Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jan 23, 2018 at 6:35 AM
    #8401
    dingel5
    dingel5 Mocphus
    Paul
    P Town, California
    2016 MGM SR5 AC AT 4x4 OVTuned 2.0B (Un)Dongled OG
    In progress.... And getting better!
    Definitely. Going uphill, I either have to slam the throttle through the floor and skip shift from 6th directly to 4th (what 5th gear?) or just shift into S mode and get the same result. I agree that shifting from D mode into S mode should default to the gear that the truck is currently in.
  2. Jan 23, 2018 at 6:43 AM
    #8402
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    ^^^^ Yes please
  3. Jan 23, 2018 at 6:57 AM
    #8403
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I think I notice the gear number '4' on the dash console whenever I shift over to S. I can't recall if it's momentary or constant. But I'm pretty certain it defaults to 4th gear.
  4. Jan 23, 2018 at 6:57 AM
    #8404
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    If it was a "sport/shift" mode, I would agree. That is the way most of the actual sport/shift mode selectors are to my knowledge.
    Tacoma, on the other hand, got a shift restriction mode which limits the highest gear allowed to that which is selected. If Tacos defaulted to current gear then if you engage it at a stand still it would never leave 1st, which is not at all what Toyota was going for it seems.
    I am one that agrees that IF @OVTune can make this a true sport mode holding the gear it that is selected it would be great. IT could assist crawling/towing/road trips/.... He did point out at one time that doing so MAY cause issues, I can not recall what all the possible drawbacks he saw.
  5. Jan 23, 2018 at 7:01 AM
    #8405
    RushT
    North Texas
    I for one, prefer the 'top available gear' mode vs. a sport mode. I have my 'other' car for sport mode. My truck should drive well and 'pull crap' when I need it to. Really, the top gear limit is pretty smart in my mind. It just shows you that the gearing isn't quite what it should be when 4th is the default. I wish 5th was the default. Perhaps @OVTune could make the default a dealer's choice in the tune. Something you selected when you flash.
    dingel5 likes this.
  6. Jan 23, 2018 at 8:01 AM
    #8406
    dingel5
    dingel5 Mocphus
    Paul
    P Town, California
    I agree. Perhaps it could drop down by one gear and you could assist it lower if needed but 6th to 4th is too harsh IMHO.
  7. Jan 23, 2018 at 8:24 AM
    #8407
    RushT
    North Texas
    That's not a bad idea either... but I'm thinking it through: 65mph on the highway, with a load in the back and a slight grade coming up. Do I go ahead and preemptively shift to S, thus dropping a gear. Or do I let it try to hold the gear and then get stuck when it downshifts by itself.... then to keep it there I have to go to S thus dropping another gear. In these situations it's good to know your truck and what it will and won't do.
    dingel5[QUOTED] likes this.
  8. Jan 23, 2018 at 8:30 AM
    #8408
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    bshammer0 likes this.
  9. Jan 23, 2018 at 10:31 AM
    #8409
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    When using S mode it mostly defaults to 4, but have occasionally seen it go to 3. Never seen it go to 5.
  10. Jan 23, 2018 at 11:33 AM
    #8410
    dingel5
    dingel5 Mocphus
    Paul
    P Town, California
    Never have seen it go to 5th gear. Seems that the preset gear is 4th unless you are going too slow for 4th.
  11. Jan 23, 2018 at 11:59 AM
    #8411
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    I have never seen it go into 5th when go to S mode, but the manual states the following:
    The initial shift range in S mode is set automatically to 5 or 4 according
    to vehicle speed. However, the initial shift range may be set to 3 if
    the AI-SHIFT has operated while the shift lever was in the D position.
    Also this:
    Selecting shift ranges using S mode restricts the upper limit of the possible
    gear ranges, controls engine braking forces, and prevents unnecessary
    upshifting.
  12. Jan 23, 2018 at 1:31 PM
    #8412
    sig916
    sig916 Well-Known Member
    Hmm, i use s mode a lot and never seen it go to 3.
  13. Jan 23, 2018 at 2:13 PM
    #8413
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    I've seen it default to 3 if, say I'm in D but going down a mountain and throw it into S and it will (often downshift) to 3rd. Rare I've seen it though. Normally 3 and perhaps it would shift to 5th if going fast enough but I've never tried shifting it over at higher speeds for fear of dropping to 4th going 80mph :)
  14. Jan 23, 2018 at 4:40 PM
    #8414
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    I'll be sending out a bunch of stuff later this evening, flu is kicking my ass
    riz_atx, bshammer0, taco 16 and 3 others like this.
  15. Jan 23, 2018 at 5:50 PM
    #8415
    DakoTaco
    DakoTaco Well-Known Member
    North Coast
    2016 MGM OR Tacoma
    Avid front bumper guard OVtune HPS Intake Tube Meso designs counting
    Sorry to hear about the flu, battled it myself. Cough hangs on for a week or 2,sucks.
    Kilokato and Lt_Dan like this.
  16. Jan 23, 2018 at 6:08 PM
    #8416
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Same had flue for 2weeks and cough for 1month. Sucks!
    Kilokato and DakoTaco like this.
  17. Jan 24, 2018 at 9:27 AM
    #8417
    dingel5
    dingel5 Mocphus
    Paul
    P Town, California
    Do not like!!! This flu is the worst ever! It comes back again and again. It’s enemies are fluid and rest. And perhaps a little bit of alcohol. Get tons.
    MOC221_ likes this.
  18. Jan 25, 2018 at 4:29 AM
    #8418
    sundogbrew
    sundogbrew Well-Known Member
    Joe
    2016 Blue TRD OR Double Cab
    So I did my upgrade last night. It took like 5 or 6 times before it completed. Kept giving me an ugly error about not turning off my truck for fear of permanent damage. I had to keep trying and quitting the program and restarting it. Did this happen to anyone else? If so, does it happen each time you re-flash it?
  19. Jan 25, 2018 at 5:06 AM
    #8419
    bshammer0
    Brandon
    Nashville, TN
    This happened to me some as well - may try a different USB cable, that seems to have worked for me
  20. Jan 25, 2018 at 5:36 AM
    #8420
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    Never had an issue, pcmflash isn't exactly the most literate of applications but it works just fine.
    speedtre and bshammer0 like this.
Thread Status:
