Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jul 12, 2017 at 12:14 PM
    #1621
    Doomsday
    Doomsday Well-Known Member
    Cypress, TX
    2017 TRD Sport 4x4 DCSB MGM
    Lights, Tires, Wheels,...more to come!
    I'm surprised TacomaWorld members haven't made a mass complaint about this to Toyota. I mean, I seen and read the reviews online, plus all the other consumer reports, edmonds, etc... and still no legitimate fix. I bought my Taco January of this year knowing the 2nd revision ECU/Tranny flash (TSB) was being done. Yet still the throttle response is horrible.
    IMHO and I agree with others. The factory flash is dangerous on the highway! By the time the Taco responds to WOT you burned some time trying to merge or move over a lane. I wouldn't be suprised if someone sues Toyota over this if they get hurt in an accident.
    FrankJake, KevinCT and speedtre like this.
  2. Jul 12, 2017 at 12:32 PM
    #1622
    Taco Larry
    Taco Larry Well-Known Member
    Larry Gonzalez
    South Fla
    Tacoma SR5
    I pretty much drive my Taco with the ECT on all the time.....lol
    When to use your ECT
    Using your vehicle’s electronically controlled transmission, your Toyota’s engine is able to shift at higher revs. That being said, a good time to use this function of your engine is when you need to accelerate quickly, such as when merging onto the freeway. Acceleration is noticeably quicker with the Electronic Controlled Transmission on, however it should be noted that it significantly decreases your vehicle’s efficiency. So while you could leave it on and experience the influx of power all of the time, if you’re looking to save at the gas pump, we wouldn’t recommend it.
    Hopefully that answers any questions about the Toyota ECT button. For more answers about your vehicle, as well as Toyota-related news and information, be sure to check out the rest of our blog. If you have any other questions, feel free to ask below or contact us here at New Rochelle and we’ll be sure to get back to you.
  3. Jul 12, 2017 at 4:28 PM
    #1623
    Ares32
    Ares32 Well-Known Member
    America
    2016 MGM TRD off road DCSB M/T
    Now that i have ran the tune for a few days I cant wait for the V1.02 M/T update!
    rnicholls and nevadabugle like this.
  4. Jul 12, 2017 at 6:27 PM
    #1624
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Dongles are on track so we should have any pendings orders out NLT friday afternoon.
    by the end of the week we will have a solution in place so that there are no more delays for the future.
    thanks everyone.
    hbaade, FrankJake, riz_atx and 6 others like this.
  5. Jul 12, 2017 at 9:02 PM
    #1625
    OVTune
    OVTune
    The only important part is if the single exit exhaust port matches the FKS. I'm betting it does given Toyotas history of how they do their engines.
    Like the 2gr fe, 2gr fse, 4gr fse etc all use indetical flanges / bolt pattern spanning 10+ years without change.
    It seems Toyota likes to make as little new pieces as possible and re-use anything they can.
    BeaverNation[QUOTED] likes this.
  6. Jul 12, 2017 at 9:19 PM
    #1626
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    any rev hang?
  7. Jul 13, 2017 at 4:21 AM
    #1627
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    Lol, then what were you trying to do with that comment?
    What way did you mean for it to come out?
    trazerr and EubeenHadd like this.
  8. Jul 13, 2017 at 4:30 AM
    #1628
    Toytaco2k17
    Toytaco2k17 Well-Known Member
    Kenneth
    Chapmansboro Tn
    2016 Nissan Titan XD Pro4x Diesel
    Stock
    It's not going to be a miracle. The throttle lag is alot less and it acclerates more smoothly. Getting on the interstate takes less effort. I can hold gears a little better. This is also just the alpha tune. You may want to wait until he has time to work on it more. The tune does make my truck feel more like the 4.0. the 4.0 was no speed demon either. I feel like the tune was well worth it. The good thing is that it's only going to get better with each update.
    maxa and FrankJake[QUOTED] like this.
  9. Jul 13, 2017 at 4:33 AM
    #1629
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Ha, I did the same thing when I was on the Big Island in January. Missed my Taco instantly with all the rough ride on the rough roads - made me really appreciate my Taco's suspension! Still fun though. Enjoy!
    Hawaii loves their Tacos though so it will be hard not to see 100s of them pass you by to remind you of your baby sitting at home waiting for a tune...
    dYL0n[QUOTED] likes this.
  10. Jul 13, 2017 at 4:44 AM
    #1630
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    To expand a bit on what @OVTune said, the mounting of the turbo is the hard part for us, the required tune is what still make the engine work right and get around the shortcomings. IMO Toyota probably went with the small bore long stroke to keep cylinder wall thickness high for longevity and still maintain the displacement. Small bore, long stroke motors are well suited to boost because the turbo can make up for the reduced high rpm breathing that the cylinder wall shrouding the valves causes, while also low rpm the breathing is less effected and the turbo can still spool quickly.
    In our large bore/short stroke motors, the turbo aren't likely to spool as soon(especially because our motor isn't designed with it in mind! ), but that works to our advantage easing the tuning due to the higher compression ratios making tuning much more tenuous at low RPM.
  11. Jul 13, 2017 at 5:11 AM
    #1631
    Egnaro
    Egnaro Watch this
    Brett
    AZ
    16 Inferno DCSB Offroad 4x4
    Ricochet full skids, Mobtown rear with swing-out, toytec boss 2.0, OV tuned
    Do I understand this correctly.... Tacoma Turbo Time!?
  12. Jul 13, 2017 at 5:17 AM
    #1632
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    Millennial here...never mind my 4 year nursing degree I paid for (and am still paying for...)I'm just sitting here in Afghanistan not working for anything I own...
    Guess my house, truck, and everything else was given to me... Tax payer dollars right?
  13. Jul 13, 2017 at 6:22 AM
    #1633
    speedtre
    speedtre Well-Known Member
    DirtySouth
    '17 DCLB TRD OR AT 4x4
    I'm a long time Toyota Truck owner...4 Tacoma's (back to '98 including this one) and 2 Tundra's. I LOVED my '98 Tacoma and loved all the others except for this one. I came from a 2005 Tundra DC TRD 4x4 (RIP). After I totaled it I needed another truck. I test drove a new Tundra TRD CrewMax, and Tacoma TRD DCOR and a Chevy 1500 LTZ (just because they were having STUPID $12K discounts.). The Chevy motor was great, but the rest of the truck was too old-man for me (I'm not an old man yet, at least not in my head), but damn it was ALOT of truck for the money with all the options it came with (it ended up being between the Tundra and Tacoma price wise). So it was down to the Tundra and Tacoma. I actually preferred the Tundra on the short test drive. That motor is just smooooth and the power is great. The interior went on for days. I swear you could have sex in the back seat and the people in the front would not even know it. :D The Tacoma felt cramped in comparison (even compared to my 2005 Tundra) but I live ITP (Inside The Perimeter in Atl) and 75% of my driving is in the city so I didn't really want a truck as big as the new Tundra and I was tired of getting 13 MPG. Ultimately is was the $5K price difference, smaller size and 18 MPG (combined) I expected to get that made me pick the Tacoma.
    So, how does this relate to this tune? Well, at this point, I wish I'd bought the Tundra. I'm getting in the 14s combined MPG with shitty drivability. I HOPE that my truck is a replaced crankshaft position sensor away from getting decent (not great) MPG, but with only 700 miles on it, I'm reluctant to make any big changes, including this tune, yet. If I can get my MPGs up to 18 and make the damn thing DRIVE the way it should, I may be able to love it...I don't need big power (even though it's nice, remember my favorite was a 2.7 I4 Tacoma AC), I just want smoooooth predictable delivery of what is there based on what my right foot is doing. While I'm very appreciative of what OV is doing and I don't think his price is crazy, I'm pissed off at Toyota for building a truck that I'm going to have to end up spending possibly close to $1000 on to make it right (the tune and CPS if I never get on the recall) simply from a driving experience standpoint when I just spent $35K to buy it. :mad: I would consider selling it and getting a Tundra but at this point I don't want to give Toyota any more of my money. Reward bad behavior and you get more of it. At this point I'm trying to decide if I will throw $1000 at it in the next 1000 miles or so to see if I can make it right or if I just drive it as is and wait for the new Frontier or possibly even test drive a new Titan and see if they float my boat.
    OT...millennials...yea, as a generation, they have their own unique issues (like not understanding that tuning an overly rich engine IS tuning for more power...;)), but all generations do. Everyone needs to be treated as an individual. I don't believe in lumping people into negative groups based on things they have no control over. On top of that, the issues the millennials do have as a generation are the consequences of the cultural environment that we (Gen X and Baby Boomers) created for them...so if we want to blame anybody for the "millennials issue's" we probably ought to look in the mirror first.
  14. Jul 13, 2017 at 6:28 AM
    #1634
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    I'm really not sure where the whole "millennials don't work hard" rhetoric came from, I worked damned hard to get my engineering degree and am paying for my truck(and my degree!) myself. Still not working hard enough I guess...
  15. Jul 13, 2017 at 6:41 AM
    #1635
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    My calibration kit will be here tomorrow! :goingcrazy::goingcrazy:
    Toytaco2k17 and EubeenHadd like this.
  16. Jul 13, 2017 at 6:51 AM
    #1636
    tacoflavoredkisses1
    It's a way older folks feel important.
    It's also hilarious, and ironic, that there is this idea that millennials don't take responsibility for anything or are entitled...all the while the previous generations don't seem to be taking any responsibility for having raised us. And God forbid a millennial get promoted ahead of an older person based on merit because "I've been here for years! I am entitled to that spot!"(by function of being a warm body sitting there for years)
    I digress.
    I've also noticed when people make claims about millineals and you call them out, they back pedal so fast. "Oh not you. You work hard!" Or "I didn't mean it like that".
    EubeenHadd[QUOTED] and Doggman like this.
  17. Jul 13, 2017 at 6:55 AM
    #1637
    OVTune
    OVTune
    I am trying to be prepared next round when we start normally offering them.
    have a few things left to test on 1.02. Can't say "yes" yet
    MOC221_[QUOTED] and riz_atx like this.
  18. Jul 13, 2017 at 6:56 AM
    #1638
    speedtre
    DirtySouth
    You mean like I just did, 5 posts above? Don't fall into the trap of doing to others what you don't like being done to you (casting dispersions on a whole group of people based on something they have no control over). Let's just let this generational bashing die....at least in this thread. :D
    FrankJake, bensonxj, Reypac24 and 2 others like this.
  19. Jul 13, 2017 at 6:59 AM
    #1639
    wantone
    wantone Well-Known Member
    Baton Rouge, LA
    2017 TRD Offroad DCLB White w/tech package and 6AT
    DeeZee bed mat, Weathertech floor mats and in channel wind deflectors, Carista, center console tray, tinted windows, LED interior lights, 265/75R16 AT3s, carhartt seat covers, bakflip MX4
    Let's stick to the tune for our trucks, not generation XYZ vs generation ABC. I'm sure we all work hard.
    I've ordered mine and waiting to hear feedback from others that have installed or working on installing.
  20. Jul 13, 2017 at 7:49 AM
    #1640
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    No worries, thanks Mat.
Thread Status:
