Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Mar 11, 2018 at 5:18 PM
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    shouldn't matter, I used pcm flash that says 1.1.83. what mattered was making sure i was using the latest flash manager.
    if you follow the steps in the instruction slowly and don't get ahead of yourself, you should be fine. I had a couple issues, but all of them were because I was too anxious and got a step or two ahead of the instructions.
  2. Mar 11, 2018 at 5:20 PM
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    don't give up... just start over and follow the steps deliberately. I had to do this to stop myself from being over anxious and having problems
    2016trdtacoma and TWTaco[QUOTED] like this.
  3. Mar 11, 2018 at 5:23 PM
    filbert
    filbert Well-Known Member
    Chicago
    2016 Tacoma TRD OR DCSB V6 MT
    I got my serial number this afternoon and installed it. I made a new video following the latest instructions so hopefully this is helpful to anyone who hasn't done it before.
    I've never done an ECU Flash before (but I had a piggyback ECU on my WRX STi). It took about 10 minutes for computer setup the first night and 15 minutes the next day for connecting and flashing the truck (due to a small delay from anti-virus).
    I did a quick 12 mile drive to the grocery store with a small highway detour and I like it so far, but I'll reserve full judgement until i get through a tank and try 91.
    https://youtu.be/0LRsGGzlpg8
  4. Mar 11, 2018 at 5:33 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Thanks for the advice, and yes there will be a shitload of data in the CSV file. I'm bringing my son (co-pilot) along to manipulate the record controls so that only a few seconds of data is captured right when I want it.
    Sounds easy, right?
    Lol
  5. Mar 11, 2018 at 5:45 PM
    MOC221_
    Frank
    Very well done sir :hattip:
  6. Mar 11, 2018 at 6:39 PM
    SpeySquatch
    2016 TRD OR DCSB
    Cool! Nice work. Now we just need one for an AT...if there is any difference.
  7. Mar 11, 2018 at 7:14 PM
    filbert
    Chicago
    My understanding is that is basically the same. On the auto after the ECU flash there is an extra step for the TCU (transmission) flash but it's basically the same, you just have to choose a different protocol as noted in the instructions.
  8. Mar 11, 2018 at 7:25 PM
    TWTaco
    TWTaco Well-Known Member
    Dave
    Well i got a little further! Got to the point of hooking up to the truck to flash , opened pcmflash, Message Windows cannot complete the extraction, destination file could not be created.
  9. Mar 11, 2018 at 7:27 PM
    TWTaco
    Dave
    Still nothing in the interface box. Well i think thats enough for tonight . Deleted all, start over tomorrow.
  10. Mar 11, 2018 at 7:32 PM
    TWTaco
    Dave
    Well shit started to delete then decided to retry it again and now the interface box has the J2534 tactrix in the box.That must be the issue. but now i got to go to dinner . Have to stop there.
  11. Mar 11, 2018 at 7:37 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    if you follow each step in order, and make sure you have everything installed (2 things.. the drivers) it should all work. A user posted a really really good video on the previous page that goes over every little step
    bshammer0 and TWTaco[QUOTED] like this.
  12. Mar 11, 2018 at 7:37 PM
    Gravex3400
    Gravex3400 Well-Known Member
    Jose
    Oceanside, CA
    2017 MGM Tacoma TRD Sport
    Thanks for this! Question though, I'm trying to do step 1-2 and every single time I plug in the dongle I don't get a serial number. I've tried multiple times and get the same result. All drivers have been installed already. Any help or advice?
  13. Mar 11, 2018 at 7:40 PM
    TWTaco
    Dave
    One of the drivers did not download,I will get it eventually !
    go2cnavy likes this.
  14. Mar 11, 2018 at 9:18 PM
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    If there are no updates for tunes in the pipe right now, might I ask what is?
  15. Mar 11, 2018 at 9:30 PM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Before running PCMFlash, did you insert the dongle?
    Download and install drivers. Insert dongle. Run PCMFlash.
  16. Mar 11, 2018 at 9:38 PM
    Gravex3400
    Jose
    Oceanside, CA
    Yes, I've followed those exact steps and I still get the "USB Dongle not accessible" where the serial # should be popping up. No idea what I'm doing wrong. I've uninstalled and deleted everything and started all over and keep getting the same results
  17. Mar 11, 2018 at 9:46 PM
    Tharris242
    Tharris242 Technically
    Houston, TX
    2017 TRDOR DCSB 4X4 A/T FP TO BL
    Solid Fold 2.0, Air Dam
    This is one of the issues that has kept me on the sideline watching. I'd like to be able to customize my shift points.
    I want the transmission to be in whatever gear gives the best MPG. It concerns me that almost everyone in this thread doesn't want it to shift into 6th, ever, unless they're going 70 mph or XX mph... OTOH you have most people in the manual thread bragging on how slow they can go in 6th now with the tune.
    I have zero problems with the stock 6th UPshift. It will not upshift into 6th unless you are very light on the throttle; but then, as you say, it is reluctant to downshift causing you to lose speed and perhaps requiring more aggressive throttle input risking a downshift to 4th (especially w/ CC). I think the transmission doesn't shift enough... that's its job. The 4th and 5th upshift conditions at light to medium throttle are stupid, though; and, actually produce inferior MPG to my active use of S mode (3, 4, 5, 6).
    I see some are reporting improved MPG, which is promising; but, it sounds like MPGs are being left on the table due to so many wanting to do a Pike's Peak climb in 6th.
    Chipi3s likes this.
  18. Mar 11, 2018 at 9:52 PM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    The manuals have 4.30 rear end gears at are 3.90. We at guys can’t use 6th that low in the rpm range, not enough gear.
  19. Mar 11, 2018 at 9:58 PM
    sig916
    sig916 Well-Known Member
    @OVTune, Can you throw a bone out? The tread is getting boring... :taco::taco::taco:
    iexc likes this.
  20. Mar 11, 2018 at 10:06 PM
    Tharris242
    Houston, TX
    Yeah, I know. It's just funny how diametrically opposed the discussion is between MT and AT.
    At steady speed on level ground at anything above 40mph, 6th is the gear to be in for mpg; but, as soon as you need to accel or climb with just a bit of throttle... it should downshift... but it doesn't.
Thread Status:
