Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Aug 29, 2020 at 2:50 PM
    Distance87
    Distance87 Well-Known Member
    Garrett
    Driving up some mountain.
    2016 blue dcsb sr5 taco tss
    3 inch lift, custom exhaust with Flowmaster hp-2 muffler. Bedrack, decked system, arb on board air system, fabfours vengeance winch bumper with smittybilt X20 winch, dual car seats.
    there are alot of factors it just makes me miss drive by cable and pressure activated shift solenoids you may get less milage and put out more co2 but it felt like you had more control of the vehicle
  2. Aug 29, 2020 at 2:51 PM
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    Engine speed drops, vehicle speed increases. No gear shift or converter lockup state change. What am I missing?
  3. Aug 29, 2020 at 2:55 PM
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Zendesk request sent. STOKED!!!
    PNWTacoma and wahoobie like this.
  4. Aug 29, 2020 at 4:47 PM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
  5. Aug 29, 2020 at 5:12 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Ask @MDFM31.
    His truck does the TC dancing in 3rd...
    Fu**thistruck likes this.
  6. Aug 29, 2020 at 5:41 PM
    dunlap837
    2018QSDCLBSR5
    What I’m getting at is your data imply torque converter input speed (engine speed) drops by a few hundred rpm, but torque converter output speed (measured by vehicle speed) does not drop. I guess really this is just a blip and vehicle inertia keeps the transmission spinning until the engine catches back up at its new timing operating state.
  7. Aug 29, 2020 at 6:33 PM
    HeyWannaTaco
    HeyWannaTaco Well-Known Member
    Dan
    Ontario
    2019 Red DCLB SR5
    OVTuned, OKX Skids, AVS In-Channel, N-fab Predators
    I kind of miss driving a stick sometimes...
    Karminski and dunlap837 like this.
  8. Aug 29, 2020 at 6:51 PM
    Vlady
    Issy, WA
    But why RPMs drop if you command more throttle?
    Again. I'm rolling i to the intersection. I have a momentum..
  9. Aug 29, 2020 at 7:03 PM
    Distance87
    Garrett
    O yea I wish I would have gotten the stick option when I bought mine but the only one they had on the lot was plain white. And blue is my favorite color so I went with it
  10. Aug 29, 2020 at 7:16 PM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    Thanks @OVTune - cheers. Gonna get that AGM tweak in with this puppy!
  11. Aug 29, 2020 at 8:34 PM
    GPatriot
    GPatriot Well-Known Member
    Cincinnati, Ohio
    2016 Black Tacoma Sport 4x4 V6 DCSB AT Loaded
    KDMaxPro 10.0, OME 2" Med Duty lift, RCI Sliders, RoofRack, Skid Plate, etc.
    Maybe its my imagination but it doesn't do that in S4. Definitely not on ECT. But then it may jerk into gear. Frickn Toyota lol
  12. Aug 29, 2020 at 8:57 PM
    Vlady
    Issy, WA
    Selecting S4 does not mean you are in 4th..
    We all know Toyota can't tune a horse buggy, but seeing ol' B03 stuff in "final" 2.0 make me wonder..
    VB25 likes this.
  13. Aug 30, 2020 at 4:34 AM
    dunlap837
    2018QSDCLBSR5
    We know that throttle is not directly mapped to accelerator. You are not commanding more throttle, you are requesting more torque. The ECU has several knobs in addition to throttle it can turn to accomplish this.
    Does fuel momentarily cut when the intake valve timing changes? Or is any engine power consumed to complete this task?
    A TC is a fluid coupling, right. The input shaft and output shaft do not need to spin the same rpm. If, say fuel cuts, engine rpm will drop. But the trans rpm is not forced to drop instantaneously along with it because the two shafts are coupled only by fluid flow. The trans rpms would drop more slowly than the engine because there is more inertia in the vehicle than in the engine. Once fuel comes back on, engine rpm catches back up and begins driving the trans again.
    That is nothing but a long winded guess.
  14. Aug 30, 2020 at 4:39 AM
    CTtoNoVa
    CTtoNoVa Well-Known Member
    2017 DCSB TRD OR Magnetic Gray
    Pop N Lock
    Hey guys, I’ve been off this thread for awhile.
    Quick question. I have 04B03 and I could have sworn that package was not available for the longest time and would require flashing to 04B04. I just checked on OvTunes site and it appears 04B03 is there. Just wanted to make sure I’m not missing anything. I thought there was a reason the tune wasn’t made for 04B03.
    thanks in advance!
    edit: with reference to 2.0.
  15. Aug 30, 2020 at 5:39 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Lets hear what you are "seeing" in final that is from 04B03?
    FCL30 likes this.
  16. Aug 30, 2020 at 5:58 AM
    tater taco
    tater taco no it all
    Todd
    ground zero of the zombie apocalypse
    2016 ACLB TRD OR Quicksand OV Tuned 2.0 (91)
    OVTuned, decatted dump tubes
    *turning off notifications for this thread*
    MDFM31, RushT, MacFly and 1 other person like this.
  17. Aug 30, 2020 at 6:45 AM
    OVTune
    OVTune
    This guy has a habit of looking at logs and coming to his own wrong conclusions.
    I had to make some significant changes to 2.0 because is I'll informed posts caused quite a stir.
  18. Aug 30, 2020 at 6:50 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    2.0 Final Premium Stock non-THX shifts fine for me (2017 04B04). But it really does seem to feel a bit anemic when I step on the pedal from a stop. I have to mash the pedal much more than I would expect in order to get rolling. Also when on the interstate I find myself gradually slowing down when cruising, if I don't make a conscious effort to keep that gas pedal mashed down.
    dubs66 likes this.
  19. Aug 30, 2020 at 7:21 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Same. My pedal is mush. It all starts the same. Good tune, decently peppy and then after a bit back to short shifts and mushy pedal. It's infuriating. I'm ditching the Tacoma asap when the new tundra comes out. I'm so over this gutless turd.
  20. Aug 30, 2020 at 7:48 AM
    MacFly
    MacFly Well-Known Member
    2018 Cement Tacoma TRD Off Road AT
    OVTune, AT Habitat, Firestone RRs, ARB CKMA12 compressor
    what'd you get? Seriously looking at jumping ship myself....
Thread Status:
