Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Oct 16, 2017 at 7:26 PM
    #6641
    Livinserene
    Livinserene Thejerkyguy
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    Any shipments to Canada today ?!?!
  2. Oct 17, 2017 at 3:11 AM
    #6642
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    same here, nothing shows after downloading and installing everything. You should have to do NOTHING other
    than plug em both in, run pcmflash and the dongle code will pop right up. Tried the entire process several times
    on 2 different laptops and using 7 different usb ports.
  3. Oct 17, 2017 at 3:27 AM
    #6643
    stevenjasmin
    stevenjasmin Well-Known Member
    2017 TRD OFF-ROAD
    I also had this problem, what worked for me is after you download the pcm flash right click on download and press “open in file”. There you will see a lone file, I drug that to my desktop and got it to work. Before this I had to download the pcm flash each time to get the dongle to work. This may or may not work in your case, but now mine works.
  4. Oct 17, 2017 at 3:29 AM
    #6644
    BlkTaco47
    BlkTaco47 Unhinged
    I don't follow, pcmflash is an executable there's only 1 file, the .exe.
    I assume you mean the compressed file that comes down and the exe
    contained within.
  5. Oct 17, 2017 at 3:46 AM
    #6645
    stevenjasmin
    2017 TRD OFF-ROAD
    Exactly, sorry I use Mac had to dig out a old pc just for this tune thing
  6. Oct 17, 2017 at 4:47 AM
    #6646
    BlkTaco47
    BlkTaco47 Unhinged
    ah, ok makes more sense then, I support a MAC dept as well
    as a windows network so I'd imagine there's an issue, not sure how
    it will be fixed other than sending out new drivers again and then we
    get to wait some more!
  7. Oct 17, 2017 at 7:49 AM
    #6647
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Received serial keys. Will be sending then out this morning. Hour or two from now.
    Thanks
  8. Oct 17, 2017 at 8:23 AM
    #6648
    erok81
    erok81 Well-Known Member
    Imposter
    Didn't work for me. :(
  9. Oct 17, 2017 at 8:25 AM
    #6649
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Be sure to disable Windows Defender or whatever other virus detection software you're running whenever you attempt to download or run pcmflash.exe
  10. Oct 17, 2017 at 8:34 AM
    #6650
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Just a follow up on the P0607 code with CEL and TRAC OFF light I had on 1.02C. I reflashed 1.02C and then selected Clear DTC per @OVTune's instructions and all is good so far after 160 miles on the reflash. I found out also that my girlfriend had put 5 gallons of 87 in my gas tank the night prior to getting the CEL. Not sure if this was to blame. I will update if the CEL shows up again.
    TRDOBSESSED and bshammer0 like this.
  11. Oct 17, 2017 at 10:03 AM
    #6651
    OVTune
    OVTune
    Okay everyone who is receiving " dongle not accessible" issue has been found. Sending out emails now. If you have this issue please email me if you have not.
    Please email me.
    Please email me.
    Toytaco2k17, 17TRDOR and erok81 like this.
  12. Oct 17, 2017 at 10:18 AM
    #6652
    erok81
    Imposter
    Email sent!
    I'm glad I brought my laptop to work today!
  13. Oct 17, 2017 at 10:40 AM
    #6653
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    Thank you!!! I just had to catch up on 30 pages of posts to get this comparison. :cheers:been running the 91 shift A for awhile... love it and didn't feel like reflashing. What's your load out look like? I'm heavy, on 285/70/17, and 4.56s. Thanks again!!!
  14. Oct 17, 2017 at 11:20 AM
    #6654
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    No problem! All stock aside from 265/70R16 Falken A/T3W tires which are only slightly heavier than stock. So, additional weight and larger tires I can only assume would increase the seat of the pants power loss on 87.
    seelyartacus[QUOTED] likes this.
  15. Oct 17, 2017 at 11:46 AM
    #6655
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Same - saved me from getting annoyed w/ the loss of power. I don't mind the extra at the pump for the fun of the giddy-up on premium. I am considering testing out Shift C just to see if 1st is a little less abrupt. It's still great in every aspect but I do wonder if I would "miss" the aggressive 1st so long as the shift FROM 4 to 5 and 1 to 2 are still smooth. Would love some more comparisons on this as people test them out. I know one member mentioned it was slower feeling...
  16. Oct 17, 2017 at 3:30 PM
    #6656
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    There's some amount of irony in this, but I digress :)
    PUMPED FOR M/T ON THE DYNO TOMORROW!
    Serious question, is the test mule running stock intake/exhaust?
    I hope so, good baseline for most ppl. But alas, we'll take what we can get :thumbsup:
    Toytaco2k17, Ares32 and lapoltba like this.
  17. Oct 17, 2017 at 3:33 PM
    #6657
    su.b.rat
    su.b.rat broken truck
    this question is best pointed to @Av8rJake
    very much looking forward to the MT dyno. :drool:
  18. Oct 17, 2017 at 3:35 PM
    #6658
    MOC221_
    Frank
    UHHH.. I didn't want to "out" the guy.... if err this is the guy. :anonymous:
  19. Oct 17, 2017 at 3:37 PM
    #6659
    su.b.rat
    he mentioned it in the forum. nothing weird or secretive. iirc
  20. Oct 17, 2017 at 3:37 PM
    #6660
    bshammer0
    Brandon
    Nashville, TN
    well if that is the GUY... then his profile says he's got TRD intake/exhaust so should be close "enough" to stock as the intake doesn't do a TON from what we've seen and the exhaust seems to be more sound than massive improvement in flow...
Thread Status:
