Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jul 26, 2020 at 9:23 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    ownubad likes this.
  2. Jul 26, 2020 at 9:57 AM
    SpeySquatch
    2016 TRD OR DCSB
    Been camping (still am) this weekend and 04B04 2.0 91 octane 4.88 non THX has been awesome. With my 4200lb trailer (full) I got 14mpgs towing to location and yesterday. Without it doing some sight seeing I averaged 22mpg. Very impressed with the tune as it seems to have settled nicely and behaves very consistent now at 500+miles on the tune. Only thing left is the same tune in the tune pack to adjust the voltage. Truck is 5650lbs 255/75/17 tires.
    Nice @OVTune!
  3. Jul 26, 2020 at 10:07 AM
    Tacohumper13
    Tacohumper13 IG @_.mfa_
    Menifee
    2017 TRD Off-road DCSB 4x4
    6112/5160s w/ camburg UCAs 265/70/17 wildpeaks JP8 conversion kit
    Nice numbers, crazy how much of a variant 04b04 is with these trucks.
    SpeySquatch[QUOTED] likes this.
  4. Jul 26, 2020 at 12:17 PM
    SpeySquatch
    2016 TRD OR DCSB
    Agreed. Mine is a 2016 and I have had next to zero issues besides a HP fuel pump under warranty. At 52k miles now
  5. Jul 26, 2020 at 1:54 PM
    smikec
    smikec Well-Known Member
    @Saiji Satoh
    This link by DES2009 seems to suggest the accessory might use .pcm files. I don't know.
    Perhaps OVTUNED sent you the wrong files (.bin format) assuming you had a Pro HH
    Have you tried to upload a pcm file?
    Found this archived link via google describing the different (accessory at bottom)
    https://www.ovtuned.com/blogs/news/flash-kit-vs-handheld
    seems to imply using the same files as flashmanager (which are not .bin files that you have)
    Saiji Satoh likes this.
  6. Jul 26, 2020 at 3:09 PM
    Saiji Satoh
    Saiji Satoh Well-Known Member
    Saiji
    Thanks for the infos.
    My HH is not a Pro. The files they send to are .bin. I am a flash kit user, never received .pcm file.
    For a common sense, if my Handheld - Flash Kit Accessory can’t even save the stock tune from the truck. How can it accept tunes from computer?
    In my opinion, this HH need a firmware update.
  7. Jul 26, 2020 at 3:24 PM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Here is another old post, but I don't know if it helps. I don't know where the "download page" that Mat mentioned is located.
    This post mentions a firmware update, but I don't know if it applies to you.
    Saiji Satoh[QUOTED] likes this.
  8. Jul 26, 2020 at 3:44 PM
    Saiji Satoh
    Saiji
    I remembered that firmware he mentioned. And i did get that firmware updated.
    Because the first time when connected the HH to the truck, it’s wasn’t recognized or some kind of error message. And that firmware was fixed the issue. But no one can tell if the HH is working until you got the tunes.
  9. Jul 26, 2020 at 5:36 PM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Help. Was there ever a fix for the 5.29 and AT 85mph speed governor? So weird that I can accelerate to 95 mph in 4th, but 5th and 6th won’t go above 85 mph. I don’t drive that fast very often, but going to Maine sucked with a 75mph speed limit.
    I’m currently on the newest 2.0, but experienced the same on other betas.
    blitzkrieg3002 likes this.
  10. Jul 26, 2020 at 10:44 PM
    jbehrens5898
    jbehrens5898 Well-Known Member
    Josh
    Huntington Beach, Ca
    2017 Gray TRD Off Road Long Box
    Fox 2.5 w/DSC REM 4.88 Icon Mini Pack OVTuned Caliraised LED's Bakflip MX4 WeatherTech's
    Nice, makes me excited for the 4.88 install tomorrow. Are you running the premium 4.88 tune for stock tire or 33"?
  11. Jul 27, 2020 at 1:07 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    what!?!?...... you're just going to say fuk it to the money you spent on the device?
    VB25 likes this.
  12. Jul 27, 2020 at 3:31 AM
    go2cnavy
    Was this ever fixed?
  13. Jul 27, 2020 at 9:25 AM
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    I still experience the same speed limiter on the latest 5.29 tune. I hadn't tested it on any other tune. it's for sure there. 2019 04b31 premium 5.29 33" non thx.
    on the other hand this tune has been amazing. I've logged a lot of towing miles towing heavy loads. Once i have gearlock back i think it will be perfect. It's been a real pleasure.
    GPatriot likes this.
  14. Jul 27, 2020 at 11:09 AM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    How much do you think that pod and those bikes weigh in total?
  15. Jul 27, 2020 at 11:10 AM
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    a rough estimate would be 4k on the pod and gear, and about 900-1k lbs of bikes and generator and gear in the bed.
  16. Jul 27, 2020 at 1:04 PM
    Mike O
    Mike O Well-Known Member
    2016 TRD OR MGM Access Premium LB
    Mobtown Sliders, SSO Slimline bumper, Baja Amber lightbar & fogs, Sumo bump stops
    Yeah, you would think that part of a tuners "art" (science?) would be determining exactly what is different between trucks with the same tune. If I recall, the 04b04 "variant' was the "standard" for quite some time; without issues specifically related to that tune. Strange, inconsistent behavior over the life of these vendor tunes. Makes me want to spend $ for forced induction that requires the tune.
    Here they come.......;)
  17. Jul 27, 2020 at 4:01 PM
    TacoSauceHB
    TacoSauceHB Well-Known Member
    Brian
    Rathdrum, ID
    2017 _TRD Off-Road DCLB 4X4 Tech Package
    King 2.5 ext travel, Camburg uniball UCA, SCS Ray10 wheels, 285/75/16 Cooper STT Pro's, CMC , MBRP exhaust, K&N cai , OVTune 1.05 , T-rex billet grill, Rigid DS Pro ditch lights, SDHQ ditch light brackets, Leer 100XQ Shell, ShmellFab Sliders, Victory 4x4 Roof rack, LED headlights. SOS Concepts bumper, Smittybilt X20 Winch, Nitro 5,29 gears, ECGS clamshell bushing.
    So I shipped my dongle a week ago. Arrived 07/21 at their PO Box. I have not heard anything since. Am I supposed to receive something physical to replace that dongle ? I am confused how this works and I just keep getting canned responses when I email OVTune.
  18. Jul 27, 2020 at 4:25 PM
    ivanza
    ivanza Well-Known Member
    Bay area, CA
    2017 MGM TRD OR MT
    Mobtown skids Fox 2.5 DSC OME heavy leaf
    to apply the tune, you need the OVtune or tactrix cable and then the tacoma 3.5 tune from ovtune?
  19. Jul 27, 2020 at 4:51 PM
    pick21
    pick21 Well-Known Member
    central illinois
    2017 TRD OFFROAD ACCESS CAB
    I want to buy a tune. I currently have no tune or hardware. can someone lead me to where I can purchase this? Thanks
  20. Jul 27, 2020 at 5:51 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    See 1st page.
    Or here https://www.ovtuned.com/
    ownubad likes this.
Thread Status:
