Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jul 5, 2017 at 12:31 PM
    #1261
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Non ethanol here in Oregon is getting hard to find and usually $1 more per gallon.
    ebbs15 and GotToyota like this.
  2. Jul 5, 2017 at 12:38 PM
    #1262
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    I drive about 100 miles a day minimum for work so it seems I'm always filling up lol. I use 91 octane already anyways since it runs less than $4 per tank difference in my area.
  3. Jul 5, 2017 at 12:39 PM
    #1263
    sig916
    sig916 Well-Known Member
    @OVTune, if I remember correctly. you stated we can save the stock file and tuned file and switch back to stock if needed. What are chances we can have three file ( stock, 91 tunned and 87 tunned) saved?
    KTJO 4x4 likes this.
  4. Jul 5, 2017 at 12:43 PM
    #1264
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    I wish. Anywhere from .70-$1 more per gallon here.
    ebbs15 likes this.
  5. Jul 5, 2017 at 1:01 PM
    #1265
    c4lvinnn
    c4lvinnn Well-Known Member
    '17 TRD Off Road DCSB
    This would be helpful for traveling and 91/93 isnt readily available.
  6. Jul 5, 2017 at 1:18 PM
    #1266
    fzj40
    fzj40 Well-Known Member
    R
    2017 TRD OR MGM 6MT
    The factory "tune" will pull timing if any pinging/knocking/detonation is detected, many aftermarket "tunes" keep this safety factor too. So, if you have higher octane tune, and have to run a lower octane fuel, the ECU will compensate by retarding timing, safeguarding your engine and lowering your performance simultaneously. I'm not saying I know anything about the tune we are buying here, but it would surprise me if it did not continue to do this.
  7. Jul 5, 2017 at 1:28 PM
    #1267
    Hank Heel
    Hank Heel Well-Known Member
    WA
    LTacoman, def67, stealthmode and 2 others like this.
  8. Jul 5, 2017 at 1:30 PM
    #1268
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    It's so noticeable that a thread was started about it:
    https://www.tacomaworld.com/threads/4low-and-down-steep-hill.496728/#post-15464866
    Try having your engine braking let go all of a sudden when going down a steep hill in 4lo 1st gear!
    AFMurse2014 likes this.
  9. Jul 5, 2017 at 1:39 PM
    #1269
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    We can do this. We have got a lot of requests for 87 oct files. it would be similar to our 91, without the ability to run 91 oct Ignition and AFR. Otherwise torque / throttle / camshaft maps are the same (except low rpm VVT-intake) So yes, no problem can easily be done.
    If you put 87 in on a 91 file the engine will get some initial knock (pretty bad) switch over to a lower IGN K-factor multiplier and you'll be stuck with less power than stock until the ECU can adequately adjust the multipliers back up to "stock" or higher.
    It's related to DFCO control.
    Doomsday, dYL0n and rnicholls like this.
  10. Jul 5, 2017 at 1:59 PM
    #1270
    Hank Heel
    WA
    Sometimes I sit and think why I keep making a mistake of joining forums, id have so much more money in my account
    :annoyed:
    Order #1892
    nDub, Doomsday, goose443 and 2 others like this.
  11. Jul 5, 2017 at 2:01 PM
    #1271
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    :goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy:
    rnicholls likes this.
  12. Jul 5, 2017 at 2:04 PM
    #1272
    Hank Heel
    WA
  13. Jul 5, 2017 at 2:05 PM
    #1273
    Hank Heel
    WA
    Around here all I can get is 92, will the tune be adjusted accordingly or ?
  14. Jul 5, 2017 at 2:11 PM
    #1274
    OVTune
    OVTune
    Running any octane higher than 91 on a 91 oct tune = even better.
    ** for our orders ** we had to order an additional 50x cables which will be here friday morning. Tune kit orders are closed as of this morning, preparing kits as fast as possible thanks. Thank you all!
    Working on dissecting some of the lesser controls for an upcoming update. We will be back on the dyno soon. :)
  15. Jul 5, 2017 at 2:14 PM
    #1275
    Ares32
    Ares32 Well-Known Member
    America
    2016 MGM TRD off road DCSB M/T
    Having to run 91 or higher is the price to pay for a leaner A/F, more ign timing and power. Im hopimg for a Ethanol map! Haha
  16. Jul 5, 2017 at 2:15 PM
    #1276
    wantone
    wantone Well-Known Member
    Baton Rouge, LA
    2017 TRD Offroad DCLB White w/tech package and 6AT
    DeeZee bed mat, Weathertech floor mats and in channel wind deflectors, Carista, center console tray, tinted windows, LED interior lights, 265/75R16 AT3s, carhartt seat covers, bakflip MX4
    How different would the torque numbers be on an 87 oct tune vs a 91 oct tune?
    ebbs15 likes this.
  17. Jul 5, 2017 at 5:20 PM
    #1277
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Not sure what DFCO control is but can this annoying and dangerous loss of compression braking be tuned out of the manuals?
    su.b.rat and TeecoTaco like this.
  18. Jul 5, 2017 at 5:23 PM
    #1278
    BCSpazer
    BCSpazer Well-Known Member
    2020 Tundra TSS Off Road
    Deceleration Fuel Cutoff (DFCO)
    I had to look it up :D
  19. Jul 5, 2017 at 9:03 PM
    #1279
    wirenut
    wirenut I like this place
    Andrew
    NH
    98’ T4R
    OME/5100 - 300lb 3.5” loft setup Prinsu 3/4 rack
    So does anyone have this tune kit installed yet? I skimmed through the pages, didnt see much of actual users.
  20. Jul 5, 2017 at 10:06 PM
    #1280
    FrankJake
    FrankJake Well-Known Member
    Southern California
    2017 Tacoma TRD OR SB Magnetic Grey Metalic JBL Stock (so far)
    Shift Sense Pro, HomeLink Mirror, Screen Protector, Tinted Windows, Now onto the expensive stuff
    One person that we know of has it installed. He wrote a short report but he hadn't driven it very far at that time so he didn't list a lot of info. As of now, two members that I'm aware of just received their final file. They need to install it in their trucks. We should be getting a report from them any day now. If I remember, one of the guys had quite a bit of fuel in his tank and he wanted to run it down so he could fill with 91 octane. The other I can't remember but it was going to take him a few days before he was going to install it. I'm guessing we'll have at least one report by Friday. I think the entire 3rd gen forum is waiting.
    :fingerscrossed:
    ebbs15, Ares32 and dYL0n like this.
Thread Status:
