Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jul 6, 2017 at 5:20 PM
    #1321
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    :rofl:
    OffsetPlayer2 and Hank Heel like this.
  2. Jul 6, 2017 at 5:22 PM
    #1322
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    We're taking about putting the truck in "drive" and "standard". Not ECT.
    Hank Heel likes this.
  3. Jul 6, 2017 at 5:24 PM
    #1323
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Yeah I quoted we all sarcastically because some people in this thread are saying it only changes shift points. I forgot sarcasm doesn't translate through text well.
  4. Jul 6, 2017 at 5:25 PM
    #1324
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Wow guys sorry if we confused anyone!
    To clear up a couple of things on ECT mode, throttle control between the autos and manuals:
    ECT mode -
    ECT mode changes the upshift parameters in the ECU so that it upshifts at different designated RPM / road speed
    there are also throttle control maps that are dependent on ECT mode. So yes ECT changes throttle.
    There are also throttle maps that change for different designated "CRAWL" selection
    We categorized it as "similar" to how the throttle response / control changes in "S/ S+" mode on Lexus vehicles because it is quite literally the same style calibration mapping just stripped, rebadged, and thrown in the tacoma. HOWEVER, You can't make a direct comparison with the tacoma and any lexus vehicle. Sorry if that confused anyone. Our blog about the 2GR is specific to lexus and the 2GR FSE, which is quite different than the 2GR FKS.
    The manual transmission is a lot simpler. It uses the exact calibration features for throttle control with torque / limits / targets as almost any other toyota / lexus with the same logic. (with exception to the progressive torque / throttle intelligence control).
    I can explain further on this if more clarification is needed. One thing that we are looking into for the future is enabling "crawl control" on automatics that don't have it (4x4). The calibration code is there, the table data is all available, it's just not "enabled" because the vehicle doesn't have the selection dial. We're thinking this is very similar to how Lexus does it, by literally leaving all the "S+" code in the ECU, and just removing the dial from allowing you to select S+! (dont take this as "confirmed" more digging is required)
  5. Jul 6, 2017 at 5:26 PM
    #1325
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    File loaded and did 40 miles so far. I will say I like it and nothing more until the ECU completes learning. I will give impressions after 100-200 miles.
  6. Jul 6, 2017 at 5:26 PM
    #1326
    Lt. Dangle
    Ohio
    Let me back up and see if I miss quoted something.
  7. Jul 6, 2017 at 5:29 PM
    #1327
    rnicholls
    rnicholls Well-Known Member
    2016 TRD OR DCLB
    :bowdown::bowdown:
    Thank you op.
    Any word on shipments?
  8. Jul 6, 2017 at 5:29 PM
    #1328
    Lt. Dangle
    Ohio
    Yeah I goofed. I misread that. Sorry.
  9. Jul 6, 2017 at 5:29 PM
    #1329
    OVTune
    OVTune
    Cables come in tomorrow, we posted that but everything gets buried so fast on this thread
    ** we are also making a couple additions to our flash instructions which we will email out to everyone with shipment confirmation**
    dYL0n likes this.
  10. Jul 6, 2017 at 5:30 PM
    #1330
    Doggman
    Alabama
    2017 TRD OR MT
    Cool. Thanks for the info. Just a heads up, the trd or 4x4s with crawl control come with an upgraded brake booster system. I don't have more specifics but as far as I knew it is entirely to support the crawl control for ATs and A-TRAC for manuals. The code may very well be there but the non TRD OR models may not have the brake system needed to support crawl control.
  11. Jul 6, 2017 at 5:31 PM
    #1331
    Doggman
    Alabama
    2017 TRD OR MT
    Aye, someone who admits when they made a mistake. Rare around these parts. Respect
  12. Jul 6, 2017 at 5:32 PM
    #1332
    Lt. Dangle
    Ohio
    I'm not sure it's even allowed...
    sakibomb, rnicholls and EubeenHadd like this.
  13. Jul 6, 2017 at 5:33 PM
    #1333
    OVTune
    OVTune
    Thanks!. I suspect that if these parts were put on a non TRD OR model and wired into the ECU (if toyota was mean enough to not leave the wiring) then it would work as a TRD vehicle.
    Not as easy as lexus, literally a S mode dial.
  14. Jul 6, 2017 at 5:38 PM
    #1334
    OVTune
    OVTune
    When I get a chance I'll do a whole in-depth write up on the 2GR FKS and control system. Might answer any left over questions. I'll do the auto and manual so people understand differences in interactions depending on what transmission you have.
    93jeepman, splitbolt, dYL0n and 7 others like this.
  15. Jul 6, 2017 at 5:38 PM
    #1335
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Any idea on the possibility of enabling use of the rear differential locker in any other drive mode aside from 4L? The locker is specific to the TRD off road. This was a popular mod with the second gen and many of us third gen owners were quite disappointed when we learned a simple 'work around' was not available.
    MOC221_ and Glenn_R like this.
  16. Jul 6, 2017 at 5:40 PM
    #1336
    OVTune
    OVTune
    I'll need to take a closer look at how it is implemented and how it interacts with the ECU before I can determine what can be done
    opentang and SC4333[QUOTED] like this.
  17. Jul 6, 2017 at 5:41 PM
    #1337
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    This would be awesome, that sort of work is what allows enthusiasts to really get into the potential of a motor.
    MOC221_ likes this.
  18. Jul 6, 2017 at 5:47 PM
    #1338
    OVTune
    OVTune
    if you want a temp map I can revert the ignition and fueling changes back to stock, and it will just have torque / throttle mode adjustments. Temporary, but lets you get a feel for it. (won't be much change in power though)
    Ares32[QUOTED] likes this.
  19. Jul 6, 2017 at 5:51 PM
    #1339
    Ares32
    Ares32 Well-Known Member
    America
    2016 MGM TRD off road DCSB M/T
    Thanks for the offer Matt but I know you are busy enough as is. Im at half a tank and will drive the shit out of the truck this weekend......I just need a little more patience even though its killing me inside haha
  20. Jul 6, 2017 at 5:58 PM
    #1340
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    @OVTune can the DFCO be tuned out? Sorry if I missed your response.
Thread Status:
