Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Apr 17, 2018 at 6:50 PM
    n6vmo
    n6vmo Well-Known Member
    Sahuarita, AZ
    2018 DCLB OR AT Super "Priviledged"
    Bilstein 6112, ICON UCAs, 5160, AAL, 265/75/16 Falken Wildpeaks
    Is all the tune flashing software 64 bit or can it run on a 32 bit Windows machine?
  2. Apr 17, 2018 at 6:53 PM
    SpeySquatch
    2016 TRD OR DCSB
    It did. Confirmed, like red burnt reside
  3. Apr 17, 2018 at 6:58 PM
    ThatOneTaco
    ThatOneTaco Well-Known Member
    CA, Bay Area
    2017 DCSB 4X4 TRD Off-Road
    Again, my hybrid which is in electric mode at low speeds is setting off car alarms?
    Or my stock truck which I drive 1-2 times a week is setting off alarms?
    Guess I need to get an exhaust to live up to your expectations.
  4. Apr 17, 2018 at 7:01 PM
    catastrofe
    catastrofe Well-Known Member
    Bob
    Montrose, CO
    2022 F350 Tremor
    I think you have him confused with TacoSauceHB...
  5. Apr 17, 2018 at 7:13 PM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    I really don't see how this is possible. Was the filter soaked in oil and dripping? Even then the MAF would be a mess from the oil and the thing would run like crap long before the O2's failed. I don't get it.
  6. Apr 17, 2018 at 7:14 PM
    SpeySquatch
    2016 TRD OR DCSB
    It was a 2003 4-banger. The oil covered the sensor over time in burnt carbon. I asked the tech that worked on Toyota and Lexus vehicles and he said it is common for Toyotas with aftermarket oiled intakes.
    However, he could be blowin smoke lol
  7. Apr 17, 2018 at 7:17 PM
    E$Yota
    E$Yota Well-Known Member
    Ethan
    Dothan, AL
    2016 Tacoma TRD Sport 4X4
    FN wheels' version of the TRD Pro 4Runner, TRD Pro front skid plate, Low Range Offroad 3/1 lift, JBA Offroad upper control arms, TRD Pro Shift knob, OV Tuned, 4.88s, 285/70/17 BFG KO2s
    Basically sine the MAF was covered in oil, it was throwing off the readings causing the engine to dump more fuel, thus fouling out the plugs and the O2 sensors. Could fixed it all by just cleaning the MAF, throwing in new plugs, and seafoaming the shit out of the intake thus burning off carbons on the O2s
  8. Apr 17, 2018 at 7:27 PM
    ksj
    Pacific NW
    265/70-17 KO2
    That sounds about right to me as far as what it was. The red color was more likely to be fuel additives, which can cause that over time. A fouled MAF causes a chain reaction through both intake and exhaust cycles.
  9. Apr 17, 2018 at 7:49 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Bro, stop.
    Your IATs are probably screaming high. How is your “cold” air intake, drawing air from the engine bay? Get out of here. K&N is the BIGGEST chain auto parts store scam to exist.
    Let me guess, your throttle body spacer gave you +12 wheel HP?
  10. Apr 17, 2018 at 8:06 PM
    Reypac24
    Reypac24 NRA Member
    Mr., but friends call me Sir.
    Republic of Texas
    2017 DCSB Limited 4x4 (SOLD)
    04B04. OV Tune # 1857 dongle 1.04r 91 octane. Nitto Ridge Grapplers 265/60/18. SaBellCo Tailgate Lock. Meso Customs TRD coin holder, gasshole. Tacomods black anodized aluminum radio knobs. Lock'er Down Console Safe. Sig Sauer P238 Desert. Escort Passport 9500i Radar/Laser Detector.
    add Slick 50 and you're done. :D
  11. Apr 17, 2018 at 8:14 PM
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    Isn't there a thread in here where a guy had to get a new engine because of his high performance air filter? Let in too much dirt...
    dYL0n likes this.
  12. Apr 17, 2018 at 8:24 PM
    SpeySquatch
    2016 TRD OR DCSB
    Finally, thank you
    2016trdtacoma and dYL0n[QUOTED] like this.
  13. Apr 17, 2018 at 8:39 PM
    treimche
    treimche Well-Known Member
    Fargo, ND
    If you want your truck to chug around at 1000 RPMs, go flash it back to stock. That will net you the best MPG and lowest RPM possible. If you haven't realized, the OVTune is here so we can actually use the little bit of power the Tacoma makes, and not be stuck in 5th gear at 30 mph bogging around everywhere. You are NOT speaking for everyone with a stock truck/wheels/weight/etc. I personally can't stand the fact that the damn thing is still getting up into 5th gear at 35 mph. It's completely worthless at that speed/RPM. My Tacoma should NEVER see 5th gear under 45mph, maybe even 50mph.
    I have been campaigning for a way to manually shift the auto trans since the beginning, but you don't see me posting about it every day. Or maybe that's what has to be done in order to make sure it gets attention? Just chill out man.
    Also, if we have to pay extra for custom shift points or whatever, I'm game.
  14. Apr 17, 2018 at 8:50 PM
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    1. No one said anything about 5th gear at 30, 4th gear is perfectly fine to MAINTAIN 30mph... again... load based. If you're still accelerating then it shouldn't touch 4th.
    2. You need to either go buy a V8 truck or a sports car if you want to scream around at 2500rpm all day long 'because I want the power ready'. Vehicles have gears, let it change gears to give you power, otherwise go buy a CVT or a manual.
    3. This is a new release, which myself and a few other stock truck owners believe has improved on certain aspects and gone backwards in others, hence the posts.
    You'll probably like his power map he's been working on.
  15. Apr 17, 2018 at 8:54 PM
    SpeySquatch
    2016 TRD OR DCSB
    Are you saying you don’t like 1.04? Seems pretty darn flawless. Commuting is wonderful now both highway and city.
    hbaade, Reypac24 and dYL0n like this.
  16. Apr 17, 2018 at 8:57 PM
    acemastr
    Aaron
    Tampa, FL
    OVTune
    Everything is perfect, except shift points for 3-4 and 5-6 on my stock truck. To put it simply, I don't like sitting at 2000rpm+ at 30mph because it won't change to 4th and I don't like it using 5th when it could easily be in 6th when i'm cruising along the flat Florida interstate.
  17. Apr 17, 2018 at 9:27 PM
    SpeySquatch
    2016 TRD OR DCSB
    Weird. Mine doesn’t do that and my tires aren’t that big 265/75. It’s probably Florida...
    Shellshock likes this.
  18. Apr 17, 2018 at 9:38 PM
    KkelX4
    KkelX4 Well-Known Member
    2017 Tacoma TRD OR
    RTT Rack
    Yeah I'm stock and that doesn't happen to me either. (I'm on 1.04) Something fuckety with your truck.
  19. Apr 17, 2018 at 9:41 PM
    KkelX4
    2017 Tacoma TRD OR
    RTT Rack
    Also notice you have a 2016, have you checked or swapped out your CPS yet?
  20. Apr 17, 2018 at 9:42 PM
    SpeySquatch
    2016 TRD OR DCSB
    Mine is a Texas made 2016 too.
Thread Status:
