Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jun 29, 2017 at 10:18 PM
    #901
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    https://www.dz-custom-innovations.com/products/shiftsense-pro
    "ShiftSense Pro is a plug-and-play solution which requires no modifications to the OEM programming, instrumentation, or the ECU. It is enabled and operates automatically when the gear-selector is placed in the sequential-shift "S" mode."
    All from that site
  2. Jun 29, 2017 at 10:21 PM
    #902
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    @OVTune i didn't get any instructions! Order #1843
    riz_atx likes this.
  3. Jun 29, 2017 at 10:22 PM
    #903
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    @OVTune I am the Utah guy what is the other data you will need from me?
  4. Jun 29, 2017 at 10:22 PM
    #904
    rnicholls
    rnicholls Well-Known Member
    2016 TRD OR DCLB
    I've owned the shiftsense since release. Tune is much more useful so I ordered it but I'm debating what to do with my shiftsense. Sounds like it may be useless.
    Dylon gave a fair description of what it does. Basically an add on that helps hold gears longer and shift better based on obd data. Here's a link to a graph for the shifts.
  5. Jun 29, 2017 at 10:26 PM
    #905
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    just some engine data, logs for load at higher elevation. since load is greatly affected, the tune will need adjusted
    editing**
    we can most likely do what it does but in D mode, there are many many mapped shift points in D mode, but not so much in S, although we can adjust S mode map points as well.
    in the future we may look into doing what we do on lexus transmissions,
    riz_atx and dYL0n like this.
  6. Jun 29, 2017 at 10:27 PM
    #906
    Glenn_R
    Glenn
    got it.
  7. Jun 29, 2017 at 10:29 PM
    #907
    dYL0n
    Dyl0n
    New Orleans, LA
    This is why I cancelled my shiftsense order. Props to the guy who came up with it on here.
    But
    I'd like to keep my "manual" functions available, while the OV tune gets the shift points correct while in "drive"
    riz_atx and Oldman808 like this.
  8. Jun 29, 2017 at 10:49 PM
    #908
    rnicholls
    2016 TRD OR DCLB
    So no use in keeping it around then I suppose :annoyed:
  9. Jun 29, 2017 at 10:52 PM
    #909
    Jrobb
    Jrobb Well-Known Member
    Jon
    SF Bay Area
    2017 Double Cab Lb SR5 Magnetic Grey Metallic
    I ordered the Shift Sense Pro but have not installed it yet...maybe tomorrow if it shows up.
    You can cancel the Shift sense at any time by manually shifting up or down in S mode. It requires a shift back to Drive then into S below 65mph to re-enable the Shift Sense. So you CAN have manual shifting whenever you want. But from the sounds of the OV tune, I agree Shift Sense Pro may be not necessary as OV can address the shifting via the tune and you get more useable power.
    From DZ Custom's FAQ:
    How do I turn-on/engage the device?Short answer: Start the truck, place shift lever in "S" and go.
    More detailed answer: With the power switch turned on, ShiftSense™ Pro will power up and establish communication with the OBD system automatically as soon as the vehicle is turned on or started. The power switch may be left on at all times if desired because the unit obtains power from the vehicle only when the key is ON. Two beeps are heard when the device has established communication with OBD and is ready for driving. This will occur within 1-2 seconds after turning the vehicle on or powering on the device. ShiftSense™ Pro remains totally inactive until the operator places the vehicle in the Sequential/Sport-mode "S" with the shift lever. When shifted to "S", the device will engage immediately and begin automatic control of all shifting. A single beep will be heard when the unit engaged successfully. The vehicle speed must be less than 65 mph to allow the unit to initially engage. If the device is ever cancelled, it can be re-engaged by shifting back to Drive "D", and back into Sequential "S".
    How do I cancel the control if I want to drive with the OEM manual sequential-shift mode?
    Simply make an S+ or S- shift by hand. At this point, the system cancels, provides an alarm, and reverts back to manual control. The device will stand-by and remain inactive until it is intentionally re-engaged by the operator (moving the lever into drive, and back to Sequential "S").
    Nice to have both options and both at reasonable prices.
    J
  10. Jun 29, 2017 at 10:59 PM
    #910
    BREAK
    BREAK Well-Known Member
    Washington
    2016 TRDOR LB
    BFG KO2 265/75R16 Icon Dynamics 2.0 Front Coilovers and rear shocks. Rear AAL Borla Catback exhaust Afe momentum CAI
    URD sells a dummy plug that keeps the O2 Sensor from tripping the CEL. I used it on my 09 when I installed the Doug Thorley LT headers. Anyone know if they are compatible with the 3rd Gen?
  11. Jun 29, 2017 at 11:31 PM
    #911
    turbosmitty
    turbosmitty Well-Known Member
    Vegas
    2017 Tacoma TRD OR
    Sub'd
    outlawtacoma and Swiftks like this.
  12. Jun 29, 2017 at 11:34 PM
    #912
    speedy112790
    speedy112790 Well-Known Member
    Stephen
    2016 Tacoma SR5 4x4 DC TSS LB
    I have the Shift Sense it helps a lot... I could see this helping the tune out even more by looking at that graph. it would keep it in the power range better..
  13. Jun 29, 2017 at 11:42 PM
    #913
    Swiftks
    Swiftks Well-Known Member
    Spring, TX
    2016 TRD OR
    Bilstein 6112 (front) Bilstein 5160 (rear) Headstrong Progressive AAL ShiftSense Pro SumoSprings BakFlip F1 Tonneau Cover BAMF Grille aFe intake w/ scoop Custom Exhaust - URD Y-Pipe, Vibrant Ultra Quite Resonator & MagnaFlow Muffler 4Runner TRD Pro 17" Wheels Wrangler DuraTracs - 265/70R-17 Redline Hood Struts OPT7 LED Headlights (Highs & Lows) Baja Designs Squadron Pro Fog Lights LED Interior Lights Total Chaos Bed Stiffeners TRD Pro Skid Plate TRD Pro Tail Lights TRD Pro Shift Knob @CBoy808 Custom Bedside Decals FormulaOne Pinnacle Window Tint OEM Tacoma Bed Mat OEM Tacoma All Weather Floor Mats Fumoto Valve Amsoil Fluids
    Power extractors would be kick ass, just keep in mind when paired with the spec u and/or URD y-pipe, you'll be running no cats at all.... Which would definitely increase the exhaust flow. I have just their y-pipe with a custom exhaust, and I could tell an increase in flow, just from removing the rear set of cats.
    Also, technically with no cats, you'd be illegal, emissions testing aside... I know, I know, I don't really care either. Have to pass emissions here in Houston area to get registration though, otherwise I'd already have ordered them.
    Side note:. You can still pass a emissions test with just the rear set of cats removed.
    Only will throw a CEL with the front cats removed; i.e. the power extractors Installed. No CELs with y-pipe and/or spec u.
    ^^^This^^^
    ^^^And This^^^
    Don't need it for the spec u exhaust or y-pipe. May work when paired with the power extractors... Don't know, no one on here has bought them yet, probably due to the reasons mentioned above.
    su.b.rat likes this.
  14. Jun 29, 2017 at 11:43 PM
    #914
    sig916
    sig916 Well-Known Member
    Its all in your head about the shift sense. Leave that in the other thread and lets concentrate on OV TUNE!
    dYL0n likes this.
  15. Jun 30, 2017 at 12:07 AM
    #915
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    By exhaust do you mean muffler swap to something more free flowing or a whole catback system?
  16. Jun 30, 2017 at 12:17 AM
    #916
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    So I can remove my rear cats and no have a check engine light?
  17. Jun 30, 2017 at 1:28 AM
    #917
    Rackness
    Rackness Well-Known Member
    Maryland
    17' Tacoma
    Working on it.
    Order placed #1851. TRD Pro. I am running the trd exhaust. I know it is nothing like the URD set up it should breath a little bit better than stock. I am looking forward to the future development and product support.
  18. Jun 30, 2017 at 4:20 AM
    #918
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    As of about a month ago they didn't work with the 3rd gens
  19. Jun 30, 2017 at 4:39 AM
    #919
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    @OVTune I haven't seen this topic covered yet but were the upgraded tire size and weight accounted for in the tune? I know yall deal alot in tuner cars but trucks have few different modifications to deal or tune in parameters. For instance I run E rated 285/75/16 KO2 with a 59 lbs/tire with FN wheels at 18 lbs/ rim some drivers run mid-high 20's on wheel size and/or other rated tire sizes. Was all that extra rotating mass and tire diameter change taken into account? Will your tune first fix the speedometer to help correct the gear shifts in automatic? Second I assume when we take order of a tune we will have to fill out the modifications of tire diameter, weight and gears to get proper tunes to correct the gear shifts in automatic?
    For me I see this tune for my future modification of upgrading to 315/75/16 (35") tires and help manage the drive and hold off on getting 4.88 gears for awhile. If I can get the truck to stay in gears longer I can keep in the power range to keep pushing heavier tires with out it trying to shift every 10 secs to keep it in a higher gear. Also looking for better throttle response that should be fun but bad on the wallet. :)
  20. Jun 30, 2017 at 4:49 AM
    #920
    nm4553
    nm4553 You had me at "Meat Tornado"
    Nick
    NEPA
    2017 DCSB TRD Sport
    SCS Stealth 6 Matte Bronze on Toyo Open Country 265/70R17, Fox 2.5 Coilovers, Bilstien 6150 w/ Remote Resi, Dakar Leaf Pack, Wheeler's Bumpstop, OVTuned
    Has the warranty issue been answered? Can we reflash the ECU without a counter being tripped before heading to the dealer? I know I saw this answered by @OVTune in the earlier pages but this thread has gotten lit AF.
Thread Status:
