Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Mar 7, 2018 at 6:30 PM
    Yeeyo
    Yeeyo Well-Known Member
    Rodrigo
    Central Cost California
    2017 TRD DCSB Sport 4x4 OVTune
    I’m right handed, but my dongle fits easily in my left hand
  2. Mar 7, 2018 at 6:33 PM
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    Im a lefty, and my dongle fits well in both hands.
  3. Mar 7, 2018 at 6:37 PM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    I had no problems although the instructions are not Ikea-like :)
    My kids 21, 18, and 16 wouldn't be able to follow the instructions...neither would my wife or mother.
    The below notes are not official and are not meant to replace OVTune's instructions, but rather help you navigate some of the potentially confusing order of operations. It's so much easier than it used to be, but the instruction haven't caught up yet.
    Please pay careful attention to notes/warnings in the official instructions.
    *** For those of you who have successfully installed the tune, please review my post for accuracy if you have time ***
    With the new DONGLE pre registered it's pretty simple.
    DONGLE
    1. Download and Install all drivers and support software from flash manager. DO NOT plug the dongle until you've done so,
    2. Launch PCMFlash. The new dongles will have a serial number.
    3. If Mat provided your license key with your shipment:
    a. Click 'Settings' and paste the license key.
    b. Click 'Activate'
    c. Click 'Ok'
    d. Exit PCMFlash
    e. Relaunch PCM Flash
    4. If not, then email the serial number of the dongle to Mat and wait for the license key. Once received, complete step 3.
    Identifying and Flashing ECU - Truck must be ON, but engine off (not running) – NOT IN ACCESSORY MODE! [Push-button start = push it two times]
    5. Make sure DONGLE is inserted in laptop
    6. Hook up OBDII cable to truck (OBDII Port) and laptop second USB port.
    7. Launch PCMFlash.
    8. From the drop-down menu, select the 'corresponding Toyota ECU' as per Mat's directions/pictures.
    9. Click 'Identification' and note last 5 digits of the calibration file (i.e 04B03).
    10. Click on the three dots (...) and load the tune file for your ECU that you downloaded with Flash Manager.
    11. Click 'write' and wait.
    12. Once successful Turn the truck off.
    For the Transmission (TCU) flash, turn the truck back on as you did for the Identifying and Flashing ECU process.
    The following steps are nearly identical to the ECU flash except #8 and #10
    13. Launch PCMFlash
    14. From the drop-down menu, select the 'corresponding Toyota TCU' as per Mat's directions/pictures.
    15. Click on the three dots '(...)' and load the tune file for your TCU that you downloaded with Flash Manager.
    16. Click 'write' and wait.
    17. Once successful Turn the truck off.
    18. Start truck and let it idle per Mat's instructions.
    19. GO DRIVE and try not to get a ticket.
    20. Come back here and post your review.
    EDITED to add the following thanks to @bshammer0
    when you get to the WRITE step in the process (in steps 11 and 16)...
    You will see what looks like 2 error messages
    1. Confirms your battery voltage - assuming it’s not low, you can click OK. This is a good reminder to make sure ALL electronics of any sort are OFF.
    2. “error” message pops up saying the checksum was corrected. This is normal and nothing to worry about.
    3. If you get an error because the process didn’t complete successfully just leave everything on the way it is and retry - it will work. Don’t panic.
    Hope this helps.
  4. Mar 7, 2018 at 6:44 PM
    2016trdtacoma
    Trevor
    Utah
    Seems very well put together.
    Chipi3s likes this.
  5. Mar 7, 2018 at 6:53 PM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    None that I felt. No logs, just watched trans temps and misfire monitor all were good.
    tacomabro69 likes this.
  6. Mar 7, 2018 at 6:56 PM
    tacomabro69
    tacomabro69 Well-Known Member
    How long does it usually take @OVTune to send out license keys?
  7. Mar 7, 2018 at 6:58 PM
    PB FAB
    2017 SR DCSB 4x4 v6
    Excellent trailer brakes help a lot.
    go2cnavy[QUOTED] likes this.
  8. Mar 7, 2018 at 7:03 PM
    catastrofe
    catastrofe Well-Known Member
    Bob
    Montrose, CO
    2022 F350 Tremor
    Same here...still waiting for drop off at UPS. Something ain’t right
  9. Mar 7, 2018 at 7:04 PM
    2016trdtacoma
    Trevor
    Utah
    Depending on how busy he is, but I got mine in 2 days after I sent him my serial number.
  10. Mar 7, 2018 at 7:39 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Well done! The only thing I would call out for new folks is that when you get to the WRITE step in the process...
    Thanks for helping folks out with all this - and yes all get your reviews in once you’ve had a chance to test it out. Life is about to get a lot better for a new batch of donglers!
  11. Mar 7, 2018 at 7:47 PM
    MacMedic
    MacMedic Well-Known Member
    2016 Black Tacoma TRD Sport
    At what point do we make a copy of the stock load .. in case we want to return to stock??
    bshammer0[QUOTED] likes this.
  12. Mar 7, 2018 at 7:54 PM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Its already in the flash manager
    2016trdtacoma likes this.
  13. Mar 7, 2018 at 7:54 PM
    Shellshock
    Iowa
    You can download it with flash manager. Or you can click the read button IN PCM before you flash and save it.
  14. Mar 7, 2018 at 7:57 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    If I am not mistaken, Matt has the stock versions of each ECU revision available on the flash manager.
    ETA Beat twice
    Chipi3s and bshammer0 like this.
  15. Mar 7, 2018 at 8:29 PM
    pditty
    pditty Active Member
    Pat
    2016 TRD Sport
    Hello, does anybody know if running windows 10 on a Mac using parallels will work to install the tune? Would rather go this route vs buying a new PC.
    thx
  16. Mar 7, 2018 at 8:31 PM
    go2cnavy
    Shellshock and 2016trdtacoma like this.
  17. Mar 7, 2018 at 8:35 PM
    2016trdtacoma
    Trevor
    Utah
    Yes, but I used boot camp. Worked perfectly.
    pditty[QUOTED] likes this.
  18. Mar 7, 2018 at 8:38 PM
    go2cnavy
    LMGTFY
    bshammer0 and Saeros like this.
  19. Mar 7, 2018 at 8:42 PM
    go2cnavy
    Sorry. You're right. Better solution is to generate a FAQ.
    bshammer0 likes this.
  20. Mar 7, 2018 at 9:35 PM
    TWTaco
    TWTaco Well-Known Member
    Dave
    Question for you Tech guys. Can i start the the down load process to get the Dongle serial # on my desktop PC to get it emailed off to OVtune while i wait for my laptop to be delivered next week? Then run the whole process with my laptop when i get it? So i have the License key ready when laptop arrives.
    Big geek likes this.
Thread Status:
