Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Feb 11, 2021 at 10:29 AM
    Zacreth
    Zacreth Member
    '21 MB first taco ever!
    it makes me wonder if it makes a difference adding the changes or not. I'm stock right now but plan on a lot of changes over the next couple of months.
  2. Feb 11, 2021 at 10:40 AM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    I can tell you in my experience, trying every tire size and every different gear size, I could not tell much if any difference.
    Now if you change airload maps, throttle maps, shifting maps, etc, there are changes felt.
    honey and Skydvrr like this.
  3. Feb 11, 2021 at 10:49 AM
    Zacreth
    Zacreth Member
    That's understandable. I'll mess with it more here shortly and see what I can find out. I'm on the 04c20 map and most of the work from others is done on the older maps. I'm curious to see what they have changed but I know my taco is a whole other beast from the earlier years.
  4. Feb 11, 2021 at 10:50 AM
    Richardericmeeker2
    Richardericmeeker2 Member
    Richard
    2016 trd quad cab crawl control
    Lvl kit 33" tire
    - Gearlocking - Enable by S mode, no longer enable by ECT
    Does this mean you can lock the rear diff in four high just by shifting into S mode on the automatic shifter?
  5. Feb 11, 2021 at 10:50 AM
    MGMSangTaco
    MGMSangTaco Colorado Toyota Tuning
    Denver, CO
    2017 TRD OR MGM DCLB
    Some people prefer to have the tire size higher than what they actually have, idk if thats because of weight or what. I personally haven't noticed a difference either.
    PapaRee likes this.
  6. Feb 11, 2021 at 10:51 AM
    disk_55FL
    disk_55FL Well-Known Member
    disk
    Buckeye
    '17 TRD Sport MT
    No ......... gear lock is for the AT.
    The Diffs are controlled by a different ECU.
    Skydvrr and tonered like this.
  7. Feb 11, 2021 at 10:52 AM
    Shellshock
    Iowa
    Tire size and gears are factored into the algorithm used in the ECU. Everything that references that is somewhat of a mystery, but it does do something. The other tables will be the same as its basically just a modification to the calculation done.
    ihatemytruck and tonered like this.
  8. Feb 11, 2021 at 10:58 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    From end-user, nothing..
    I drove tunes from guys with 33 on stock truck. Absolutely zero impact.
    PapaRee likes this.
  9. Feb 11, 2021 at 11:09 AM
    Richardericmeeker2
    Richard
    Lvl kit 33" tire
    Is there a way to do this with a flash to A/T
  10. Feb 11, 2021 at 11:13 AM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    There is a tune from way back--May 2020 that had this feature. The problem was that this tune also had a "stumble start"---The starter would run a mili-second after the engine starts. If you want to try it, here it is.
    Skydvrr, FCL30 and TWTaco like this.
  11. Feb 11, 2021 at 11:14 AM
    SpeySquatch
    2016 TRD OR DCSB
    you are saying changing the gear ratio and tire size in VFtuner between tunes does nothing to the driving experience?
  12. Feb 11, 2021 at 11:18 AM
    Badbasic
    Badbasic New Member
    Terry
    2021 black tacoma sr dbl cab 4wd
    I'm interested!
  13. Feb 11, 2021 at 11:29 AM
    Richardericmeeker2
    Richard
    Lvl kit 33" tire
    Stumble start like rolls the starter against the fly wheel or just starts to start and stumble then starts hole new start the completes it is if you didn't apply the button enough
  14. Feb 11, 2021 at 11:31 AM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    It starts fine. I ran it a while with no problems. It just sounds like the starter runs a mili-second long.
  15. Feb 11, 2021 at 11:36 AM
    Richardericmeeker2
    Richard
    Lvl kit 33" tire
    Ok that doesn't sound bad .
    And so when I run this flash it will allow me.to lock my rear diff in four high .
    Is it possible to run it while not in 4 wheel drive ?
    Really I would to block vsc abs and lock in four high . If I could lock any time that would be sweet but for me the first 3 are a must . Im at the point to where I might just trade in or sell my truck. I use to have a 1990 runner on 37 and a manual manual smog legal that I converted . I want full control of my truck . I feel like I'm bieng banbysitted
  16. Feb 11, 2021 at 11:37 AM
    disk_55FL
    disk
    Buckeye
    '17 TRD Sport MT
    No ...... OVtune flashes have nothing to do with the diff.
    Skydvrr likes this.
  17. Feb 11, 2021 at 11:38 AM
    TWTaco
    TWTaco Well-Known Member
    Dave
    DOES NOT LOCK YOU INTO 4HI!
    Skydvrr likes this.
  18. Feb 11, 2021 at 11:39 AM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    That tune is for gearlocking in S mode. Not differential lock.
    Skydvrr likes this.
  19. Feb 11, 2021 at 11:40 AM
    TWTaco
    Dave
    It allows you to control shifting manually.
    Skydvrr likes this.
  20. Feb 11, 2021 at 11:52 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Editing gearing and tire size in vF properly adjusts your shift points, otherwise you'll be shifting earlier than you'd like and your top speed will be limited to much lower than it should be (i.e. like 88mph or something like that for people with 5.29's)
    To say there's no benefit for the end user is pretty ignorant.
Thread Status:
