Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Apr 16, 2018 at 7:35 AM
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    I'm in San Antonio, but heading out for a two-week drive around to BBRSP, Big Bend, Marfa, Alpine, Fort Davis, McDonald Observatory, among other places. Pretty much a West Texas road trip.
    hbaade, mZiggy[QUOTED] and riz_atx like this.
  2. Apr 16, 2018 at 7:38 AM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    My GF and I just did a similar trip! BBRSP is just amazing! So remote and gorgeous but much smaller than BBNP. 1.03 did well in this part of texas. With my truck fully loaded, I averaged 15mpg for the whole trip. The gas killing part is the 85MPH sections of I-10. I found an 18 wheeler going 75 so I got behind that rig and cruised for many hours, which helped the MPGs
    Phich[QUOTED] likes this.
  3. Apr 16, 2018 at 7:39 AM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    I didn’t get into 6 until low to mid 70’s on freeway, under light load.
    dYL0n[QUOTED] likes this.
  4. Apr 16, 2018 at 7:56 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Yeah I guess I’ll have to get up there.
    Not sure how much I’ll like this. MPGs May hurt.
  5. Apr 16, 2018 at 8:20 AM
    Feltcycle
    Feltcycle Well-Known Member
    2017 Tacoma SR5 4x4
    Totally agree with this ^^^
    I would like to see the truck shift into 5th at no less than 45 mph and 6th around 60-65 mph. Other than this 1.04 has been just about perfect for me. (SR5 4x4 stock wheels & tires)
    Tip in is absolutely perfect
    The truck shifts much better
    Seems to be in the right gear during low speed operation
    Idle is drastically better
    Cold surge is gone
  6. Apr 16, 2018 at 8:22 AM
    catastrofe
    catastrofe Well-Known Member
    Bob
    Montrose, CO
    2022 F350 Tremor
    Agreed!
  7. Apr 16, 2018 at 8:39 AM
    treimche
    treimche Well-Known Member
    Fargo, ND
    I think the only way to make everyone happy with shifting and deciding what gear the truck should be in at what speed, etc, is going to require more than just one tune file. There will have to either be custom tunes for everyone, or else the ability to manually shift the auto transmission both up and down. That way the driver can lock into 6th gear at 40 for their fuel mileage. Personally, I can't stand the Tacoma chugging around town at 1100 RPMs. There's zero torque down there, and in order to accelerate, an immediate downshift, or 2, is necessary.
    Hateusernames likes this.
  8. Apr 16, 2018 at 8:46 AM
    E$Yota
    E$Yota Well-Known Member
    Ethan
    Dothan, AL
    2016 Tacoma TRD Sport 4X4
    FN wheels' version of the TRD Pro 4Runner, TRD Pro front skid plate, Low Range Offroad 3/1 lift, JBA Offroad upper control arms, TRD Pro Shift knob, OV Tuned, 4.88s, 285/70/17 BFG KO2s
    Prolly could be solved with 1 of the below tunes:
    1- Stock gears and tires
    2- Stock gears and 32-33 inch tires
    3- 4.56-4.88 gears and 32-33 inch tires
    4- 4.56-4.88 gears and 35 inch tires
    Lt_Dan and dingel5 like this.
  9. Apr 16, 2018 at 8:47 AM
    SpeySquatch
    2016 TRD OR DCSB
    I think it depends how aggressively you push the throttle. Sometimes 6th happens at 60 for me when driving normal, other time it’s 75 if I am accelerating
  10. Apr 16, 2018 at 8:49 AM
    MCDavis
    MCDavis Taco life is over. Full time 4wd for the win.
    RIC, VA
    2017 TRD Sport 4wd (SOLD) - Currently in a 2016 GX460
    One more needed:
    5- Stock gears and 35" tires
    for those of us who haven't yet regeared.
    bshammer0 and dingel5 like this.
  11. Apr 16, 2018 at 8:49 AM
    E$Yota
    Ethan
    Dothan, AL
    3.91s and 35s? Wow, that must really suck!
  12. Apr 16, 2018 at 8:51 AM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    Commute this morning was great - 9 miles, hilly, zig zag path through urban streets. Lots of slow-and-go, turns transitioning to downhill, turns transition to uphill. Transmission shifting and throttle response seems spot on. Slower throttle tip-in makes bumper-to-bumper sections easier.
    bshammer0 likes this.
  13. Apr 16, 2018 at 8:52 AM
    E$Yota
    Ethan
    Dothan, AL
    FYI, eastcoastgearsupply.com has 3rd members with any gearset you want for about $1300 for front and rear. You just ship them your cores. Already comes setup . You just need diff fluid! Been thinking about going from 4.88s to 4.56s to get back some fuel mileage and my rear diff has never been right.
    ian2016 and Hateusernames like this.
  14. Apr 16, 2018 at 8:57 AM
    hr206
    Western Washington
    Straying off-topic. How does that work? Slide axle shaft out, replace 3rd member, slide axle back in? I've been wondering about this for my 1st gen.
  15. Apr 16, 2018 at 9:01 AM
    E$Yota
    Ethan
    Dothan, AL
    Basically. The 8inch diffs are a semi-floating axle. You'll have to drop the rear driveshaft, remove tires, remove brake drums, unbolt the plate that secures the axle shaft, slide shaft out. Sometimes you have to disconnect the brake line but I have done it without disconnecting it. You just have to bend it back in place if it gets bent.
    ian2016 and hr206[QUOTED] like this.
  16. Apr 16, 2018 at 9:01 AM
    dYL0n
    Dyl0n
    New Orleans, LA
    1.04?
  17. Apr 16, 2018 at 9:01 AM
    MCDavis
    RIC, VA
    Yes I'm fully aware as I have quotes from ECGS directly and a local shop to do a third member swap. And honestly, the 3.91s and 35"s aren't that bad, quite liveable in fact, but not ideal. It's all in perception though. Your last statement is one of the reasons I've haven't taken the dive just yet.
    Anyway, the 91 tune definitely helps with the tire size. Just to get back on topic.
    dYL0n likes this.
  18. Apr 16, 2018 at 9:05 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    I did that drive from Houston in January and was getting 15 mpg but would suck bc I was either going to slow or to fast (4-5 gear dance) and it wouldn't hold a speed. My friends drafting behind were like WTF the whole time bc it wouldnt hold a speed. I bought the tune a week later.
    Phich, hbaade and dYL0n like this.
  19. Apr 16, 2018 at 9:17 AM
    E$Yota
    Ethan
    Dothan, AL
    When (notice I said WHEN and not IF), I re-gear again, I will be going with eastcoastgearsupply.com. It is stupid easy to pull the diffs, ship, wait, re-install. That way the onus is on them and not on a mechanic to install using a install kit that doesn't have everything in it needed. justdifferentials/Nitro gear really screwed the pooch and me when it came to re-gearing my Yota. I ended up having to call literally 20 dealership parts departments to find the correct rear carrier bearings. And before anyone says it was the installer, it wasn't/isn't. The gears are within spec. They have been checked at least 10 times. It's the crappy Nitro gears. I'll be going with Yukon the next time. Until then whining on decel is how I roll!
  20. Apr 16, 2018 at 9:29 AM
    TRDOBSESSED
    TRDOBSESSED Well-Known Member
    Blair
    Puyallup, Wa.
    2017 TRD ORAC
    OvTuned
    I enjoy reading the comments and technical stuff . Compared to how this truck drove a year ago , i'm pretty darn content with 1.04. The truck staying in the higher rpm range around town i love it . It does go into 4th with my light foot . Has immediate power when going around a corner now ...that's helpful too . Great tip in , and the surging i had seems to be gone .
    hbaade, taco 16 and bshammer0 like this.
Thread Status:
