Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Apr 15, 2018 at 12:32 PM
    catastrofe
    catastrofe Well-Known Member
    Bob
    Montrose, CO
    2022 F350 Tremor
    Oh, my logical brain knows that but you still can't help wondering! :eek:
  2. Apr 15, 2018 at 12:32 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    ECT mode = higher shift points.
    SC4333 and riz_atx like this.
  3. Apr 15, 2018 at 12:33 PM
    Slickwhenwet
    Slickwhenwet Well-Known Member
    2017 Tacoma TRD offroad
    I’m not sure how I didn’t accidentally do this...
  4. Apr 15, 2018 at 12:40 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    I was close realllllly to doing it!
  5. Apr 15, 2018 at 12:43 PM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    I was already excited about 1.04 now im even more excited.:p
  6. Apr 15, 2018 at 12:55 PM
    SpeySquatch
    2016 TRD OR DCSB
    ok, maybe it isn't me then. I only drove the 91 1.04 tune for like 25 miles, but it seems a little less powerful SO FAR than the 1.03 87 tune. Anybody else notice this SO FAR...? Should I have reflashed the 1.03 TCU and 1.04 ECM at the same time to zero everything out again? I only did the 1.04 ECM. I am not noticing much of a difference besides smoother shifting a little.
    sig916 likes this.
  7. Apr 15, 2018 at 12:59 PM
    Chipi3s
    San Diego
    Powers the same, throttles been smoothed. Also he just mentioned a few posts ago he will be going into more details abot that and other stuff
  8. Apr 15, 2018 at 1:00 PM
    SpeySquatch
    2016 TRD OR DCSB
    OK so no need to reflash the TCU? Thing is the 87 1.03 seemed to have more power than the 91 1.04 so far
  9. Apr 15, 2018 at 1:00 PM
    dubstyle7
    dubstyle7 Well-Known Member
    Nic
    Dana Point, CA
    2016 Super White Tacoma TRD Sport 4X4 DCSB
    And no need to flash tcu again. Just put some more miles on it.
  10. Apr 15, 2018 at 1:01 PM
    SpeySquatch
    2016 TRD OR DCSB
    Roger that.
  11. Apr 15, 2018 at 1:06 PM
    Venator_2033
    Venator_2033 Well-Known Member
    4" inch lift Dakar leafpacks/Bilstein 5100 B110/Fox 2.0 coil-overs/Catless Dual Exhaust w/H-pipe/OVtuned1.05/RCI Sliders/HID kits Hi/Low/AFE Intake with scoop and 76mm throttle body/Total chaos Fab UCA's
    I was able to get quite a few miles in on 1.04 since I was able to load it a bit sooner than everyone else so far the things I have noticed are one immediately is the tip in, which in my opinion is now perfect no more breaking the tires loose when accelerating from a stop in slick road conditions, Idle is now so smooth if it wasn't for the rumble of the exhaust I wouldn't be able to tell it was running, on 1.03 there was still a little roughness to it also while idling with the blower on it would constantly kick up the RPMs which was a bit annoying but that also has been reduced to the point that I barely notice it anymore alright now onto shifting I've never really liked the way it drives in D mode but I did drive in it for about the first 30 maybe a few more miles and for me I still don't like the shift points but might be more due to the TC not being locked more often like in S mode also 4th still holds on and doesn't want to shift into 5th after letting off the accelerator between 50-60mph trying to feather the pedal won't help either I'm not sure if it's because of my mods not being properly tuned for or not since these trucks just don't all act the same from what I've seen posted on here however in S mode which is what I normally drive in it drives beautifully for me, just love the way it shifts in S mode I know exactly how the truck will react based on how much pedal I give it, also I have noticed that it does seem a bit smoother shifting overall. Now just waiting for the customized tuning to start.
    EDIT: Forgot to mention that that when flooring it from a stop it'll hit the fuel cutoff when it shifts to second gear I'll be getting the chirping high pressure fuel pump TSB done on this coming Wednesday so I'll see if that fixes it.
    metal-rex likes this.
  12. Apr 15, 2018 at 1:10 PM
    catastrofe
    Bob
    Montrose, CO
    2022 F350 Tremor
    Agreed. Very smooth idle.
  13. Apr 15, 2018 at 1:13 PM
    ThatOneTaco
    ThatOneTaco Well-Known Member
    CA, Bay Area
    2017 DCSB 4X4 TRD Off-Road
    I got a half staff when he said “power” map.
    taco 16, Shellshock and Chipi3s like this.
  14. Apr 15, 2018 at 1:18 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    The video Matt has on the first page only shows you flashing to the canbus...
  15. Apr 15, 2018 at 1:18 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    I know. I made that video.
    The reason I’m saying this is because if you did 1.03 last.. if you don’t change it back, you’ll write 1.04 to the gearbox.
    Slickwhenwet likes this.
  16. Apr 15, 2018 at 1:23 PM
    Anchovy
    TRD Ferguson
    I did 1.03 87 and I didn't have to change anything before flashing 91. Are you supposed to flash the TCU to the gear box? Or to the canbus?
  17. Apr 15, 2018 at 1:24 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    TCU gearbox
  18. Apr 15, 2018 at 1:25 PM
    catastrofe
    Bob
    Montrose, CO
    2022 F350 Tremor
    Been there, almost done that! :facepalm:
  19. Apr 15, 2018 at 1:28 PM
    Anchovy
    TRD Ferguson
    Uh-huh. Because I flashed one after the other without changing anything from the drop down but I didn't notice anything wrong
  20. Apr 15, 2018 at 1:28 PM
    Anchovy
    TRD Ferguson
    I did this on the 1.03 as well
Thread Status:
