Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Feb 22, 2018 at 2:29 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
  2. Feb 22, 2018 at 2:32 PM
    DiabloTRD
    DiabloTRD Well-Known Member
    Clearwater, FL
    2017 DCSB TRD Sport (OVT)
    OVT, Spidertrax 1.25, K&N CAI, Dynomax Super Turbo exhaust, Clazzio seat covers
    I like power.....power is good
    Thanks again
    riz_atx likes this.
  3. Feb 22, 2018 at 2:47 PM
    speedtre
    speedtre Well-Known Member
    DirtySouth
    '17 DCLB TRD OR AT 4x4
    Everyone who is (or will be) running the tune on an AT should watch this short video (if they don't already understand how a TC works) so they can understand what Mat is doing when he changes when/how the TC locks up...
  4. Feb 22, 2018 at 3:08 PM
    FLJoe
    FLJoe Well-Known Member
    Joe
    Wellington, FL
    16 Blazing Blue Taco Limited AT
    OV Tuned
    Technically you’d want a looser converter, the slip would allow you to get into the higher RPMs faster, which would make power faster. Unless these converters are stalling at a really high RPM because they have a lockup converter? It’s been a while, so correct me if I’m wrong.
  5. Feb 22, 2018 at 3:20 PM
    bshammer0
    Brandon
    Nashville, TN
    Correct, and the man can comment here when he has time to come up for air after the AT release, but stock on these trucks it seems it's generally all or nothing and likely is partly incorrectly blamed for people's perceived grievances with the transmission. full lock in S-mode would seem to give you the most response though. I can feel mine go from stall to lock when I hit the gas but there is no slip I can detect like in pretty much any other AT I've had in recent memory. Sounds like he's solving it from both angles - beautiful AT shifting when in D with the half-lock on the lower gears which should lead to a very smooth transition, with the full lock option in S-mode which would be pure fun. RPMs won't ramp as fast probably, but every bit of power it's generating is being used to scoot!
  6. Feb 22, 2018 at 3:28 PM
    DiabloTRD
    Clearwater, FL
    Does S mode shift the same as stock? Say you’re in S4, does it still shift automatically up to 4th? Or do you have to shift thru all the gears manually? Sorry if it’s confusing
  7. Feb 22, 2018 at 3:31 PM
    bshammer0
    Brandon
    Nashville, TN
    I have no clue how S-mode is going to work in 1.03... stock it is just a gear limiter and it does automatically shift up through the gears up to the top gear you have selected. For the last several weeks now I've been driving exclusively in S mode. If I'm around down and driving under 50 I keep it in S-4, then on the highway depending on speed I'll ramp it up to 5/6 to keep it in the 2500 rpm range
    Edit: and the other benefit stock is that using S-mode disables the transmission learning features so it will generally shift the same way every time for better or worse. but now it sounds like he's achieved that benefit in D while also making S-mode more exciting
  8. Feb 22, 2018 at 3:58 PM
    redaccount36
    redaccount36 Well-Known Member
    2017 DCSB Silver Limited
    Basically I've built up the anticipation in my mind so much without knowing anything really about all the techy stuff he's talking about. So at this point that if the truck doesn't go from 0 to 88mph in 2.0 seconds with 60mpg, then have the torque converter transfer energy to the flux capacitor, have the valve timing go on full lock to 1980s Hill Valley, and send me careening into the past to see Marty's black Toyota truck I'll be disappointed.
    taco 16, treimche, ben dover and 9 others like this.
  9. Feb 22, 2018 at 4:01 PM
    2017TRDpro
    2017TRDpro Well-Known Member
    2017 TRD Pro
    It already does all of that with 1.02 :D
  10. Feb 22, 2018 at 4:07 PM
    dinglehoser
    dinglehoser Well-Known Member
    2017 TRD OR AC SW JDM YO
    Speaking of which, I'm still hoping someone sells a kit to turn the 3rd gen into this:
    https://www.roadandtrack.com/car-culture/entertainment/news/a27109/toyota-tacoma-marty-mcfly/
  11. Feb 22, 2018 at 4:24 PM
    WNYTACO
    WNYTACO Well-Known Member
    2016 Gray TRD OffRoad DC
    2 Gallon Airtank with Firestone AirRites
    Don’t get me wrong I am excited for 1.03 but I do have a little concern in my mind as I see some of the MT guys are not as happy as they first were. I guess only time will tell!
    bshammer0 likes this.
  12. Feb 22, 2018 at 4:31 PM
    su.b.rat
    su.b.rat broken truck
    some of us are looking at a need for some refinement with light throttle at low rpm. the changes are huge and great, no complaints, just further development. speaking for myself of course. i think the MT guys know Mat is committed so we're patient about it... but all of us want another Mat or maybe several more..
    MOC221_ and WNYTACO[QUOTED] like this.
  13. Feb 22, 2018 at 4:33 PM
    redaccount36
    Meh, they're MT guys. They won't be happy till they have a shifter inside the truck to control the timing directly.
    Chipi3s, dYL0n and WNYTACO[QUOTED] like this.
  14. Feb 22, 2018 at 4:45 PM
    Shellshock
    Iowa
    Mine was acting a little strange at first but after some more miles it has straightened out.
    WNYTACO[QUOTED] likes this.
  15. Feb 22, 2018 at 4:49 PM
    redaccount36
    I had thought of doing this same thing, only using "OVTune Kenobi".
    bshammer0[QUOTED] likes this.
  16. Feb 22, 2018 at 4:52 PM
    su.b.rat
    i can definitely say the same and I'm happy about it. but this little thing i just noticed. it's a detail that i wouldn't have found unless i was stuck in the jam. no big deal but needs fixing anyway.
  17. Feb 22, 2018 at 4:56 PM
    Shellshock
    Iowa
    Yup it could use a little refinement still but there’s still no way I flash back to stock lol I’m content until MT dyno day
    su.b.rat[QUOTED] likes this.
  18. Feb 22, 2018 at 6:06 PM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Im betting the page refresh count for this thread is astronomical right now
    bshammer0 and redaccount36 like this.
  19. Feb 22, 2018 at 6:12 PM
    redaccount36
    dYL0n, riz_atx[QUOTED] and jholc21 like this.
  20. Feb 22, 2018 at 6:32 PM
    ThatOneTaco
    ThatOneTaco Well-Known Member
    CA, Bay Area
    2017 DCSB 4X4 TRD Off-Road
    I think I broke my keyboard from refreshing so much....
    dYL0n, riz_atx and redaccount36 like this.
Thread Status:
