Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Mar 14, 2018 at 5:47 AM
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    Not sure why you're quoting me?
    taco 16 and dYL0n like this.
  2. Mar 14, 2018 at 6:04 AM
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    Could have sworn that Mat said you had to have both or the truck wouldn't run, so you must have done both.
    but hell if it's that big a deal, re-flash ECU then TCU to be sure you don't fuck shit up.
  3. Mar 14, 2018 at 6:18 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    You flashed most of the tune, but you're not getting all of the benefits of the pressure changes and snappier shifting that are included on the TCU file.
    Should be able to just flash the TCU though if it were me i'd probably reflash both (ECU first) and let it idle for awhile to start fresh.
  4. Mar 14, 2018 at 6:38 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    Does it matter which you do first - tcu or ecu?
  5. Mar 14, 2018 at 6:49 AM
    tnel12
    tnel12 Well-Known Member
    Oklahoma
    2017 QS TRDOR SB
    icon stage 2, icon rebound, wildpeak at3 285/70/17, rago fab light bar, Cali raised led fogs
    No idea, but unless you are the kind of person that likes to watch the world burn and work from bottom to top, I would think Ecu first just because of layout.
    2016trdtacoma, JKDer, dskakie and 2 others like this.
  6. Mar 14, 2018 at 7:26 AM
    bshammer0
    Brandon
    Nashville, TN
    yeah it probably doesn't make much difference but logically I'd start with the brains before flashing the gearbox
  7. Mar 14, 2018 at 7:53 AM
    Ryandr91
    Ryandr91 Well-Known Member
    Corpus Christi, TX
    2018 Cavalry Blue Pro
    Just finished the 91ECU/TCU install. Mat’s instructions are pretty clear. Made one mistake but reread the instructions and figured it out. Currently sitting in the truck letting it idle!
  8. Mar 14, 2018 at 8:24 AM
    trdsilver
    trdsilver Well-Known Member
    So Cal
    2016 TRD Sport 4x4
    OVTune, King 2.5", Total Chaos UCA's, Icon RXT Leaf, Icon Rear Bumps, Pelfreybuilt Silders, JL Audio, Cali-Raised LED, Toyo RT 285-70-17
    His instructions say ECU before TCU.
    dYL0n and BlkTaco47[QUOTED] like this.
  9. Mar 14, 2018 at 8:26 AM
    BlkTaco47
    BlkTaco47 Unhinged
    thx, that's the way I did it weeks ago, I was more curious than anything else.
    dYL0n likes this.
  10. Mar 14, 2018 at 11:43 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    next batch of serial keys sent.
    I know a couple of you guys have the 4.0L 4Runner, one of my main dealers and Branches in the OVTune-PH is taking over all of my mazda work, so I'm looking to get some more 4.0L stuff done for the tacoma and 4Runner.
    if you have a 4Runner and want to get some development finished (and a free handheld V3+) just let me know.
    3rd Gen MT I will have an update in the MT thread
  11. Mar 14, 2018 at 12:00 PM
    Tao
    Tao Member
    Nathan
    2018 Midnight TRD Pro
    Ceramic Coating Window Tint 1" Wheel Spacers General X3's Tires Red Lettering
    can someone help me
    i am stuck on identifying my ECU
    when i plug into the truck and highlight the correct template the "identification" doesnt light up to press
    its like the PCM is not reading or connected to the truck, even though its pluged in
    i think i copied my key right and restarted the PCM
    help..
  12. Mar 14, 2018 at 12:11 PM
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    is your truck ON? you have to press the start button twice in an auto. can't be in accessory and your engine has to be off
  13. Mar 14, 2018 at 12:14 PM
    Tao
    Tao Member
    Nathan
    yes
    the dash says "ignition on"
    and its not running, just on
  14. Mar 14, 2018 at 12:17 PM
    Tao
    Tao Member
    Nathan
    super frustrated. i wonder if it my laptop and some anti virus or protection donig a block
  15. Mar 14, 2018 at 12:23 PM
    SpeySquatch
    2016 TRD OR DCSB
    Taco16LB likes this.
  16. Mar 14, 2018 at 1:10 PM
    DakoTaco
    DakoTaco Well-Known Member
    North Coast
    2016 MGM OR Tacoma
    Avid front bumper guard OVtune HPS Intake Tube Meso designs counting
    If all else fails, use the "Monopoly game" approach, go to start. Usually works for me, either a hiccup or something I missed. All right, I've run the 87 tune for 500 miles, would've logged more but things happen. I've gassed her up with 93 to pull it up to 91 and I'm getting ready to flash the 91 tune. I smile when I do this, but I curse the guys on 91 already raving about it, because I need to go out of my way to gas up at a top tier 91. This includes you @bshammer0 , @dYL0n, @go2cnavy, and others. LOL It's a cold day here, I seem to have the best luck with the idle rev up being not as pronounced when I load the tune at the lowest operating temp, and yes, always I always let it idle for about half an hour. Or until Al Gore & his group show up in their Prius. :) After I get 500 miles on the 91 tune, I'll post my reviews on OP's @bshammer0,s thread.
  17. Mar 14, 2018 at 1:14 PM
    bshammer0
    Brandon
    Nashville, TN
    It will be hard to go back to 87. The struggle is real. I had full intentions of filling up w/ 87 and flashing just to try it out a couple weeks back and mindlessly pumped 93. And have since filled up again with 93. I'll probably try 87 out before a long trip where I can at least claim to save some $ and test it out at some point but as of now I have ONLY run 93 on 91 tune and it definitely SCOOTS and sounds great doing it... Enjoy. Just don't say we didn't warn you that once you cross that line it may be hard to turn back.... :)
    DiabloTRD and DakoTaco[QUOTED] like this.
  18. Mar 14, 2018 at 1:18 PM
    SpeySquatch
    2016 TRD OR DCSB
      File size:
      7.3 MB
      106
    bshammer0[QUOTED] likes this.
  19. Mar 14, 2018 at 1:27 PM
    Tao
    Tao Member
    Nathan
    i have flashed both the ECU and TCU (AT) and am currently idling for 10
    i will report back afet my test drive.
    thanks to all
    bshammer0 and ebbs15 like this.
  20. Mar 14, 2018 at 1:35 PM
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    Granted I used parallels on Mac to do mine, but I didn't turn anything off on windows and had no issues... FWIW
    bshammer0 likes this.
Thread Status:
