Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jan 4, 2018 at 9:08 PM
    #7901
    ThatOneTaco
    ThatOneTaco Well-Known Member
    CA, Bay Area
    2017 DCSB 4X4 TRD Off-Road
    There are 6 files
    3 for 87 Octane
    3 for 91 Octane
    Each of the 3 has different calibrations regarding the transmission adjustments.
  2. Jan 4, 2018 at 9:10 PM
    #7902
    ThatOneTaco
    CA, Bay Area
    Per @OVTune
    There are 3 different shift settings to select from, and 87 octane tunes to match.
    Shift setting 1 - All gears have been adjusted
    Shift Setting 2 - Gears 1-4 have been adjusted
    Shift Setting 3 - Gears 2-5 have been adjusted
    1.02C includes:
    throttle map changes for D and ECT mode
    rukness likes this.
  3. Jan 4, 2018 at 9:33 PM
    #7903
    dubstyle7
    dubstyle7 Well-Known Member
    Nic
    Dana Point, CA
    2016 Super White Tacoma TRD Sport 4X4 DCSB
    I may want to flash back to stock file before my service next week. OV never sent me stock tune file, I suspect it may be the file I sent him originally but I wasn't sure if that's the right file or not. If anybody knows, please let me know.
    Lt_Dan likes this.
  4. Jan 4, 2018 at 9:38 PM
    #7904
    rukness
    rukness Well-Known Member
    Thank you.
    ThatOneTaco[QUOTED] likes this.
  5. Jan 4, 2018 at 9:42 PM
    #7905
    Shellshock
    Iowa
    Yes it’s the file you read and sent off.
    I’ve had mine in for service and no one has said a thing. But that’s just been oil and tires.
  6. Jan 4, 2018 at 9:44 PM
    #7906
    dingel5
    dingel5 Mocphus
    Paul
    P Town, California
    2016 MGM SR5 AC AT 4x4 OVTuned 2.0B (Un)Dongled OG
    In progress.... And getting better!
    Just emailed engine and AT read files. Pissing myself with anticipation. Can’t wait.....
  7. Jan 5, 2018 at 4:46 AM
    #7907
    Ares32
    Ares32 Well-Known Member
    America
    2016 MGM TRD off road DCSB M/T
    Bump @OVTune. Will this include 04B10 or are we sol?
    MOC221_ likes this.
  8. Jan 5, 2018 at 5:47 AM
    #7908
    Lt_Dan
    Lt_Dan Well-Known Member
    Daniel
    Cincinnati OH
    2017 TRD OR 4x4 DCSB A/T Super White
    There are two files that I read (engine and transmission) and emailed to OVtune, do I have to write both of them to go back to stock?
  9. Jan 5, 2018 at 5:59 AM
    #7909
    offgrid taco
    offgrid taco Well-Known Member
    ned
    mass
    24 trd off road bronze oxide
    How about info on 2018 mt support. Are you working on this?
  10. Jan 5, 2018 at 6:11 AM
    #7910
    InternationalHarvester
    InternationalHarvester VF Pro Licensed, KDMAX Authorized Vendor
    Sierra Nevada
    2017 TRD DC LB OR 4x4
    KDMAX Tooooned
    When you installed the tune, you should have only wrote on “...P5-CAN-bus”. So, if you want the stock tune back, that’s where you’d write it. The one for the transmission says gearbox. DONT write to that one.
    Lt_Dan[QUOTED] likes this.
  11. Jan 5, 2018 at 6:23 AM
    #7911
    Lt_Dan
    Daniel
    Cincinnati OH
    So the engine will go back to stock but the transmission will stay OVtuned?
  12. Jan 5, 2018 at 6:26 AM
    #7912
    jholc21
    jholc21 Well-Known Member
    Colorado
    2017 White Tacoma TRD OR
    Bilstein 6112/5160 w/Dakars Leafs 255/80/R17 Cooper ST MAXX Skinnies 4.88 Gears TRD Pro Fog Lights Cali Raised 5D Combo Leather Seats LED Bed Lighting ARE Overland Shell
    No - it should put everything back to stock config. - P.S. Your screen name is awesome. Every time I see it, I hear Gump saying. "Lt Dan, You got new legs!"
  13. Jan 5, 2018 at 6:26 AM
    #7913
    Shellshock
    Iowa
    There currently is no transmission tune. Everything is done via the ecu
  14. Jan 5, 2018 at 6:33 AM
    #7914
    Lt_Dan
    Daniel
    Cincinnati OH
    Oh, I see, I wonder why the instructions say to read the gearbox too.
  15. Jan 5, 2018 at 6:35 AM
    #7915
    Sierra Nevada
    KDMAX Tooooned
    The way I understood the instructions is that it’s optional at this point (reading it). There currently is no option to write because we don’t have a tune file for it.
  16. Jan 5, 2018 at 6:36 AM
    #7916
    Lt_Dan
    Daniel
    Cincinnati OH
    lol....Since I read the engine and the transmission, I don't remember which file is the engine since they're both named almost the same, the only different is that one contains 04B02 and the other one 04012, I'm not sure which one is the correct one to go back to stock.
  17. Jan 5, 2018 at 6:37 AM
    #7917
    Lt_Dan
    Daniel
    Cincinnati OH
    You're write, it does say "you can," that verbiage sounds optional.
  18. Jan 5, 2018 at 6:38 AM
    #7918
    jholc21
    Colorado
    My Stock ECU bin file is 1536 kb while the stock trans bin file is 1280 kb. Don't know if that helps.
  19. Jan 5, 2018 at 6:41 AM
    #7919
    Sierra Nevada
    KDMAX Tooooned
    My stock ECU file is 1.5 MB while my gearbox is 1.3 MB. The one that says 04B02 should be the ECU
  20. Jan 5, 2018 at 6:43 AM
    #7920
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    04012 is the TCU file, 04B02 is the ECU file. Yours are the same version numbers as mine. Back in October when I wrote the files OVTune sent me, he instructed by email to write the "102BB" file he sent FIRST, then the new actual tune file. I don't know how (or if) that applies when going "back" to the original factory tune.
Thread Status:
