Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Apr 11, 2018 at 9:29 PM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    Did the slight nerfing of tip in get booted from this update?
  2. Apr 11, 2018 at 10:26 PM
    ThatOneTaco
    ThatOneTaco Well-Known Member
    CA, Bay Area
    2017 DCSB 4X4 TRD Off-Road
    Fuck yea Mat!
    Did the numbers change any on the dyno with the fuel changes?
    2016trdtacoma likes this.
  3. Apr 12, 2018 at 1:07 AM
    CrisMag16SPRT
    CrisMag16SPRT Well-Known Member
    Oregon
    16 DCLB TRD Sport (Silver St Cloud)
    275/KO2s, 5100s, Morimoto hids/fogs, OVTune. Softopper.
  4. Apr 12, 2018 at 4:37 AM
    Doogle
    Doogle Well-Known Member
    Jonathan
    2017 Black Tacoma Dbl Cab
    Thanks Matt !! Hope you found away to throw in a soft cut without causing engine detonation .
  5. Apr 12, 2018 at 4:43 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Wired, just like if you were flashing a new map. Obd2 adapter to cable to laptop
    Doogle[QUOTED] likes this.
  6. Apr 12, 2018 at 5:03 AM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    @OVTune
    I emailed over some AT logs with the bogg/accelation pause on full throttle take offs.
    Does the update fix this?
    I’m still trying to capture the random kick/bump after deceleration and coming to a stop and also the bogg when accelerating out of a corner.
    Thanks, Pbfab
    Order2152 Conter
    Metallikatz3 likes this.
  7. Apr 12, 2018 at 5:23 AM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Tell
    Tell me about it... my average mpg is 14-15mpg with normal driving. I can get 19-20 but i have to go under 65mph which is not realistic here in california. I go to work at 4am and everyone literally drives 80-90mph... Ov is doing alot with this tune but toyota messed this truck up!
  8. Apr 12, 2018 at 5:38 AM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Are you stock?
  9. Apr 12, 2018 at 5:39 AM
    cwolgy88
    cwolgy88 Well-Known Member
    Cody
    2017 Toyota Tacoma TRD Sport
    None as of yet
    I too have this kick/bump when decelerating and coming to a stop and I'm NOT on the Ovtune...yet. I actually have my 15k service today at the dealer and brought up this issue. Per other threads it could be due to low trans fluid from the factory.
    Crimson Flam3s and bshammer0 like this.
  10. Apr 12, 2018 at 5:50 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    I have that some bog on full throttle take-offs, stock, and through every version of the tune. The dealer spent 2 days trying to diagnose it (stock) and could not determine why it was happening.
    Chipi3s likes this.
  11. Apr 12, 2018 at 6:34 AM
    Doogle
    Jonathan
    Thanks
  12. Apr 12, 2018 at 6:40 AM
    dingel5
    dingel5 Mocphus
    Paul
    P Town, California
    2016 MGM SR5 AC AT 4x4 OVTuned 2.0B (Un)Dongled OG
    In progress.... And getting better!
    :bowdown::dancingbacon::burnrubber:
  13. Apr 12, 2018 at 7:06 AM
    Chipi3s
    San Diego
    Lifted abd bigger tires
  14. Apr 12, 2018 at 8:28 AM
    PB FAB
    2017 SR DCSB 4x4 v6
    I’ll be servicing my transmission in the next week or two, waiting for filter and gasket. I’ll check fluid level first and update later.
    cwolgy88[QUOTED] and bshammer0 like this.
  15. Apr 12, 2018 at 8:49 AM
    SpeySquatch
    2016 TRD OR DCSB
    OK, sorry to beat a dead horse, but Mat said the update will be available via the Flash manager.
    Does this mean I go to the "Updates" menu in my current flash manager and download the new tunes?
    Is it connected to what I already have?
  16. Apr 12, 2018 at 9:00 AM
    SpeySquatch
    2016 TRD OR DCSB
    3-4 tanks a week! F***
  17. Apr 12, 2018 at 9:01 AM
    su.b.rat
    su.b.rat broken truck
    i go through two and i thought i was feeling the pain. eesh.
  18. Apr 12, 2018 at 9:12 AM
    catastrofe
    catastrofe Well-Known Member
    Bob
    Montrose, CO
    2022 F350 Tremor
    Correct, unless he puts out an updated version of Flash Manager as well (I believe he said he would a couple of weeks ago). The OP would indicate whether a new version of Flash Manager is available. So you would either download the new version of FM, then the new maps, or just the new maps from your existing version of FM.
  19. Apr 12, 2018 at 9:14 AM
    2017TRDpro
    2017TRDpro Well-Known Member
    2017 TRD Pro
    Mat has never release new maps with previous version of Flash Manager. In the past, he release new Flash Manager with new maps. Not efficient, but I am sure he has reasons.
    dYL0n likes this.
  20. Apr 12, 2018 at 9:40 AM
    Doogle
    Jonathan
    I know right!! I’m trying to get in the habit of turning my truck off more . I work with the DOT and sometimes it’ll run from 6:30 am to 5:00 pm minus a lunch break. That’s one reason I see 8-10 mpg a lot. I like coming back to a warm cab on the winter
    su.b.rat[QUOTED] likes this.
Thread Status:
