Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. May 18, 2021 at 1:04 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Another one for the ignore list, and a record I think. Just 36 posts.
  2. May 18, 2021 at 1:23 PM
    malichite
    malichite Active Member
    2020 TRD Offroad
    I think this will be a good thing. As a new person to this, it was a bit chaotic trying to find where the latest information or place to follow up and get a response was. I do appreciate that you did take quick care of my issues. I would say the biggest takeaway is regardless, no one is getting help unless they email through zendesk. That is where I actaully got help.
  3. May 18, 2021 at 1:46 PM
    HCFR TACO22
    HCFR TACO22 Well-Known Member
    Vic
    Tampa,FL
    2019 Tacoma SR5 on 33's DCSB
    KDMax Performance Tune
    I've seen it many times before bro. people ask valid questions no matter how many times its been asked you always have that one guy that has to be a smart ass about it. not trying to start anything with anybody just speaking my mind that's all. then again you always have the band wagon boot lickers, but its all good I'm chill
  4. May 18, 2021 at 2:28 PM
    fullsend604
    fullsend604 Well-Known Member
    2018 Tacoma TRD Sport 4x4 DCLB
    Yukon 5.29 gears, Eaton ELocker, Stoptech 6 Piston front BBK + Stoptech 4 Piston rear BBK conversion (Tundra master cylinder upgrade), 315/70R17 Falken Wildpeak AT3W, Advan RG-D2 17x8.5 wheels (Indigo Blue), Fox 2.5 PE mid travel w/DSC adjust, Icon RXT leaf pack, DRT shackle hangers w/crossbar, BTF high caster LCA, SPC UCA, OVTune 5.29 (87 regular tune), C4 Hybrid front bumper (30" Rigid light bar + 3" pods), C4 Rock Runner HC rear bumper (Baja Designs S1 wide cornering reverse lights), C4 oversized tire fender kit, Cali Raised trail rock sliders, Cali Raised Overland bed rack, Cali Raised bed stiffeners, RCI engine/trans/tcase skids, CBI fuel tank skid, Prinsu cab rack, Borla Type-S exhaust, Morimoto XB LED head + tail lights.
    So I've successfully upgraded from the P5 Flash Utility Tool to vF Tuner, registered my VIN/calibration ID and received the 2.0 Final VFT tune packs. I noticed the .VFT files are the exact same as the previous .P5F files I have from 2019 when I first flashed 2.0 Final and they are same file size 2049 KB. Does this mean I do not need to flash again as there have been no changes to the 2.0 FINAL and this was simply just to switch to the new platform? For example the previous files are named 04A61_Premium_Stock_thx.p5f vs the new one I got which is 04A61_Premium_stock.vft so the only difference is the file format that has changed correct?
    Chasespeed likes this.
  5. May 18, 2021 at 2:33 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sort of. While the map data in those files are the same, you now have a bunch of maps that you can freely edit with more coming with new versions.
    If it was my Taco, I jump in there and turn off the 1st Gear and Reverse Torque Limits, turn up the Speed Limiter, and maybe bump up the Tire Size (radius) if you are on anything by the stock tires.
    fullsend604[QUOTED] likes this.
  6. May 18, 2021 at 2:41 PM
    fullsend604
    Gotcha, thanks for the info! Only problem I am having is as per step 7.3 - 7.4 of the installation guide, after pressing "Select Calibration File" it only allows me to select .VFC files and all the new files I just got from OVTune are .VFT files so they do not show up and I am unable to select any of the new files..
  7. May 18, 2021 at 2:46 PM
    N5J_Taco
    N5J_Taco Well-Known Member
    Make sure you have 1.2.9.9.9 and open a .vft file with vftuner then export it to a folder of choice. Once exported it is automatically changed to a .vfc file with the new upgrade.
    tonered and fullsend604[QUOTED] like this.
  8. May 18, 2021 at 2:47 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    What @N5J_Taco said. You'll be good to go.
  9. May 18, 2021 at 2:58 PM
    Kesore
    Kesore Naked MG OFF ROAD
    PNNW
    17 Magnetic gray ordc
    285 Ridge Grapplers
    When did you email Zendesk to request the key for the VFtuner software registration. Im still waiting for mine.
  10. May 18, 2021 at 2:59 PM
    fullsend604
    I am using 1.2.9.9.9 but unfortunately I do not have the option of opening .VFT files with my vF Tuner to export, the options are not able to be selected and are greyed out.
  11. May 18, 2021 at 3:04 PM
    fullsend604
    I sent my request April 27 and received master key on May 16.
  12. May 18, 2021 at 3:10 PM
    Kesore
    PNNW
    285 Ridge Grapplers
    That was quick. I sent mine April 19th and Im still patiently waiting. thank you.
  13. May 18, 2021 at 3:24 PM
    BrettsMac08
    BrettsMac08 Well-Known Member
    Kansas
    2016 DCSB TRD Sport | 2002 Camaro SS
    KDMax Tuned | MagnaFlow Exhaust | OEM Audio Plus Reference 450Q | TRD Pro Wheels | AT Tires | LED Interior Lighting
    This is the question I’ve had the last couple of days. The new “lite” vF does NOT have the ability to open files.
    Also, it can only flash .VFC files.
    The tune pack (in fact I never got one, mine are all .P5F still) is .VFT
    So if you get upgraded, and get the tune pack. They cannot be flashed….
    I hear the stock tunes will be updated to .VFC in 1.3.0 but what about tune packs and how will we go about requesting those? Seems like we have to email in a follow up to request our 2.0 tunes be in .VFC format.
  14. May 18, 2021 at 3:32 PM
    fullsend604
    Understood, I guess I will have to reply to the support desk email and request the stock tune 2.0 Final files in .VFC format. I'm assuming I have the "lite" version because I didn't pay the $79 to upgrade to the full version since I do not have the need to edit files since I'm happy with the stock 2.0 Final version the way it is.
  15. May 18, 2021 at 3:33 PM
    N5J_Taco
    Did you purchase the tune pack? If so you should have gotten an email from Mat with a link to access tunes for the ECU you requested. If NOT the factory tune is in C:/program files (x86)/vftuner/tacoma
  16. May 18, 2021 at 3:36 PM
    N5J_Taco
    Contact support@ovtune.zendesk.com and let Mat know what is going on.
  17. May 18, 2021 at 3:45 PM
    fullsend604
    I am one of the original P5F Utility flash kit users with orange ODBII and have been tuning with that since early release many years ago (pre 1.05). I upgraded from P5F Utility to vF Tuner recently as it was mandatory so I'm not sure if this means I've purchased any tune packs? Seems like I just need to request the v2.0 Final files from support desk in .VFC since the vF Tuner "lite" version restricts me from opening any files and convert them from .VFT to .VFC format. I only want to run the stock v2.0 Final files and don't require the need to edit tunes, thanks for the help much appreciated!
  18. May 18, 2021 at 3:46 PM
    N5J_Taco
    Mat said he was working on them BUT I would send him another message to support@ovtune.zendesk.com with your email info, and order number.
  19. May 18, 2021 at 3:48 PM
    N5J_Taco
    Yes contact Mat at support@ovtune.zendesk.com and he will get you the files needed for your ECU.
  20. May 18, 2021 at 3:53 PM
    fullsend604
    Will do, seems a bit counterproductive that they didn't think of this before sending out the files as I'm sure there currently are/will be many old P5F users who will be doing the mandatory upgrade to vF Tuner and most if not every one of them will be running into this issue. Hopefully OVTune sees this and will just send out .VFC files to begin with to avoid the mass emails that will be coming in requesting .VFC files because they aren't able to flash with .VFT files like me therefore OVTune doesn't have to do the emailing work twice. Cheers!
    LTacoman and BrettsMac08 like this.
Thread Status:
