Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Nov 10, 2020 at 1:36 PM
    INT.EGRATED
    INT.EGRATED Well-Known Member
    San Francisco, CA
    2006 Lexus GX470
    Correct, the zip of files Mat gave me was for `04B81 v2.0 Final VFT` for my 2016 tacoma. Am I supposed to have received a different set of files?
    If it helps, here's my calibration info:
    Code:
    Calibration: 8966304B1000
    Calibration file: 89663-04B10
    Part Number: 89661-04K60
    El Chivo Norteño likes this.
  2. Nov 10, 2020 at 1:49 PM
    Shellshock
    Iowa
    Yeah those are the wrong files for your truck (04b81 is a newer model year). I’d recommend applying the TSB to upgrade your truck to 04b14. Reply back to mat that you received the incorrect files and need the files for 04b14.
    Applying the TSB is easy and HIGHLY recommended, especially on the 16/17 trucks. All the information and files you need are found here
    https://www.tacomaworld.com/threads/ecu-tsb-update.562550/
    I’ve done this as have many others like @tonered, @MOC221_, @mZiggy and others. Plus then if I you want to get in on vF edits, we are all using 04b14 so its easier to assist all being the same calibration.
  3. Nov 10, 2020 at 1:58 PM
    Stormpeacock
    Stormpeacock IG: @storm.peacock
    Rich
    Atlanta, GA
    19 Cement Offroad
    MCB Elite Performance Tuned 5.29 Differential Gearing 35" Kenda M/T on Steelies SOS Bumpers, Skids, and Sliders Ranch Camper Shell
    "B1" looks a lot like "81"
    Simple error.
  4. Nov 10, 2020 at 3:07 PM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    @INT.EGRATED Like Shellshock said, update to the newest ECU version for sure
    Might I add that you should seriously consider putting a charger on the battery when you update to 04B14 because updating to the newest ECU through TS can brick your ECU if it runs into any issues. Flashing different tunes through VF is safe as Mat has made it brick proof but TS is a different deal altogether. Don't get me wrong, it's generally safe to use TS, but eliminating possible failure issues would be smart and low battery is a known issue to cause bricking.
    LstMinutePanic and Burmapeak like this.
  5. Nov 10, 2020 at 3:09 PM
    INT.EGRATED
    San Francisco, CA
    2006 Lexus GX470
    yep it's on a slow charger right now, and I'll probably leave it on the charger while updating through TS, battery tester shows `GOOD-RECHARGE`at 73% health.
    will update to 04b14 afterwards, already emailed Mat just waiting for a reply with the tune for it.
  6. Nov 10, 2020 at 5:18 PM
    honey
    honey Well-Known Member
    Jeff
    Wisconsin
    16 tdr sport inferno 4x4
    leather, T.C. 6", King coilovers, TC uca's, Alcan, amp, Pro comp, bushwaker, bamf, magnaflow, afe.
    I have 16, on 04b04! Running 2.0 final. Didn't know there was 04b14. Am I suppose to switch?
    ownubad likes this.
  7. Nov 10, 2020 at 5:25 PM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Not unless you turned your truck into a Manual transmission.
    04b04 is the most up to date for your Auto transmission.
    ownubad, Skydvrr, inksin and 2 others like this.
  8. Nov 10, 2020 at 5:29 PM
    honey
    Jeff
    Wisconsin
    Lol! Got it!:thumbsup:
    skyking3 and PapaRee like this.
  9. Nov 10, 2020 at 5:30 PM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    @honey, With your heavy, lifted, geared truck, you need to try one of @Mooseditty17 's most recent tunes. Or get with him or me to make you a custom tune specifically for your tire size, gears, and performance.
    Moose lives in Wisconsin.
    jomopdx, Mooseditty17 and honey like this.
  10. Nov 10, 2020 at 5:31 PM
    Shellshock
    Iowa
    04b04 is the newest for your truck. 04b14 is for the MT
    Skydvrr likes this.
  11. Nov 10, 2020 at 5:43 PM
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    what's the rest of your truck setup? tire size, estimated total added weight. That sounds about what i'm getting around town on a good day (15~16) (highway 16~18). i'm on 5.29 33 performance tune. heavy 285's and about 400lb added weight and live where there's lots of hills.
  12. Nov 10, 2020 at 6:01 PM
    honey
    Jeff
    Wisconsin
    Sounds good. I think I could use one. Still have a hard time with 6th gear with any incline or headwind or towing for sure. The 19800 seemed best. Am on 2.0 4.88. 35" thx. 91 octane. Always use premium, 91 or 93 whatever available! Would love to upgrade if someone can help! Just put on new shoes. Trying the new Toyo at3's 285 75 17.
    blitzkrieg3002 and skyking3 like this.
  13. Nov 10, 2020 at 6:49 PM
    SpeySquatch
    2016 TRD OR DCSB
    with 35’s and 4.88’s you will always have an issue with 6th.
    I have 32’s (255’s) with 4.88’s and it’s almost perfect (have 265’s too). Anything more in tire size and it’s exponentially increased (decay) every inch of tire as far as lag and gear holding
    Boltripper likes this.
  14. Nov 10, 2020 at 7:06 PM
    Jbrentb
    Jbrentb Well-Known Member
    Jake
    Wilmington NC
    Black 2016 Trd OR Dcsb
    17x9 mayhem prodigy’s with -6 offset duratrac 265/65-17, fox2.5 coil overs, fox 2.0 rear shocks, OME uca, custom vf tune, Urd spec-u exhaust, high flow catted dump tubes, mbrp muffler, S&B cai, Green lane off road skid and stump bumper, ss3 fogs, pro grill and tail lights, tint, led interior reverse and plate lights, bhlm retrofit HID headlights, Meso turn signals, gashole, and coin holder. hardtop on bed and mat. Blacked out meso everything!!!
    Ok so I just purchased @OVTune with a set of catted dump tubes. I’ve also got a URD u-spec exhaust already installed and s&b intake. I’ve been running 93oct for a few tanks already. Question is what’s the best tune for this set up? Thanks for the help guys. This is gonna be though for me since I’m already confused. Lol....
  15. Nov 10, 2020 at 7:17 PM
    honey
    Jeff
    Wisconsin
    I'm sure you are correct! I think I was first to regear, and was no 5.29 at the time!:(
    SpeySquatch[QUOTED] likes this.
  16. Nov 11, 2020 at 2:44 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    nope, not once. signed up many, many times......nothing.
  17. Nov 11, 2020 at 6:21 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    nothing in your spam?
    we have honestly been having tons of email issues lately.
    Speaking of that, we have been having a lot of orders lately, but are still getting back to people generally same day / next morning.
    If anyone here is expecting an email but not seeing it please check your spam folder, until we get this email problem resolved. Tons of people seem to not be seeing our email responses but we are definitely sending them.
    If you are expecting a vF Tuner master key, please check spam folder. If you have gmail it will end up there without a doubt. We do not know why.
  18. Nov 11, 2020 at 6:24 AM
    BlkTaco47
    BlkTaco47 Unhinged
    No, nothing. That's the first place I'd check (systems engineer so I ask my end users the same...way too often :D ) I signed up again today. I sent you my email over dm both gmail and corporate, happy to do some testing with you if that helps you sort anything out.
    BlazinBlue, Skydvrr and Taco16LB like this.
  19. Nov 11, 2020 at 7:11 AM
    SkunkTaco
    SkunkTaco Well-Known Member
    Kahl
    2017 Cement TRD PRO
    dumb question- I ordered the vftuner and the 3.5L tune pack. Now that I’ve sent in my ECU ID, I’m assuming the tune pack is supposed to be emailed to me? Or is there a shared drive somewhere that I overlooked? Thanks for the help!
  20. Nov 11, 2020 at 7:13 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I am curious if you can use the Account History page on your site to post Master Keys, REG files, and Tune Pack download links? It should be pretty easy to get folks pointed there?
Thread Status:
