Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. May 17, 2018 at 9:04 PM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    No lift??!!? Look nice though
  2. May 17, 2018 at 9:14 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Icon coilovers in the front to keep it level. I have some AALs that I’ll install when these tires go to shit and I can install bigger tires!
    Chipi3s[QUOTED] likes this.
  3. May 17, 2018 at 9:15 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    Nah, but I make a shitload of electricity.
    Prairie Hawk[QUOTED] likes this.
  4. May 17, 2018 at 11:41 PM
    Thao_209
    Thao_209 Well-Known Member
    2017 Tacoma TRD
    Stock
    The problem is that these 3.5 don't have torque.
    mlventurini likes this.
  5. May 18, 2018 at 8:50 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Those Falken AT3Ws?
  6. May 18, 2018 at 9:01 AM
    mlventurini
    mlventurini Well-Known Member
    Michael
    2017 DCSB TRD Off Road
    Totally agree. I bought my truck to be a suburban hauler knowing that limitation. Can’t make a pack mule into a thoroughbred. Maybe I’ll try to pick up a 2nd vehicle like a older LandCruiser or a full size diesel to scratch that itch.
    Thao_209[QUOTED] likes this.
  7. May 18, 2018 at 9:59 AM
    speedtre
    speedtre Well-Known Member
    DirtySouth
    '17 DCLB TRD OR AT 4x4
    The Tacoma is a thoroughbred that I wish would act like a pack mule...
  8. May 18, 2018 at 10:01 AM
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    lugging a motor at 2k rpms with high load is just inefficient and puts a high mechanical strain on everything. Not sure why folks are so caught up on not having the transmission downshift when necessary. I'd rather the truck shift down when needed but as soon as the load lessens, go right back down. Yes it's a jump in rpms but why does that bother everyone so much as long as you're maintaining speed?
    I've had it where the truck drops to 4th to maintain but only after having to go 50% throttle, and by then the mapping is so different the truck thinks i need to go really fast.
    Hence my issues with the throttle tables in each gear not being the same.
  9. May 18, 2018 at 10:09 AM
    Chipi3s
    San Diego
    I completely agree!
  10. May 18, 2018 at 10:21 AM
    bshammer0
    Brandon
    Nashville, TN
    This.. Running 1.03 yes it did hold 5th and 6th on the highway more for sure and shifted a bit less, but if you look at your manifold pressure / calculated load on a OBD2 device you'll see when it's holding at times you're at a very high load vs. the downshift to higher RPMs to push a shorter gear = much less load on the engine. so long as it shifts when I want it to and is snappy in response as it is with 1.04 I'm fine with some shifting on the highway. my overall MPGs are still better with 1.04 than 1.03 even with bit more shifting on the highway.
    Tharris242 and Reypac24 like this.
  11. May 18, 2018 at 10:23 AM
    bshammer0
    Brandon
    Nashville, TN
    the problem I had was that when I'd push the pedal down the delay to downshift was so horrible (and you're losing speed when this is happening) on a hill then by the time it did downshift you were high in the throttle and jerking into 4th roughly. this doesn't happen with the tune
    ksj, TFly, Reypac24 and 1 other person like this.
  12. May 18, 2018 at 11:30 AM
    commbubba19
    '23 TRD PRO
    I do have this happen with 1.04.
    Example: crusing at 70 mph flat, 6th gear. hit grade. vehicles slows based on given throttle (say 5%). so I push on the pedal more, say 10%, finally it kicks down to 5th, but too late, i've lost momentum, at this point i've slowed to 65 or less. also continuing to give it more throttle, now at 15-20% if not more, now the truck thinks based on load and throttle that i really want to get moving so it kicks to 4th and i accelerate back to 70 but by the time that happens, i'm having to lift as i don't want to go over 70. really, the truck should shift to 5th any time there's a torque request that is anything but flat road cruising. that's all 6th is good for. sometimes i drive in s5 just to avoid it shifting to 6th.
    to me, this feels like inconsistent throttle mapping in each gear. i say feels like because i don't know if that's actually the case.
    holding a gear at high load and low rpm is just something this engine can't do.
    if i'm bored i might go back to stock tune just to see how the truck behaves in this same exact circumstance and give it a few hundred miles to 'learn'. i didn't do that previously for enough time for a good comparison.
  13. May 18, 2018 at 11:55 AM
    dYL0n
    Dyl0n
    New Orleans, LA
    Bfg at
    BT17 and bshammer0[QUOTED] like this.
  14. May 18, 2018 at 12:02 PM
    Thao_209
    2017 Tacoma TRD
    Stock
    Anybody paired with Ssp and the tune?
  15. May 18, 2018 at 1:49 PM
    Chipi3s
    San Diego
    Yeah a few members. I believe everyone with the ssp tossed it abd stuck with tune. Pointless to have both since matt is offering custom shift points/tunes
    dYL0n likes this.
  16. May 18, 2018 at 1:50 PM
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
    Bingo. Sold my SSP after going to v1.01 of the tune.
  17. May 18, 2018 at 3:58 PM
    turtle.sc1
    turtle.sc1 Active Member
    2017 TRD Sport
    Magnuson S/C
    Got this from Ovtune in messenger “Hi, Mike. Mat (the big boss) is unavailable for a few days. Once he's back to working condition, I'll make sure that we get to help you. - Rafael”
    Prairie Hawk likes this.
  18. May 18, 2018 at 3:59 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Such an exotic sounding name
  19. May 18, 2018 at 4:20 PM
    Docoma Pro
    Docoma Pro Well-Known Member
    Ken
    Rochester, NY
    2018 Tacoma TRD Pro Cavalry Blue
    OVtuned 1.05 93 Perf,Undercover Elite LX, Subaru/Kicker tweeters
    Anyone having luck installing this new tune without the dongle? Gotta admit, reading through the instruction pdf from the OVTune website has left me a little confused. Partly because I'm a Mac guy (got a Windows 10 loaded PC through Amazon for $200 that I haven't yet unwrapped) and partly because he hasn't written any new "no dongle" instructions. Still have 12 hours left of my 24 hour shift so I'll be starting from scratch when I get home in the morning. Hoping others who just received their kits chime in!
  20. May 18, 2018 at 4:26 PM
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    So just now getting around to setting the Tune up - I'm getting the "USB dongle is not accessible" error - what did I mess up and what do I need to do to get the "dongle serial number"?
    My computer sees the Guardant Code USB and I can open the properties so I know it is accessible...
    Any help is appreciated!
    cruetes likes this.
Thread Status:
