Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. May 10, 2018 at 11:22 AM
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    This will only make sense to a few of you:
    OVTune 1.04 91 is like the Yacht Rock of performance tunes; it's so smooth.
    mlventurini and PhogDog like this.
  2. May 10, 2018 at 11:23 AM
    su.b.rat
    su.b.rat broken truck
    we're saying the same thing over in the MT thread. :thumbsup:
    Phich[QUOTED] likes this.
  3. May 10, 2018 at 11:24 AM
    deemiller
    deemiller Active Member
    Dustin
    2017 TRD Pro
    What’s his email?
  4. May 10, 2018 at 11:30 AM
    Toydriven808
    Toydriven808 Member
    2017 Tacoma TRD Sport 4X4 DCSB
    deemiller[QUOTED] likes this.
  5. May 10, 2018 at 11:45 AM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    This is why I keep recommending an ECT mode that shifts into 6th at between 65 and 75 mph depending on load.
  6. May 10, 2018 at 12:04 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Is anyone noticing / have a reason why MPGs are better when it’s warm?
    I assume the engine warms up faster. But I’d think cooler IATs would be better. Who knows?
    peavey02, MOC221_ and bshammer0 like this.
  7. May 10, 2018 at 12:48 PM
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    I know mesojdm has a electronic auto switch that can keep ect on when starting the truck, but can that be enabled in a tune?
    But yeah, i agree, i'd like ECT on to be default (or remembered) upon startup and allow a shift to 6th at 65+ depending on load.
    Did about 200 miles of hilly hwy driving this morning. Head wind was decent and with the cruise at 70 i noticed on certain long up hills it couldn't maintain a speed.
    Be in 6th at 70 (cruise control)
    start up hill, speed begins to slow
    kicks down to 5th
    still slows
    kicks down to 4th
    speeds up to 72ish
    upshift to 5th then 6th
    rinse and repeat.
    Wasn't horrible and i know the oem tune is worse on this front but i still think throttle mapping vs load and shift points needs work.
    I have 750 miles on the 1.04 91 and no clunks that some were referencing.
    treimche and taco abbo like this.
  8. May 10, 2018 at 1:00 PM
    Phich
    San Antonio
    Six Demon Bag
    dingel5 and dYL0n like this.
  9. May 10, 2018 at 1:07 PM
    su.b.rat
    if that's the captain where's Tennille?
  10. May 10, 2018 at 1:08 PM
    Phich
    San Antonio
    Six Demon Bag
    Probably jamming down the beach in a tuned taco!
    su.b.rat[QUOTED] likes this.
  11. May 10, 2018 at 1:20 PM
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    Short answer is yes, @mesojdm makes the mod that keep etc on at all times.
    Longer answer... It uses an adurino set-up to detect the truck has been turned on and then sets the state of the ECT switch to the last setting you chose. This has nothing to do with the ECU or tune. The mod only "pushes" the ECT button for you each time the truck is started.
    honey likes this.
  12. May 10, 2018 at 2:08 PM
    commbubba19
    '23 TRD PRO
    I know how meso's device works. What i'm wondering is if in the ECU, can ECT be enabled to remember last setting used vs default to 0 (which is off)? Only OVTune would have access to see if that information is in a table parameter somewhere. Another option is to find that value and default it to 1 or on.
    WNYTACO likes this.
  13. May 10, 2018 at 3:22 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Anything is possible, it's just how much code it will take to make it happen.
    I wouldn't hold your breath. There are a handful of ECU / TCU related mods that have been requested, such as the locker anytime mod, but none have been mentioned by Matt since development has started.
  14. May 10, 2018 at 4:18 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    My M/T gets better trip average MPG as the weather warms. Quicker warmup is the only thing I can think of.. besides the whole drivetrain/bearings/etc being easier to turn. :notsure:
    Oh and no need for defrost either, so the AC compressor isn't sapping power.
  15. May 10, 2018 at 5:59 PM
    airsickbuffa1o
    airsickbuffa1o Well-Known Member
    Anthony
    2017 Silver TRD OR
    OVtuned 1.03
    I could be completely wrong, but warmer temps means less dense air, which means less fuel is needed to achieve the proper air fuel ratio. This also means less power output in warmer temps.
    This is based on my experience from manually controlling the air/fuel mixture in piston aircraft, they climb into less dense air, less fuel is needed.
    Tharris242 and TFly like this.
  16. May 10, 2018 at 7:03 PM
    go2cnavy
    I only really want ECT active on at highway speeds. I’ve emailed Mat to ask if a custom tune is possible to have shift points for ECT changed with 5th at 55ish and 6th at 65-70.
  17. May 10, 2018 at 7:10 PM
    ToyoDrew
    ToyoDrew Well-Known Member
    Texas
    17 Inferno TRD-OR DCSB 4x4 (SOLD)
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    Personally, I'm not sure that's the best idea because shift points in OVTune are more than just a "shift at x mph". That's what SSP does. Instead, it looks at much more such as the speed, throttle input, load, etc.
    He did say that he's planning to offer custom shift points, so I imagine that you'll have to PM him your specific needs once he annouces he has time to do it.
  18. May 10, 2018 at 7:14 PM
    go2cnavy
    Should have added based on load. What I’d really like is to log my manual shifts with techstream and have mat make my truck shift like me.
    Soul Surfer likes this.
  19. May 10, 2018 at 7:41 PM
    E$Yota
    E$Yota Well-Known Member
    Ethan
    Dothan, AL
    2016 Tacoma TRD Sport 4X4
    FN wheels' version of the TRD Pro 4Runner, TRD Pro front skid plate, Low Range Offroad 3/1 lift, JBA Offroad upper control arms, TRD Pro Shift knob, OV Tuned, 4.88s, 285/70/17 BFG KO2s
    Devil's Advocat... Let's just start swapping Supercharged Tundra 5.7s In these things and our power problems would be forever resolved and then we'd start breaking things! Just kidding but how many likes can this post get?
    dingel5 and treimche like this.
  20. May 10, 2018 at 7:54 PM
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    So I finally ordered mine today and it was in stock :bananadance:
Thread Status:
