Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Feb 16, 2018 at 5:35 AM
    #9221
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    go2cnavy, Chipi3s and 2016trdtacoma like this.
  2. Feb 16, 2018 at 5:45 AM
    #9222
    DavidM310
    DavidM310 Well-Known Member
    Temple, Texas
    2017 Tacoma/2015 4Runner/2015 IS250
    His truck will be on the next SpaceX launch!
  3. Feb 16, 2018 at 6:37 AM
    #9223
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    C-137??
    WUBALUBBADUB DUB!
    Chipi3s[QUOTED] and bshammer0 like this.
  4. Feb 16, 2018 at 6:39 AM
    #9224
    MOC221_
    Frank
    :rofl::rofl::rofl::rofl::rofl::rofl: :thumbsup:
    Chipi3s likes this.
  5. Feb 16, 2018 at 7:08 AM
    #9225
    ridge
    ridge One Gear; No Fear
    North Carolina
    '17 TRD Sport DCSB M6
    MESO!
    My search here hasn't revealed much in the signal:noise ratio...
    2017 M6, w/ V6; will this tune fix the dead throttle in low gears at lower RPMs, and when downshifting to pass on the interstate, etc?
    The only loathesome thing about this truck is the lack of throttle/engine response when downshifting the manual... hell, even when just shifting normally. It's almost like the throttle is on a coffee break when pressed
    Typical driving:
    1st gear - smooth off the clutch release, and truck accelerates as expected (maybe a bit choppy)
    shift
    2nd gear - noticeable pause from the engine response-to-throttle input... engine begins to rev up to expected acceleration after some seconds have transpired, then truck accelerates as expected.
    shift
    3rd~6th gears - Occasional pause from engine response-to-throttle input, but also sometimes a smooth acceleration and pull to shift point of next gear.
    Downshifting to make a pass.... mixed bag... sometimes have to d/s two gears to get an expected response of clutch engagement~truck acceleration.
    This is the first manual transmission vehicle I've had where the throttle/fuel/engine are controlled electronically and not by physical connection via cables, etc... so I'm more than a bit frustrated and disappointed with the engine~throttle response.
    Growing up as a gearhead/tuner in the 80's and 90's was all prior to OBD, ECU tuning, and throttle-by-wire; so I'm trying to be patient and learn what my options are to bring my Taco up to expectations.
    In my experience, when I pull a downshift to a lower gear and press the throttle; it should equal an immediate acceleration and response from the vehicle. This... pause I'm getting from the Tacoma's engine/throttle is infuriating at times; ESPECIALLY when I need to get past a slower moving vehicle, or egress from a driver-gone-stupid on the interstate.
    Thanks to OVTune and the beta testers for the work to fix Toyota's problem.
    MOC221_ and SouthtownTaco like this.
  6. Feb 16, 2018 at 7:33 AM
    #9226
    su.b.rat
    su.b.rat broken truck
    yes, although the definition of "fix" is somewhat subjective. it's why i sought out a tune in the first place.
    MOC221_ and ridge[QUOTED] like this.
  7. Feb 16, 2018 at 7:36 AM
    #9227
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
  8. Feb 16, 2018 at 7:37 AM
    #9228
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Okay here is a short video I did yesterday of cruise control. First time ever using cruise control in this truck! lol
    it was very steady and was able to maintain 6th for a majority of the drive, it will downshift if it has to on a big hill, but steady inclines (tried to show you in the video) it will maintain 6th.
    Ignore the MPG average on my screen, I was flooring it a lot, but my highway drive yesterday was the best MPG my truck has ever recorded in it's short life.
    on inclines MPG goes down to about 13-14, but flat ground was easily 20+
    This was tested on the highway with several small and a few steep inclines
    downshifted only 2 times on high grades. A few times in the video I show you I'm going uphill in 6th
    Overall it maintains 6th gear in cruise beautifully.
    I would like to get a few people to test this and the changes to S mode (full lock status always) which is so damn fun but kills MPG
    I'll show you guys a video of S-Mode vs stock S-mode
    dingel5, dskakie, hbaade and 10 others like this.
  9. Feb 16, 2018 at 7:42 AM
    #9229
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Completely independent of what's being shown in the vid but am I the only one who always laughs at how very much the turn by turn nav voice sounds like the announcements at airports? Lol "Please proceed to Gate A-4. Now boarding Group B." Smh
    Sweet vid
    ihatemytruck likes this.
  10. Feb 16, 2018 at 7:44 AM
    #9230
    Shellshock
    Iowa
    Damn that looks to address every compliant I had with my auto. That's awesome
    How much longer til we get the MT files? :spy:
    2016trdtacoma and mZiggy like this.
  11. Feb 16, 2018 at 8:08 AM
    #9231
    bshammer0
    Brandon
    Nashville, TN
    S-mode full lock sounds interesting but also sounds like could cause excessive heat under load? In any case, this sounds fun. i know it's not this easy, but it would be awesome if S-mode still behaved similar to stock (with your torque changes of course) but then ECT in S-mode triggered the full lock status when we want to have fun with it ;)
    Also really interested to hear your explanation on how you've been able to achieve the shifting progress D mode where it sounds you've been able to limit when it can upshift to overdrive at lower speeds and also prevent it from re-learning how to revert. I know lots are interested in this detail when you have the time!
    Great progress - hope you landed a big deal w/ the alternative fuels company yesterday!
    sig916 and trdsilver like this.
  12. Feb 16, 2018 at 8:13 AM
    #9232
    OVTune
    OVTune
    I have figured out how to control everything in D mode and will have an explanation on it today once I have some free time. All driving on the video was D mode. I now know how to make the transmission do whatever I want, go straight to 6th, limit to 4th gear until below certain speeds, lock, unlock, etc. I've also figured out how to manipulate JUST 6th gear.
    itsmermf, dingel5, mbcnya and 13 others like this.
  13. Feb 16, 2018 at 8:17 AM
    #9233
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Sooo, what about ECT mode?
    CTRL+C , CTRL+V the settings? :D
    BlkTaco47 likes this.
  14. Feb 16, 2018 at 8:18 AM
    #9234
    sundogbrew
    sundogbrew Well-Known Member
    Joe
    2016 Blue TRD OR Double Cab
    OMG, when I turn on cruise control it sounds like I am racing. 6th, 4th, 5th, 6th, 4th, 5th, 4th, 5th, 6th... And thats the first 5 miles. Even when it does shift in the video it seems very reasonable and smooth. I have always hated that on the highway you move over to pass, give it a little bit of gas and it sounds and acts like you are on a two lane road following someone slow and up ahead it looks like you might have enough room to pass and you floor it and it sounds like you are taking off. THAT video, that is what I want!!!!!!!
  15. Feb 16, 2018 at 8:22 AM
    #9235
    RC84
    RC84 Well-Known Member
    3G Double Cab TRD OR
    SCS F5 - 17x8.5 Matte Gunmetal Cooper ST Maxx - 255.80.17
    Hey Mat -
    Can you give us your opinion on which bolt on upgrades are worth while, in regards to performance gains?
    General consensus seems to be that "cold air intakes" add very little to nothing, but your comment on the full exhaust is intriguing, to say the least.
    sig916 likes this.
  16. Feb 16, 2018 at 8:23 AM
    #9236
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Cold air intake is a minor change, FULL exhaust system dramatically changes the air to fuel ratio and requires a tune to see any performance gains.
    dYL0n likes this.
  17. Feb 16, 2018 at 8:27 AM
    #9237
    RC84
    So then I ask, will any iteration of the tunes be properly tuned for a full exhaust? I would assume, yes...otherwise, Mat would not have made his previous statement (250 hp...potentially).
    Chipi3s[QUOTED] likes this.
  18. Feb 16, 2018 at 8:27 AM
    #9238
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Wow! This looks awesome! If you need testers on Cruise Control, I can help. I dont use S mode very often, but use cruise control on the regular. Living in the middle of Texas, it takes 6 hours to get to anywhere great to camp/wheel/overland. Heading on the next adventure to Ouachita National Forest in Arkansas in 1 week and cruise will be super helpful for the 7 hour drive there and back.
    THIS! LOL. Is it possible to fall in love with a tune before we even get it? Im glad its called Cupid! LOL
    ebbs15 likes this.
  19. Feb 16, 2018 at 8:28 AM
    #9239
    ThatOneTaco
    ThatOneTaco Well-Known Member
    CA, Bay Area
    2017 DCSB 4X4 TRD Off-Road
    We still looking at release today or tomorrow Mat?
  20. Feb 16, 2018 at 8:29 AM
    #9240
    OVTune
    OVTune
    MT expected release this evening.
    Livinserene, dskakie, iPaint and 10 others like this.
Thread Status:
