Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jan 18, 2021 at 12:47 PM
    matdiot
    matdiot Member
    2019 Cement TRD Off-road
    Interface: Tactrix Inc. - Openport 2.0 J2534 ISO/CAN/VPW/PWM
    DLL: 1.02.4791
    Firmware: 1.17.4877
    Writing file: "location of file and name"
    Passing security checks
    Completed unsuccessfully
  2. Jan 18, 2021 at 12:50 PM
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Tr
    Try clearing dtc. Sometimes mine acts up takes a lot of trys and cycling of ignition to get it to take.
  3. Jan 18, 2021 at 12:54 PM
    matdiot
    matdiot Member
    clearing the DTC was successful, but the flash following that was still unsuccessful. Making progress!
  4. Jan 18, 2021 at 12:56 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I would try to unplug the cable, reboot the laptop, turn ignition on then connect the cable, hit identify and try to flash.
  5. Jan 18, 2021 at 12:57 PM
    Shellshock
    Iowa
    Try flashing a different file.
    PapaRee likes this.
  6. Jan 18, 2021 at 1:05 PM
    matdiot
    matdiot Member
    Hit identify 3 times, on the third round it finally identified it despite having been already previously identified. Then tried to Flash it, first time didn't work, turned ignition off then on, and flash worked successfully. Now I try to start the truck and it won't start, just ignition turns over....soo close!
  7. Jan 18, 2021 at 1:15 PM
    disk_55FL
    disk_55FL Well-Known Member
    disk
    Buckeye
    '17 TRD Sport MT
    Try clearing DTC's again.
    And be sure to turn off the truck after flashing.
    Skydvrr and PhogDog like this.
  8. Jan 18, 2021 at 1:18 PM
    matdiot
    matdiot Member
    Cleared DTC successful, truck started. Did this clear the flash I just installed? Thanks!!
  9. Jan 18, 2021 at 1:19 PM
    disk_55FL
    disk
    Buckeye
    '17 TRD Sport MT
    Probably not ....... try to read it again. If it's tuned you can't.
  10. Jan 18, 2021 at 1:19 PM
    Rock-N-Roll
    Rock-N-Roll Well-Known Member
    James
    Westminster, CO
    2021 T4R TRD ORP
    One mod away from marriage counseling
    If it was successful you will notice the difference right away. Night and day on my 2018 TRD OR AT.
    matdiot[QUOTED] likes this.
  11. Jan 18, 2021 at 1:26 PM
    matdiot
    matdiot Member
    Copy.
    WHen I try to read it, it says "Wrong ECU selected", "completed unsuccessfully".
    Time for a test drive! Thanks fellas! Hope these posts help others
  12. Jan 18, 2021 at 1:28 PM
    disk_55FL
    disk
    Buckeye
    '17 TRD Sport MT
    Let us know what you experience ... !
  13. Jan 18, 2021 at 1:31 PM
    Vlady
    Issy, WA
    Read is locked.
    Most my unsuccessful flashes were related to comm issues. I would've shit bricks if the truck would not start...
    Skydvrr likes this.
  14. Jan 18, 2021 at 1:38 PM
    Kalebscott
    Kalebscott Member
    Kaleb
    Orlando, FL
    2018 White SR 4x4
    6in rough country lift 33’s 4.88’s
    Hello all,
    I’m wanting to update my 2018 from 04A60 to 04A61. What is the procedure for doing this with OVTune? I have techstream. Can I flash 04A61 on top of 04A60 that has OVTune? Did I need to flash to stock 04A60 first?
    Also will I need to buy credits from OVTune to unlock the tune packs for 04A61?
    Thanks in advance for the help.
  15. Jan 18, 2021 at 1:39 PM
    chittyrox
    chittyrox When in doubt, throttle out.
    2018 Tacoma TRD Off-Road DCLB
    How do I apply a TSB?
    Everything you need is found here, thanks to @tonered
    https://www.tacomaworld.com/threads/ecu-tsb-update.562550/
    OVtune does not do tsb's. Techstream does that. Do the TSB first, then OVTune with the updated ECU.
    tonered likes this.
  16. Jan 18, 2021 at 1:40 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Skydvrr likes this.
  17. Jan 18, 2021 at 1:40 PM
    disk_55FL
    disk
    Buckeye
    '17 TRD Sport MT
    Start here : --> https://www.tacomaworld.com/threads/ecu-tsb-update.562550/
    If you have the hardware ........ the S/W is free.
  18. Jan 18, 2021 at 1:40 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just two steps. Flash the TSB to 04A61, then flash the 04A61 vF Tune that you want.
  19. Jan 18, 2021 at 1:57 PM
    Kalebscott
    Kalebscott Member
    Kaleb
    Orlando, FL
    2018 White SR 4x4
    I already have OVTune on 04A60. Didn’t realize it wasn’t the newest ECU when I got OVTune.
    Is there a way to download the 04A61 OVtune files?
  20. Jan 18, 2021 at 1:59 PM
    Shellshock
    Iowa
    Here’s how to update the ECU
    You’d need to message zendesk for new files
Thread Status:
