo boo please lmk, I'll edit or delete as needed
    OVTune Flash Manager current version is 1.3.0
    Do not click ‘help > update’ in Flash Manager
    Download Flash Manager 1.3.0
    https://www.ovtuned.com/pages/flash-manager
    Download the software & Drivers P5Flash SOFTWARE LINK:
    https://cdn.shopify.com/s/files/1/0885/5830/files/p5flash.exe?6863261005404743
    TACTRIX DRIVERS LINK:
    https://www.tactrix.com/downloads/openport2_setup_1024791.exe
    P5 flash utility greyed out?
    1) Confirm you are on flash manager 1.3.0
    2) Try
    LstMinutePanic said:
    I found this in a post from @BadKitty , and it worked for me:
    If its a windows defender issue:
    -Go to Start > Settings > Update & Security > Windows Security > Virus & threat protection.
    -Under Virus & threat protection settings, select Manage settings, and then under Exclusions, select Add or remove exclusions.
    -Select Add an exclusion, and then select from files, folders, file types, or process.(OV tune stuff)
    I actually ended up taking a slightly different route by turning off "real time protection" under Virus & threat protection settings while running Flash Manager. While "real time protection" was off, I was able to use Flash Manager without any issues. I was sure to turn "real time protection" back on once I was done though.​
    3) Or, in flash manager, click 'config > purge local data', then click 'config > install all software', then wait about 10 sec
    paleh0rse likes this.
  14. Jun 18, 2020 at 3:14 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    I've got about 150 miles on 2.0 and my MPG is up significantly.
    Anyone else seeing the same?
  15. Jun 18, 2020 at 4:02 AM
    Hichung
    Hichung Well-Known Member
    Arkansas
    '18 TRD OR DCSB Tech+Prem 4x4
    Here’s a few extra tips to help make sure it gets there safely and for quick verification.
    Send it with tracking and insurance and use a bubble mailer/box of some type (or priority mail which includes insurance/tracking already).
    It’s a really bad idea to send it in a plain white envelope (USPS agrees).
    And make sure to include your information in the pack. It will make it easier to verify information when it shows up at OVTune’s place.
    dustynaka[QUOTED] likes this.
  16. Jun 18, 2020 at 4:27 AM
    TacoRob08
    TacoRob08 Well-Known Member
    Rob
    Fredericton, NB, Canada
    17 Sport DCLB
    gibson exhaust, OVTuned base 91, AFE intake
    My average daily driving is seeing better mileage as well. Gain of about 2mpg
  17. Jun 18, 2020 at 4:45 AM
    TacoLoco17
    TacoLoco17 Well-Known Member
    Craig
    Conshy, PA
    17 TRD OR DCSB Super White
    TRD Sport Hood swap TRD Exhaust TRD Intake TRD Skid plate TRD Pro Faux grille w/ Raptor lights MORIMOTO XB LED Headlights Rigid D series Fog lights Rigid E series 20” lightbar Spot/Flood MESO Ultimate Turn signal MESO Stage 1 Tailights 3x Remote Start Hypertech In-line Speedo Calibrator OV Tune Bilstien 6112/5160 Set at 5/6 OME Dakar Medium Leaf Pack Pioneer Avic 8400 NEX Headunit Infinity Reference 6x9s Front 6.5"rear Kicker Subaru Tweeters JL Audio Stealthbox w/ JL Audio RD500/1 amp ARE CX series cap Toyota OEM Trifold Hard Tonneau Body Armor HiLine Front Bumper Smittybilt X20 Gen 2 10K Winch SCS Ray 10 17x8.5 Gunmetal Rims 275/70 Falken Wildpeak AT3W tires
    I’m 100+miles in 04B04 and happy as hell. Definitely worth the wait. Glad i won’t have to read this sh!t show anymore. Some people just cant/won’t read before posting.
    Thanks @OVTune
    e46_ema, auskip07 and HardTaco712 like this.
  18. Jun 18, 2020 at 4:55 AM
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    Yeah I'm seeing about the same, which is quite significant considering I averaged 13mpg on the way into work (70mph up hill on the interstate). Up to 15 into work and 20 on the way home.
  19. Jun 18, 2020 at 6:05 AM
    rainyben45
    rainyben45 Well-Known Member
    Ben
    Ventura County
    2018 TRD OR DCSB 4x4
    What tune file and tire size?
  20. Jun 18, 2020 at 6:07 AM
    RustyTacoVT
    RustyTacoVT Well-Known Member
    Interestingly mine is way down. I was getting 19.5 avg on the last beta, am getting 16 now. I'll give it a while to settle in though and see what happens. This is also on the premium fuel tune now, whereas I was previously on the regular fuel beta tune while actually using premium fuel.
    Truck runs and drives great though, took it for a long ride last night.
    sorevilo likes this.
Thread Status:
