Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Apr 19, 2018 at 6:45 PM
    E$Yota
    E$Yota Well-Known Member
    Ethan
    Dothan, AL
    2016 Tacoma TRD Sport 4X4
    FN wheels' version of the TRD Pro 4Runner, TRD Pro front skid plate, Low Range Offroad 3/1 lift, JBA Offroad upper control arms, TRD Pro Shift knob, OV Tuned, 4.88s, 285/70/17 BFG KO2s
    Think that might be a placebo effect... idle relearn and all other air and fueling trims relearns go through their learning processes for the first 50 starts regardless of engine temp. How you drive it for the first 50 cranks is how it learns what to expect from then on. That doesn't mean it can't or won't make power when needed or get fuel mileage when needed. Just the difference in a grandpa vs a 16 yr kid's driving style. Both have the potential to do the same thing...
  2. Apr 19, 2018 at 7:03 PM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    I suppose it could be. I've only put ~100mi on the tune, which I put on when the truck had only ~450mi. Trucks only a week old today, so nowhere near 50 cranks.
    With that said, I noticed that my idle is much smoother than it was after the first time I flashed.
    My point is that you want to do the initial idle learning on a warm engine. While the engine will probably 'learn' anyway, following the FSM procedure for initial idle learning seems like the fastest way to being happy with the tune.
  3. Apr 19, 2018 at 7:05 PM
    E$Yota
    Ethan
    Dothan, AL
    It will settle in. The next thing you should, if going to bigger tires in the future, is regear that thing!
    4.56s for 33s
    4.88s for 35s
  4. Apr 19, 2018 at 7:07 PM
    E$Yota
    Ethan
    Dothan, AL
    A regear makes 236 hp and trq to the wheels feel like 350+...
  5. Apr 19, 2018 at 7:27 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    So you’re saying you want to cruise at 65-70, in 6th, and ECT power mode activated? Why do you need ECT power mode on at that speed?
    Just turn it off.
    TC_Mic, TFly, DakoTaco and 3 others like this.
  6. Apr 19, 2018 at 7:33 PM
    E$Yota
    Ethan
    Dothan, AL
    I just wish everyone on here would regear and install 1.04... or if it is cheaper, drive or fly to Dothan, AL and I'll let you drive my truck!
    honey, hbaade, bshammer0 and 2 others like this.
  7. Apr 19, 2018 at 7:35 PM
    chadabear
    chadabear Well-Known Member
    Chad
    Louisiana
    2018 DCSB 4x4
    Good...."professional" advice there
    disk_55FL likes this.
  8. Apr 19, 2018 at 7:51 PM
    treimche
    treimche Well-Known Member
    Fargo, ND
    Re-gear is what, $1500-2000 all said and done? Then those of us with warranty will very likely lose any coverage related to rear end, drive shaft, axles, etc. No thanks, at least not until the factory warranty is long gone. But by then I'll have either learned to just put up with the thing, or trade it off.
  9. Apr 19, 2018 at 7:57 PM
    E$Yota
    Ethan
    Dothan, AL
    $1500 all said and done doing the labor yourself. The warranty for the rear end then falls on eastcoastgearsupply.com (who is the best supplier of pre built 3rd members). The oil leaks falls on the installer which anyone can do in their front yard, drive ,etc...
    Screw the 60k mileage warranty on the axles.. they are covered ubder a different warranry. You still have the engine and trans warranty. They would have to crack the diffs to prove you regeared. If they did that without your authorization they would have no leg to stand on...
    treimche[QUOTED] likes this.
  10. Apr 19, 2018 at 8:01 PM
    E$Yota
    Ethan
    Dothan, AL
    You spent $37k+ and a $800 tune to be where you are not counting wheels tires etc.. the only reason you are reading this is because you know there is other things out there. Be a man and take care of your truck the way it needs to be. No one ever complained about a modded Tacoma or pickup until now... just reagear, get the tune and add whatever the F you want from there!
  11. Apr 19, 2018 at 8:13 PM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Or you could turn ect off... and hit 6th gear normally lol
    TC_Mic and dYL0n like this.
  12. Apr 19, 2018 at 9:56 PM
    SpeySquatch
    2016 TRD OR DCSB
    Agree with this guy!
    Regearing is excessive. Get smaller tires, you don’t need 35’s on a 3rd gen taco. Too damn expensive to run rubber like that unless you literally live in or off-road daily is silly.
    The tune is awesome with 32” tires and you save money from less gas wasted...what a concept
    dingel5 likes this.
  13. Apr 19, 2018 at 10:31 PM
    SpeySquatch
    2016 TRD OR DCSB
    Reypac24, Chipi3s and Anchovy like this.
  14. Apr 19, 2018 at 10:36 PM
    SpeySquatch
    2016 TRD OR DCSB
    Crimson Flam3s likes this.
  15. Apr 20, 2018 at 12:45 AM
    Arpatton86
    Arpatton86 Well-Known Member
    Ontario Canadia
    2017 DCSB TRD OFF-ROAD OV TUUUUNED
    Did I miss something? Since when did they come out with 4.56 gears for the turd gen?
  16. Apr 20, 2018 at 3:37 AM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    The autos without a factory locker run the 8.0 inch rear end, 5.29 available for it too!
  17. Apr 20, 2018 at 4:05 AM
    Arpatton86
    Ontario Canadia
    Got me all hot and bothered, then I realized it’s for the 8.0” non locker. The 8.75” is still stuck with 4.88 evidently.
  18. Apr 20, 2018 at 4:38 AM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Nope. Not 65-70. 70-75 in sixth - primarily on the downhill side after a climb.
    The last 75 miles of my weekend commute is very hilly. ECT makes this part of the drive much more enjoyable/mindless because:
    (1) D goes into 6th a too early on rolling hills and requires a lot of skinny pedal changes to maintain speed.
    (2) ECT holds gears a little longer and requires less throttle manipulation - it is much more consistent with the elevation changes
    Strangely enough a manual shift to S6 or setting cruise control will result in an upshift to 6th with ECT, but while in D it hangs onto 5th.
    Very minor in my opinion...just an observation.
  19. Apr 20, 2018 at 4:43 AM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    My truck goes into 6th at around 65 in ECT with stock gearing and 265/70/17s.
    go2cnavy likes this.
  20. Apr 20, 2018 at 5:01 AM
    E$Yota
    Ethan
    Dothan, AL
    My MPGs are just as good as anyone else's... 17.5 to 18.5 without trying up to 20 when hyper miling. 15.5 when I'm hotrodding it...
Thread Status:
