Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jan 22, 2018 at 7:36 AM
    #8381
    ThatOneTaco
    ThatOneTaco Well-Known Member
    CA, Bay Area
    2017 DCSB 4X4 TRD Off-Road
    I almost never use S Mode. If I wanted a Manuel I would have purchased a manual. Part of me regrets not doing so to begin with.
    speedtre and bshammer0 like this.
  2. Jan 22, 2018 at 7:49 AM
    #8382
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Yeah, I hear that. I'm actually not proposing we treat it like a manual though - just be able to shift it to S5 or S6 on startup and leave it. Still, I know we'd all love to just throw it in D and never think about it again (like most automatics historically) and with what i'm seeing from Mat, he's probably about to nail it but always good to have options.
    ThatOneTaco[QUOTED] and speedtre like this.
  3. Jan 22, 2018 at 7:54 AM
    #8383
    boxerfan
    boxerfan Member
    Max
    2016 tacoma trd sport
    I have been using the shift sense pro for about 6 months. The last month has been with the tune. I tried using just the tune and the truck ran a bunch better but it is still powered by an astmatic mouse. The guy at SSP is great to work with and I am now running and updated chip that contains 3 shift programs.. It shifts into 5th at 63mph and 6th (double overdrive) at 73. This is using the 3rd program which he called the towing version. He also lowered the downshift "threshold" for me so I would not have to gouge on it to downshift..
    I,m sure Matt can achieve the same results with the tune and I hope he does. I think keeping truck as weak as this one in it,s "power" range is just as important as the engine tuning. Or is equally benificial .... Max
    bshammer0 and Taco16LB[QUOTED] like this.
  4. Jan 22, 2018 at 8:14 AM
    #8384
    Taco16LB
    Taco16LB Well-Known Member
    Report again if you would, after running with both SSP and Tune after more than 1000 miles or so . See if you feel the truck seems to have learned any old habits or if the tune has degraded as some here experience while in D.
    It may be as simple as OVtune to program the tune to tell the truck it is in S mode to stop the learning .
  5. Jan 22, 2018 at 11:43 AM
    #8385
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    S mode isn't manual, it simple limits the top gear to whatever is selected. If you put it in S-2 and plant your foot a 10mph it'll still change down to 1st but not going into 3rd.
    I only use it for limiting to 5th when towing.
  6. Jan 22, 2018 at 12:50 PM
    #8386
    ThatOneTaco
    CA, Bay Area
    Nope, you’re incorrect sir.
  7. Jan 22, 2018 at 12:53 PM
    #8387
    acemastr
    Aaron
    Tampa, FL
    OVTune
    No, I'm not.
    People have been asking Mat to change it to lock it to a gear for months, it simply doesn't work that way from factory. It limits the TOP gear.
  8. Jan 22, 2018 at 12:54 PM
    #8388
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    this is correct.
    From Page 196 in the owners manual:
    *2: Selecting shift ranges using S mode restricts the upper limit of the possible gear ranges, controls engine braking forces, and prevents unnecessary upshifting.
    https://www.toyota.com/t3Portal/document/om-s/OM04005U/pdf/OM04005U.pdf
    Taco16LB likes this.
  9. Jan 22, 2018 at 12:55 PM
    #8389
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    You need to revise your understanding. He's correct.
    ihatemytruck, Herniator and Taco16LB like this.
  10. Jan 22, 2018 at 1:44 PM
    #8390
    ThatOneTaco
    CA, Bay Area
    I was typing a response to explain my side but you know what? I’m not gonna side track this thread anymore than it already is.
  11. Jan 22, 2018 at 1:48 PM
    #8391
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    I love comments like this with no explanation on how it does work.
    zerospeed and Boost3 like this.
  12. Jan 22, 2018 at 2:03 PM
    #8392
    Taco16LB
    I guess I am the one that side tracked the issue by asking if a combination of the SSP AND the OVtune would stop the AI learning that seems to be a problem while enjoying the TQ and HP gains .This was never a what's a better product . It was an idea to help solve the problem of the original Toyota weak engine/trans combos that the 3rd gen has .
    @OVTune ?
  13. Jan 22, 2018 at 2:14 PM
    #8393
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Or when they say they are correct, because they think they are, and then delete said comments. :laughing:
    Did Mat say that learning is still present in S mode?
    I wonder if the default gear for S mode could be "S5" instead of "S4"? @OVTune
    Reypac24 likes this.
  14. Jan 22, 2018 at 2:36 PM
    #8394
    ThatOneTaco
    CA, Bay Area
    Like I said, not trying to side track a thread anymore than it has been. We can chat via private messages or you guys can open another thread. Either way I’d like to focus more on OVTune updates.
  15. Jan 22, 2018 at 2:41 PM
    #8395
    sig916
    sig916 Well-Known Member
    I'm one of them and will continue to ask... Matt have said it many times that he's going to do it. Last he stated it will be done on 1.03 but I'm sure it's not going to happen. I'm not going to rush him because I know there's other important things he needs dail in.
    MOC221_ likes this.
  16. Jan 22, 2018 at 2:48 PM
    #8396
    sig916
    Default gear for s mode should be in the appropriate gear which is in
    TC_Mic likes this.
  17. Jan 22, 2018 at 2:53 PM
    #8397
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    It really feels like 4th. Say you're on the highway doing 70-75, and you switch over to "S" mode. It downshifts every time, leading me to believe it's default is 4. Anyone else experience this?
    dingel5 likes this.
  18. Jan 22, 2018 at 2:58 PM
    #8398
    bshammer0
    Brandon
    Nashville, TN
    yeah, I don't think I've ever seen it shift to anything higher than 4 but I could be wrong. I know that if I've switched over at low speeds it will sometimes start in 3rd but I haven't noticed it shift to 5th, in fact I'm careful not to shift it over there if I'm going very fast b/c of a potential harsh downshift I've experienced.
    The SSP vs. OV vs. PC debate exists in many other threads and my asks about S-mode were not intended to re-ignite this debate here, however I do believe a clear understanding of how S-mode operates as it relates to shift performance and AI is relevant to the OV conversation (and the manual is notably light on descriptions to the technical level most of us would like to understand...) as we work to collectively provide feedback and perfect the tune characteristics. He has it damn close, folks!
    niko5055, dingel5, speedtre and 3 others like this.
  19. Jan 22, 2018 at 4:29 PM
    #8399
    sig916
    U got me wrong. What I was saying is that ov should make the default gear for s mode in whatever gear the truck in. sorry for the confusion..
    TXTaco13[QUOTED] likes this.
  20. Jan 22, 2018 at 6:12 PM
    #8400
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Ah, ok. :fistbump:
Thread Status:
