Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Mar 15, 2018 at 6:05 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    If you're talking about all of the clicking and clunking, I think that's normal because the truck takes over complete control of all wheels and sends power to each individually with individual braking
    Lt_Dan likes this.
  2. Mar 15, 2018 at 6:22 AM
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    no I know it's normal, just that it sounds horrendous. lol
    DakoTaco likes this.
  3. Mar 15, 2018 at 6:24 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    About the same crazy sound as when your traction control kicks in if you're slipping on a slick hill or something really. it sounds like the truck is about to fall apart, yes and I don't use it often but the 3 times I've felt the "need" to use crawl control it did the job but I shut that crap off as soon as possible :) Now, the MTS works really well in my experience and I use it frequently
    ebbs15[QUOTED] and Lt_Dan like this.
  4. Mar 15, 2018 at 7:15 AM
    Lt_Dan
    Lt_Dan Well-Known Member
    Daniel
    Cincinnati OH
    2017 TRD OR 4x4 DCSB A/T Super White
    Does MTS only work on 4low?
  5. Mar 15, 2018 at 7:19 AM
    bshammer0
    Brandon
    Nashville, TN
    Yes. It's just controlling slip for different types of terrain essentially but I've found it to do the job well in snow, mud, and rocky terrain.
    Lt_Dan[QUOTED] likes this.
  6. Mar 15, 2018 at 7:27 AM
    Mike O
    Mike O Well-Known Member
    2016 TRD OR MGM Access Premium LB
    Mobtown Sliders, SSO Slimline bumper, Baja Amber lightbar & fogs, Sumo bump stops
    If you select the tune by ECM code, why then do you select at tune? Yep, the process is totally clear.....
    SC4333[QUOTED] likes this.
  7. Mar 15, 2018 at 8:10 AM
    SpeySquatch
    2016 TRD OR DCSB
    Not to go off subject for this thread, but wanted to clear this up.
    That clicking sound is completely normal. There is independent control of each braking system in the truck. I thought this myself when I first tried it, but after I contacted Toyota and they explained what was happening all worry left me. It is really in hard on the truck when you use it constantly or over long distances (like 150 yds uphill). Also, the steeper the hill the less you hear those noises, especially when you turn the roof knob past the first spot. I never use 1mph for this very reason and because it takes eons to go 20 ft.
    bshammer0 likes this.
  8. Mar 15, 2018 at 8:17 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Wait till all that clicking and popping then your engine oil light comes on bc you have been climbing a 45 degree plus hill for to long. I like wheeling with new people and laugh when they all freak out with the noise thinking I broke a tooth or CV.
  9. Mar 15, 2018 at 8:21 AM
    SpeySquatch
    2016 TRD OR DCSB
    Agreed, I think it is sometimes useless to use crawl control when these trucks have 4-lo and a locker. It almost seems like more work to use the crawl control
  10. Mar 15, 2018 at 10:50 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Regarding crawl control, the tune does not affect it. But I am investigating crawl control features and how the ECU interacts with it, I may have a crawl control only feature in the future.
    Boost3, go2cnavy, SC4333 and 6 others like this.
  11. Mar 15, 2018 at 11:07 AM
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    Yeah I know the noise is "normal" it's just disconcerting.
    @OVTune interesting, wonder what you'll be able to cook up. like @bshammer0 I use the MTS pretty much whenever I'm in 4 low (not a ton as I'm still stock suspension/tires) but crawl control I've used twice, once testing it, and once just to see if I could really crawl down a hill... worked well once I "let go" and let the truck do it's thing
    ToyoDrew and bshammer0 like this.
  12. Mar 15, 2018 at 11:38 AM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    Has anybody been able to get pcmflash to run in virtualbox on osx?
    "This application cannot be run in virtual environments"
  13. Mar 15, 2018 at 11:40 AM
    SpeySquatch
    2016 TRD OR DCSB
    Some guy (wish I could remember) said he had no issues whatsoever. Make sure Windows Defender is turned off.
    However, I would like to know if this is going to be a problem because I also have Virtualbox and Windows 10 installed on my MAC
  14. Mar 15, 2018 at 12:05 PM
    hr206
    Western Washington
    I recall lots of people saying they didn't have an issue as well. I remember seeing the dongle registration process changed and I'm wondering if pcmflash has changed - don't feel like re-reading 14000 posts and may have to wait until I get home to find a windows laptop.
    I have defender turned off. I'm running Windows 7 on Virtualbox 5.1.22. I removed all the virtualbox tools and set the virtualbox "bios" to report what the baremetal thinks it is (dmidecode).
    ugh, yet another slow down / obstacle getting this installed.
  15. Mar 15, 2018 at 12:07 PM
    SpeySquatch
    2016 TRD OR DCSB
    Has to be windows XP or 10 I believe. Not sure 7 works
  16. Mar 15, 2018 at 12:10 PM
    hr206
    Western Washington
    Wow. How did I miss that! Even more ugh.
  17. Mar 15, 2018 at 12:12 PM
    bshammer0
    Brandon
    Nashville, TN
    I have PCMFlash running in my VirtualBox on my OSX High Sierra MBP... it's a little laggy sometimes but it works fine and I didn't have to pick up a Windows PC for the job. I'm running Windows 10 Professional 64bit Insider Edition... and I have all updates turned off and, aside from downloading the tune files I keep it disconnected from an internet connection and have everything uninstalled down to the bare bones to keep size down on the partition.
    hr206[QUOTED] likes this.
  18. Mar 15, 2018 at 12:13 PM
    SpeySquatch
    2016 TRD OR DCSB
  19. Mar 15, 2018 at 12:14 PM
    SpeySquatch
    2016 TRD OR DCSB
    Also allocate at least 32-50 gigs for Windows 10 on your MAC, lower amounts won't cut it. Not that you need to know this, just clarifying
  20. Mar 15, 2018 at 12:19 PM
    bshammer0
    Brandon
    Nashville, TN
    I have 15GB HD and 4GB RAM dedicated and I would consider this to be about the minimum you could get away with - which is why I keep it off the internet and uninstalled literally everything that it would let me uninstall. If you have a huge hard drive I'd do whatever you can spare as it will likely run better but with my 256GB SSD on this machine I wanted to use the least possible given I just need the OS and the few MBs of stuff required for the tune.
Thread Status:
