Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Mar 8, 2018 at 11:37 AM
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    I used Win7 64 bit, so I doubt it is your OS
  2. Mar 8, 2018 at 11:38 AM
    Mike O
    Mike O Well-Known Member
    2016 TRD OR MGM Access Premium LB
    Mobtown Sliders, SSO Slimline bumper, Baja Amber lightbar & fogs, Sumo bump stops
    Normally, I'd agree. :amen:
    Maybe it is too much trouble for someone trying to sell me something for $700 to put a link in their signature. Maybe, with all the other communication issues (changes in process, not answering questions, etc.) it that means something about how organized they are/are not from day to day. Maybe it doesn't. But if you tell me you are to busy to be organized, I'll tell you that you are too busy for my business.
    Matt is obviously a very smart guy. Why he doesn't think it necessary to be organized from the start does concern me. He wants to avoid the same question over and over, but doesn't do anything to mitigate it. I understand he can't (or doesn't want) to stop and spec an app. All he really has to do is update the first post - something various vendors have done here. He could even cut/paste updated/procs that purchasers have posted.
    I'll stop :deadhorse: unless someone responds directly.
    BTW - I appreciate Matt working with the community to develop the tune. Really, I do. Great for all us. I appreciate that he can't fix a problem he can't recreate (tip in/surge). Been there, done that. But a simple statement such as, "If I can re-create it, I'll fix it or provide an option." would probably help. He really didn't respond at all for a bit. He has now, and is apparently actively trying to re-create. That is good - now.
    He has alluded to doing tunes with a partner. He no longer does. What happens when someone so secretive gets in a vehicle accident or? No process, means none of us can help him very easily. Again, I want the Matt's tune. I believe in his ability. But there really is no reason that this situation has to exist. Check out other vendors here.
    My apologies to all for further cluttering this thread, but at close to 700 pages it does seem to matter much. I'm only responding to those quoting me or addressing me.
    And to Matt - GOOD WORK ON THE TUNE AND ALL THE BEST.
    ebbs15 likes this.
  3. Mar 8, 2018 at 11:49 AM
    PhogDog
    20 MGM Sport
    Maybe try downloading the zip directly.
    https://www.guardant.com/support/download/drivers/
  4. Mar 8, 2018 at 11:50 AM
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    He will make changes as needed. Sure, it may take a little time, but has he NOT done anything he said he would?
  5. Mar 8, 2018 at 11:58 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    that's probably the quirky torque converter stuff this truck does stock - and he has smoothed it out considerably. in retrospect I think we all have blamed the atkinson cycle for a lot of problems that aren't related to that.
    speedtre and 0uTkAsT[QUOTED] like this.
  6. Mar 8, 2018 at 12:04 PM
    BB2017
    BB2017 Well-Known Member
    So Cal
    2017 Tacoma TRD sport
    Maxtrac 4" spindles, old man emu medium leaf packs, Bilstein 5100 struts and extended length shocks, Mamba M13 17x9 -12mm offset wheels, 3/4" wheel spacers on rear wheels, BF Goodrich LT 265/70R17 KO2 tires, OV tune 1.04, Rough Country steps, Morimoto LED amber Fog Lights, Meso Customs Limited edition Ultimate LED turn signals.
    Same thing. I completely uninstalled the dongle from the computer, uninstalled and deleted the drivers, downloaded and installed the drivers from that link, and put the dongle in the USB port. The drivers fail to load. At this point I'm thinking it's this netbook. Maybe I'll find a friend with a laptop and try that. Thanks for the help though!
  7. Mar 8, 2018 at 12:22 PM
    PhogDog
    20 MGM Sport
    Sounds like torque converter lockup.
    iexc, speedtre and Slickwhenwet like this.
  8. Mar 8, 2018 at 12:27 PM
    PhogDog
    20 MGM Sport
    I believe it locks up for gas mileage.
    At least in my Chevelle, I can feel it lockup and the rpms drop a bit in overdrive. (Without changing the gear)
    ian2016 likes this.
  9. Mar 8, 2018 at 12:28 PM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    Because with the factory tune it is the only solution to add power and accelerate, or do a downshift to 2nd lol.
    PhogDog likes this.
  10. Mar 8, 2018 at 12:40 PM
    ToyTacoTruck
    ToyTacoTruck Well-Known Member
    Dave
    2017 MGM AC V6/AT/4x4
    Thanks for checking it out. I have stated before, this is not a 1.03 tune issue, have always had it stock and view it a minor quirk not a significant issue. I suspect it is more pronounced in colder temps at cold engine startup due to higher idle rpm combined with tight torque converter. I happen to notice at idle backing out of driveway - no throttle, truck moving at idle and will get rpm flare - and I suspect due to an accessory load (pump,alt,cmprsr,etc) triggering a throttle bump. Again, for me, not a big issue and its always been there. (((For me, if you can get the D to S mode to default to 5th rather than 4th would be a more appreciated tweak.)))
    Bridge4, 2016trdtacoma and perkj like this.
  11. Mar 8, 2018 at 12:43 PM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Do you drive a motorcycle? ;)
  12. Mar 8, 2018 at 1:09 PM
    Chipi3s
    San Diego
    There called manuals lol
    0uTkAsT[QUOTED] and bshammer0 like this.
  13. Mar 8, 2018 at 1:16 PM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    And dual clutch automatics
    0uTkAsT likes this.
  14. Mar 8, 2018 at 2:03 PM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    From what I've seen on this thread, he provides plenty of support.
    bshammer0 likes this.
  15. Mar 8, 2018 at 2:09 PM
    airsickbuffa1o
    airsickbuffa1o Well-Known Member
    Anthony
    2017 Silver TRD OR
    OVtuned 1.03
    OV has been working with the people on this forum to iron out the kinks, anytime there is an issue that many people are experiencing he is quick to remedy it. The tune is pretty much set it and forget it as well, so once it's flashed, it's pretty much done.
    To purchase, go to the orange virus tuning website. https://www.ovtuned.com/
    Chipi3s and bshammer0 like this.
  16. Mar 8, 2018 at 2:30 PM
    bshammer0
    Brandon
    Nashville, TN
    I think you may have nailed it on that one - its the rolling in 1st thing that I occasionally experience and it's not always when cold. It did it stock as well but is just more pronounced with the tune when it happens. I back out of my garage in the mornings and the rear of my garage has a slight incline so I have to give it a touch of throttle then off the pedal and on the brake to coast down my driveway on a hill. Have experienced the surging a bit when turning right out of my neighborhood but then again it hasn't done it the last couple of days so... Running pretty damn good though man. I seriously cannot imagine driving this truck without the tune
    dingel5, Chipi3s and MOC221_ like this.
  17. Mar 8, 2018 at 2:57 PM
    Lt_Dan
    Lt_Dan Well-Known Member
    Daniel
    Cincinnati OH
    2017 TRD OR 4x4 DCSB A/T Super White
    No problems with tip in? What times size do you have? Also, do you have a lift?
  18. Mar 8, 2018 at 2:59 PM
    bshammer0
    Brandon
    Nashville, TN
    I'm stock wrangler tires / OR wheels - the tip in was silghtly alarming within the first few drives after flashing but it has settled down considerably. Still think he's working on a softer version which I'll certainly try out but it's not as big of a deal as it could seem from these posts. Truck GOES, that's for sure.
    Chipi3s, DakoTaco and Lt_Dan[QUOTED] like this.
  19. Mar 8, 2018 at 3:06 PM
    Lt_Dan
    Daniel
    Cincinnati OH
    I'm also stock and have the same truck as you. I did feel the tip in when I first flashed, now it's smoother, but I don't thin it's the ECU settling or whatever, I think it's my brain calibrating to 1.03 and telling my foot to take it easy on take off.
  20. Mar 8, 2018 at 3:12 PM
    bshammer0
    Brandon
    Nashville, TN
    yep - I feel there is a bit of both going on though it could well be more related to ignition learning and idle stuff that indirectly affects the tip-in. it's still there in certain situations but most of it is learning I just need to touch the throttle to go. 30% gets me MOVING.
    Lt_Dan[QUOTED] and DakoTaco like this.
Thread Status:
