Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. May 16, 2018 at 2:15 AM
    Tharris242
    Tharris242 Technically
    Houston, TX
    2017 TRDOR DCSB 4X4 A/T FP TO BL
    Solid Fold 2.0, Air Dam
    FYI: I was just looking through the service manual and came across the idle learning procedure.
    It says idle learning begins when the coolant temperature is 80C/176F or above and that it should idle for 5 minutes with no accessories on (e.g. A/C).
    Torspd, SC4333 and TFly like this.
  2. May 16, 2018 at 9:25 AM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    As a former BMW tech that is FAKE NEWS.
    PNWTacoma, SC4333, KkelX4 and 3 others like this.
  3. May 16, 2018 at 9:30 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That's because you're in 5th gear at 40 mph. How about choosing 4th gear, so the rpms are a little higher and not lugging the engine?
    lapoltba likes this.
  4. May 16, 2018 at 9:32 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :laugh:
  5. May 16, 2018 at 9:48 AM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    I putt-putt around town in 5th too, but when I need to accelerate, I shift.
    Tharris242 and acemastr like this.
  6. May 16, 2018 at 11:10 AM
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    3-4 still pisses me off daily, doing 29mph on my way to work in 3rd gear with the engine "screaming"
  7. May 16, 2018 at 11:25 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    this settled down for me - I just let off the skinny pedal a bit and it'll upshift to 4th most times when not under load then I can coast in 4th at those <35mph speeds generally unless I punch it and put load on
    TRDOBSESSED likes this.
  8. May 16, 2018 at 11:47 AM
    acemastr
    Aaron
    Tampa, FL
    OVTune
    Literally refuses to change until 31mph for me, no matter the load.
    You must have gotten used to it, the tune doesn't learn
  9. May 16, 2018 at 11:48 AM
    winston50
    winston50 Well-Known Member
    Haven't been on here in forever this is nice!
    bshammer0 likes this.
  10. May 16, 2018 at 11:52 AM
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    i still feel that the throttle mapping for each gear is off, mostly between 1-3 and 4-6 which i believe is known.
    for a given throttle positiion from a dead stop, it runs through the gears shifting accordingly with a reasonable rate of acceleration, then when it shifts to 4th, without changing my throttle input, the rate of acceleration is drastically reduced and i feel my head lunge forward. this is even more pronounced when it shifts from 4th to 5th.
    it really feels like 20% throttle in 1-3 feels like 20% but in 4th through 6th 20% feels more like 10%.
    Is this not possible to fix? Honestly, really my only driveability complaint.
    edit: and i do not notice this as much with ECT on, only when off and in D. S5/S6 seems to operate the same as in D in relation to throttle mapping and when it shifts.
    Tharris242, BlkTaco47 and trdsilver like this.
  11. May 16, 2018 at 1:02 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Drivability requests, shift change requests, etc etc all will be able to be adjusted the way you individually like it once custom tuning request is setup and ready.
    As I said in the MT thread I'm implementing an all new system to track customers, requests, etc. No more emailing and waiting, or things getting behind or lost.
    I just need some time to finish it.
  12. May 16, 2018 at 1:20 PM
    redrelyt12
    redrelyt12 Well-Known Member
    Tyler
    2016 Tacoma TRD Sport DCLB
    Derped TRD Sport Grille BAK Revolver X2 Tonneau Cover mattgecko Waterproof LED Hood & Bed light kits Southern Style OffRoad Slimline Hybrid Front Bumper Baja Designs 20" S8 Light Bar Smittybilt X2O-10 Winch Blue 3/4" Shackles
    Anticipating receiving mine tomorrow! :bananadance:
    niko5055 likes this.
  13. May 16, 2018 at 2:44 PM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Yep. My truck is back on 1.03. I just like it better.
    L-SCHLEGS[QUOTED] and Ruggybuggy like this.
  14. May 16, 2018 at 2:48 PM
    bshammer0
    Brandon
    Nashville, TN
    I always get some of my best work done when going nuts on those 14 hour flights to Asia trying something, anything to make me forget how long I'm in a tin can breathing recycled farts! :)
  15. May 16, 2018 at 5:22 PM
    OVTune
    OVTune
    Now I'm going to be thinking about recycled farts the entire trip
    For everyone waiting a reply my plan is to knock it all out tonight
    dingel5, riz_atx, DiabloTRD and 12 others like this.
  16. May 16, 2018 at 5:32 PM
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    The farts only linger for a little while. The air coming in from the engines for pressurization has to go right back out, otherwise the tin can would explode.
    Breathe easy.
  17. May 16, 2018 at 5:44 PM
    n6vmo
    n6vmo Well-Known Member
    Sahuarita, AZ
    2018 DCLB OR AT Super "Priviledged"
    Bilstein 6112, ICON UCAs, 5160, AAL, 265/75/16 Falken Wildpeaks
  18. May 16, 2018 at 5:51 PM
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    I agree with this, 1.04 for me is shifting between gear way to much. 34" tires have some do do with it, but 1.03 was better at holding gears better not jumping around gears so much,
    peavey02 and dYL0n[QUOTED] like this.
  19. May 16, 2018 at 5:58 PM
    Docoma Pro
    Docoma Pro Well-Known Member
    Ken
    Rochester, NY
    2018 Tacoma TRD Pro Cavalry Blue
    OVtuned 1.05 93 Perf,Undercover Elite LX, Subaru/Kicker tweeters
    USPS tracking says delivery tomorrow!:fingerscrossed::bananadance::mudding:
    niko5055 and cruetes like this.
  20. May 16, 2018 at 5:58 PM
    sig916
    sig916 Well-Known Member
    switched back to 1.03 and love it! well, besides the gear dropping at turns.
Thread Status:
