Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Oct 18, 2017 at 3:16 PM
    #6741
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Will be finished up in a about an hour.
    Lots of goodies coming to the MT now.
    Cleaner AF.
    Throttle response per gear enhancement
    Some cam timing changes
    PE crossover ( power enrich ) changes
    And some more.
    Plan will be same as AT with 3x 91 and 3x 87 maps with A B C throttle settings, which I've been working on the last few hours
    nxcess, Boxerocks, SigSense and 9 others like this.
  2. Oct 18, 2017 at 3:18 PM
    #6742
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    But there's no Like X 10000000000000000000000000000000000000000000000000000 button on TW.
    Boxerocks likes this.
  3. Oct 18, 2017 at 3:19 PM
    #6743
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Kudos for giving up your truck and driving 6+ hours for not only your benefit, but for all of us MT owners!
    Boom... Mic drop.
    You now notice what the AT probably masks very well. The bog when letting out the clutch from a stop in first gear was absolutely unacceptable on the stock tune. It was downright dangerous especially if you are trying to pull out into traffic. No amount of right foot could correct the problem until you got above 10-15 MPH.
    If you have found the cause and fixed the rev hang a bunch of other people mentioned I will eat my words. I honestly never noticed it, but I'll take all the improved throttle response you can muster.
    Boxerocks, su.b.rat and MOC221_ like this.
  4. Oct 18, 2017 at 3:20 PM
    #6744
    MOC221_
    Frank
    If there's one throttle setting for linear/no delay, I won't go any further! Don't need throttle amplification personally, but some may want it!
  5. Oct 18, 2017 at 3:24 PM
    #6745
    MOC221_
    Frank
    This "little" 2GR might be getting a lot of bad press WRT low end torque because of this. The 2GR I had in my RAV 4 had no such problems.
    Edit: Well if he finds/fixes the rev hang, it'll be transparent to you lol
  6. Oct 18, 2017 at 3:35 PM
    #6746
    MOC221_
    Frank
    Really Mat?!! o_O
    :goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy:
  7. Oct 18, 2017 at 3:38 PM
    #6747
    Toytaco2k17
    Toytaco2k17 Well-Known Member
    Kenneth
    Chapmansboro Tn
    2016 Nissan Titan XD Pro4x Diesel
    Stock
    @OVTune how much power did the truck make to the wheels stock?
    MOC221_ likes this.
  8. Oct 18, 2017 at 3:38 PM
    #6748
    OVTune
    OVTune
    Okay guys wrapping this up.
    I'll have as much info as I can out tonight in a MT specific thread.
    Took my time to give it the attention it needs.
    Thanks everyone.
    Boxerocks, hbaade, taco 16 and 8 others like this.
  9. Oct 18, 2017 at 3:39 PM
    #6749
    MOC221_
    Frank
    Nice, thank you Mat!
  10. Oct 18, 2017 at 3:41 PM
    #6750
    su.b.rat
    su.b.rat broken truck
    thank you!!!
  11. Oct 18, 2017 at 3:41 PM
    #6751
    MOC221_
    Frank
    In for the dyno charts later!!!!!
    Ares32 and Toytaco2k17 like this.
  12. Oct 18, 2017 at 3:46 PM
    #6752
    JasonCSU
    JasonCSU Well-Known Member
    Denver, CO
    2017 DCSB 4x4 TRD OR 6MT
    I've been lurking in this thread for quite a while and after seeing the good news for the MT, I will likely be getting this tune at some point.
    Livinserene, bshammer0 and MOC221_ like this.
  13. Oct 18, 2017 at 4:43 PM
    #6753
    Reluctanse
    Reluctanse Granny shiftin, not double clutchin
    Sam
    Newberg, Oregon
    '17 Tacoma DCSB Inferno TRD OR 6MT
    OVTuned, Grabbers, 5100s, Bakflip VP
    Thank you!!
  14. Oct 18, 2017 at 4:58 PM
    #6754
    Livinserene
    Livinserene Thejerkyguy
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    tick tock tick tock tick tock
  15. Oct 18, 2017 at 5:05 PM
    #6755
    iexc
    iexc WerXED BH2.0 AD
    Kalede
    Toronto
    2023 TRD Sport MT
    2nd that, i swore i wouldn't touch this tune if rev hang was not completely eliminated =excellent=
    ovtune is it possible to kill the DFCO to give the option to try,i understand this will drop fuel mileage but i believe it will add smoooothnes to drive.
    specifically in stop and go traffic below5-10 k. toooo much lash in these trucks and is traction control a function of ecu, default off would be nice.
    any benefit to buying tune now with the delay
  16. Oct 18, 2017 at 5:10 PM
    #6756
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    DFCO??? Fixed??
  17. Oct 18, 2017 at 6:06 PM
    #6757
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    @OVTune MT Engine braking improved with the MT specific tune?
    Any investigation into speedometer recalibration?
  18. Oct 18, 2017 at 8:18 PM
    #6758
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Better engine breaking please.....
  19. Oct 18, 2017 at 8:54 PM
    #6759
    nevadabugle
    Elko, NV
  20. Oct 19, 2017 at 8:35 AM
    #6760
    K_T
    K_T Member
    Kevin
    Denver
    2017 Black Tacoma Limited
    Long time reader, first time poster. I've followed this thread since it began, bought the tune, and I'm now trying to use it but having an issue with PCM flash.
    I see other have had this issue, but the fix seems to be load the drivers and try again. I have drivers loaded and I can see the Guardant dongle in windows device manager, but PCM flash still shows "USB dongle is not accessible (0)". I've restarted PCMflash several times, the laptop several times, removed and reconnected both usb dongle and usb odbc connector. What am I missing?
Thread Status:
