Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Oct 26, 2017 at 1:32 AM
    #6841
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Flash keys sent out.
    register your key to PCMFlash and you're all set to read your ECU and send it over to us for a tune file.
    TacoLeeSD, TRDOBSESSED and MOC221_ like this.
  2. Oct 26, 2017 at 2:34 AM
    #6842
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    thanks Mat
  3. Oct 26, 2017 at 3:24 AM
    #6843
    ThatOneTaco
    ThatOneTaco Well-Known Member
    CA, Bay Area
    2017 DCSB 4X4 TRD Off-Road
    Sounds like shit has been resolved. No point in anymore back and forth. Let’s get this thread back on topic and move forward gentleman.
    @blkbelt42 let us know how you like the tune once you get situated.
    :cheers:
    dubstyle7, disk_55FL, MOC221_ and 2 others like this.
  4. Oct 26, 2017 at 4:14 AM
    #6844
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Thanks Mat, and if you have a pic of the beasts you're working on over there, I for one would love to see it!
  5. Oct 26, 2017 at 4:59 AM
    #6845
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Update at 460 miles (Transmission learning to be stupid):
    Transmission shifting more erratic.. including a return to TWO downshifts (to 4th) to get over the the larger humps on the bridge I mentioned in the first post above. Also this morning I only got 20.3mpg for the exact same morning drive that I mentioned in the second post above where I had got 26.4mpg before. I'm hoping not to see a re-occurrence of the other transmission issue I mentioned in the third post above.
    MOC221_ likes this.
  6. Oct 26, 2017 at 5:33 AM
    #6846
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    These maps were made with what the truck will think is a new ECU. Will they change, or will the behavior of the truck change, when the ECU "learns" your driving habits after 2-3k miles?
  7. Oct 26, 2017 at 5:36 AM
    #6847
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    I don't quite understand what you are asking but I will try to answer anyway. The tune is a completely new set of maps for the ECU. The changes people see from the time of flashing through a few hundred miles are to the "learned values" in the ECU. They are independent of the base maps. The maps Matt has created do not change. The learned values can be reset by software and adjust as environmental conditions or your driving habits change.
    BlkTaco47 likes this.
  8. Oct 26, 2017 at 5:51 AM
    #6848
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    But if the learning causes the truck to perform worse, degrades the driving experience, and causes a significant loss of mpg's.... the question becomes WHY?
    Why must the truck learn to be stupid?
    Who benefits? Certainly not the owner/driver. Does Toyota benefit from this nonsense?
  9. Oct 26, 2017 at 6:08 AM
    #6849
    BlkTaco47
    BlkTaco47 Unhinged
    Certainly weird. Do the AT guys need a tranny tune as well - is there one available as well as the ECU tune?
  10. Oct 26, 2017 at 6:24 AM
    #6850
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Anyone experiencing shifting weirdness on Shift A, I would recommend trying out Shift C. It's smoother and I haven't had that issue mentioned above where it "Feels like its not in gear" with Shift C though I felt it occasionally with Shift A. You will see an immediate MPG hit with Shift C but after a few days running it my morning commute was w/in 1 mpg of 1.01b. I still only have under 200 miles on it so of course learning is still happening but so far so good.
    @blkbelt42 there is no TCU (transmission) file for our trucks at this time. the shift and torque maps that control how and when the tranny shifts in the A/Ts is apparently embedded into the ECU (P5-Can-bus) file. not sure when/if there will be anything valuable we would flash to the "gear box" file.
    tune still runs great though, and there may be nothing ultimately that can completely undo the transmission weirdness but I do enjoy the updated shift smoothness and more aggressive middle gears of Shift C thus far.
  11. Oct 26, 2017 at 6:29 AM
    #6851
    BlkTaco47
    BlkTaco47 Unhinged
    thx on both dude. That's my plan as well to start off, 1.02c-C.
    I noticed it was listed in the drop down menu at about 4am :D when I activated pcmflash and did the initial read.
    bshammer0[QUOTED] likes this.
  12. Oct 26, 2017 at 6:35 AM
    #6852
    bshammer0
    Brandon
    Nashville, TN
    Cool. hopefully by the weekend once Mat wraps w/ his pro-tunes he'll be able to get some files back to folks. but do know that process can take a few days depending on backlog to get files out. this is because he takes the time to review your file, confirm version, truck details, and ensure you get the proper files tuned for your truck to minimize potential for failures. ...another one of those things he "could" automate but would increase risk this early in the dev process and he wants to look at each trucks ECU to confirm what he's sending it correct and that does take time across all the pending files he has. you're close though!
    MOC221_ and BlkTaco47[QUOTED] like this.
  13. Oct 26, 2017 at 6:49 AM
    #6853
    BlkTaco47
    BlkTaco47 Unhinged
    lmao...it's all good ;) Along with the rest of things going on, I have two discs I jacked up sparring, now
    that they're healed getting back to regular training will help relieve the tension. :D
  14. Oct 26, 2017 at 10:40 AM
    #6854
    fxrman
    fxrman Well-Known Member
    palm springs
    Quicksand 2016 trd double cab off road
    OVT 1.03 Tacoma bed matt Husky floor liners Insain fab aluminum bumper with Baja design s8 30" light bar DB custums grill with Baja design s8 30" light bar
    When writing the 1.02c file to the ECU, is it just the one file for the eng. or do you have to choose the trans file also..? If so do you write one at a time..?
    Going to try to load the tune on my lunch break but want to get it right...
  15. Oct 26, 2017 at 10:41 AM
    #6855
    BlkTaco47
    BlkTaco47 Unhinged
    fxrman[QUOTED] likes this.
  16. Oct 26, 2017 at 10:44 AM
    #6856
    fxrman
    palm springs
    BlkTaco47[QUOTED] likes this.
  17. Oct 26, 2017 at 11:04 AM
    #6857
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    It depends on your ECU version, and also on if you've previously loaded any tune. I'l try to find the info Mat had posted and emailed me.
  18. Oct 26, 2017 at 11:07 AM
    #6858
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    See Matt's post here.
  19. Oct 26, 2017 at 11:20 AM
    #6859
    BlkTaco47
    BlkTaco47 Unhinged
    Sounds like if he sends you 2, based on the stock read you sent him, that you need to use both. No?
  20. Oct 26, 2017 at 11:38 AM
    #6860
    fxrman
    palm springs
    Only had to load one file,
    1.02c A.
    Went very smoothly.
    Quick test drive says "WOW" big difference..
    Now it could be I'm just excited but it's powerband is linear and pulls from low end to redline really nicely and seems to be in the right gear all the time.
    Turned off LSD and TRAC then powered up ECT just to see how it was and it really wakes up this truck...!!
    Going around corner and punching the gas made the tires squeel like I've never heard in the year and a half I've owned it...
    OK time to settle down and drive it normal for a while and get better review of all the changes this tune made but for now really happy...
    Again thanks to all who answered questions helping me with problems I had....
    BlkTaco47 and bshammer0 like this.
Thread Status:
