Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jun 9, 2018 at 4:10 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    FM update soon
    the TCU file controls transmission fluid pressure, shift timers based on temp, things like this.
    The new TCU file will have changes for :
    upshift timing delay (all gears). Shift timing lowered based on temp so the transmission feels less laggy during high rpm shift
    upshift timing when cold. To me the transmission feels a bit pooey until it's hot.
    and some pressure manipulation (slighty) for 4wd
    SpeySquatch, peavey02 and dingel5 like this.
  2. Jun 9, 2018 at 6:53 AM
    perkj
    perkj Well-Known Member
    @OVTune "FM update soon" meaning FM will be updated to support both dongle and dongle-less with the same FM version?
  3. Jun 9, 2018 at 7:33 AM
    NOLAMedic
    NOLAMedic Well-Known Member
    2018 Quicksand DCLB TRD Off Road
    took my truck on a road trip and had a couple of questions. I have your most recent update for the OVTune on my 2018 Tacoma. Here's what I noticed. When the truck downshifts to 4th, as in going uphill, it will stay in 4th even when I start going downhill or the road levels. For....a WHILE. However, I've noticed if I tap the gas as soon as I crest a hill or get on a level road it will upshift to 5th or sixth. I have 255/85/16 cooper discoverer ST tires but that is my only mod.
    TFly likes this.
  4. Jun 9, 2018 at 8:06 AM
    NPulver
    NPulver Active Member
    Black Hills
    10' DC Tacoma TRD
    ProComp 3 inch Lift, 255/85/16
    The factory setting is that exact same way, has nothing to do with what OVtune has done. Drives me nuts when it sticks itself at 4k rpm for way longer than it needs to. Also hate how it likes to downshift and jump to 4k when a simple single gear down would do the trick.
    TFly likes this.
  5. Jun 9, 2018 at 8:08 AM
    NOLAMedic
    I see. Do you have a third gen as well? Thanks for the input by the way. Maybe Toyota will come up with a fix.
  6. Jun 9, 2018 at 3:48 PM
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    Not looked at this thread for a while.
    Did I just read that there's a new TCU file coming?
  7. Jun 9, 2018 at 5:04 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Yes
  8. Jun 9, 2018 at 7:02 PM
    Arpatton86
    Arpatton86 Well-Known Member
    Ontario Canadia
    2017 DCSB TRD OFF-ROAD OV TUUUUNED
    @OVTune, just curious is there anything that you can do with the tune that would enhance the cruise control? I feel like a lot of issues with the truck sticking in 4th is when cruise is being used.
    riz_atx and Reypac24 like this.
  9. Jun 9, 2018 at 7:07 PM
    OVTune
    OVTune
    Nothing on cruise control yet. Once I get my truck back I will be finalizing the changes made to the 16 way 3D power demand tables. (development I talked about a long time ago.. the "power map"), which will be 1.05 release. It has taken a long time due to the complexity.
    and working on boost tuning.
    hbaade, riz_atx, Reypac24 and 9 others like this.
  10. Jun 9, 2018 at 7:10 PM
    tjpratt
    tjpratt Well-Known Member
    Travis
    Aurora, Colorado
    2016 Limited 4X4 Tacoma
    3.75" Lift / OME OVTuned
    Any ballpark ETA on 1.05?
  11. Jun 9, 2018 at 7:14 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Any ballpark on how much the turbos will cost? I'm asking for a friend ;)
  12. Jun 9, 2018 at 7:19 PM
    BlownOutTaco
    BlownOutTaco Well-Known Member
    Shane
    2018 Black DCLB OR
    @OVTune check engine light is on after shop put on bigger tires (running fine however).
    Tune was loaded a couple months ago, I think I’m on the latest version. Love it.
    Any idea if it could be tune related? Worth reflashing? Just asking before bringing to dealer so I’m prepped.
    Thank you!
  13. Jun 9, 2018 at 7:34 PM
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
    What do the CEL codes say? You sure it's not the TPMS light?
  14. Jun 9, 2018 at 7:55 PM
    BlownOutTaco
    Shane
    2018 Black DCLB OR
    Shoot... I wish. Engine symbol with “CHECK” under it. Can I check CEL codes myself somewhere?
  15. Jun 9, 2018 at 8:02 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    Autozone.
    Or carista dongle with an app on your phone.
    Or reset it using PCMflash and act like it’s not there (clear DTC)
    BlownOutTaco[QUOTED] likes this.
  16. Jun 9, 2018 at 8:28 PM
    Bigmike2017
    Bigmike2017 Member
    2017 Barcelona Red TRD Sport 6speed
    Autozone? just take you lap top that you just tuned your truck with you can check DTC codes and clear them.
    BlownOutTaco likes this.
  17. Jun 9, 2018 at 8:58 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    How do you check it?
  18. Jun 9, 2018 at 8:59 PM
    BlownOutTaco
    Shane
    2018 Black DCLB OR
    Really? I’ll try anything twice... how do you do that?
  19. Jun 9, 2018 at 9:08 PM
    OVTune
    OVTune
    load flashing software click "READ DTC"
  20. Jun 9, 2018 at 9:36 PM
    BlownOutTaco
    Shane
    2018 Black DCLB OR
    Perfect thx Matt. Will try
Thread Status:
