Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jun 29, 2018 at 10:46 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    That last bit sounds like something us M/T guys can also sink our teeth into!
    :drool:
  2. Jun 29, 2018 at 11:10 AM
    BigD1
    BigD1 Active Member
    D
    2016 BBP Tacoma DC LB OR
    So as GoldenBrew noted and put a link to the check your fluid level notes, that works for topping off or a little change. I opted to do a complete drain and refill basically using this video as a quide. https://www.youtube.com/watch?v=TF1EQc4A0Hk
    Also had read the notes from the Tacoma service manual, it was a pretty straight forward job, just had my wife to give me a hand when it was time to start and stop the truck, and I used Techstream to watch the Trans temperature, although some folks have a ScanGauge.
    As a side note, I've not had any problems at all after following pretty much the way it was presented in the youtube video. Only difference my fill plug is opposite side than his
    tjpratt[QUOTED] likes this.
  3. Jun 29, 2018 at 12:14 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    Did you measure the amount of fluid drained and amount replaced? Just wondering if you were low, and how much to fill with complete drain/fill option. Would think trucks with same options (auto/trans cooler-tow package,...) should be able to simply do a drain and fill based on measured results. ???
  4. Jun 29, 2018 at 1:12 PM
    Reypac24
    Reypac24 NRA Member
    Mr., but friends call me Sir.
    Republic of Texas
    2017 DCSB Limited 4x4 (SOLD)
    04B04. OV Tune # 1857 dongle 1.04r 91 octane. Nitto Ridge Grapplers 265/60/18. SaBellCo Tailgate Lock. Meso Customs TRD coin holder, gasshole. Tacomods black anodized aluminum radio knobs. Lock'er Down Console Safe. Sig Sauer P238 Desert. Escort Passport 9500i Radar/Laser Detector.
    When you put it that way this comes to mind.
  5. Jun 29, 2018 at 1:29 PM
    BigD1
    BigD1 Active Member
    D
    I did measure both drain and refill with one caveat. Used two clean 5 quart marked pails (one for drain, one for fill) and a 5 gallon marked for overall drain. Mine was only exhibiting minor characteristics of being low, so now for the caveat, when I reached the point of exchanging the fluid (for my truck 10.7 quarts), I added another 1.5 quarts (overfilled) and started the truck long enough to circulate through the gears, then open the overflow and drained out about a quart until what was coming out of the overflow was down to a thin stream, closed it up, fired the truck up and run through the gears and watched the temperature in Techstream until it hit the temperature range, then shut the truck off, quickly opened the overflow and only drained out 6 - 8 ounces. So giving myself a little wiggle room, I purposely overfilled to make sure I got a complete fluid exchange, and given the little amounts in the buckets of the drain and fill buckets, I'd say a guess probably 4 - 6 ounces low originally.
  6. Jun 29, 2018 at 1:41 PM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Tell me more about this 1.05 power map :spending:
    dYL0n likes this.
  7. Jun 29, 2018 at 1:42 PM
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    His horrible what?
    dskakie, mZiggy and catastrofe like this.
  8. Jun 29, 2018 at 1:56 PM
    joey.taco
    joey.taco Well-Known Member
    2018 Toyota Tacoma OR DCSB
    1.05 update plus the Turbo setup.... :bananadance:
    Shellshock and Chipi3s like this.
  9. Jun 29, 2018 at 1:57 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Nah, we just think there could be something hiding underneath if someone prefers the stock tune over any OVtune...
    I mean I won't say the truck is 100% perfect, but then again every vehicle I've had STOCK had its quirks. A Rav4 that would drop to 3rd harshly when in cruise and sounded like the trans would fall apart. it didn't. I drove it to 200k and it's still on the road today with over 250k (sold to friend). An Xterra that flared in 4th all the time unpredictably. It was totaled in an accident but had 175k with no issues whatsoever.
    So yes, my OVTuned truck runs 150% better in almost every single way vs. stock. Are there a couple of minor tweaks I'm excited to see come in the future, yes. Are they anything beyond the quirks most of the best built vehicles will have, no. But I am thankful every time I get in my truck that I don't have to put up with that garbage Toyota called a "calibration" :)
    did you ever get your OVTune sold?
    speedtre, inksin, GoldenBrew and 2 others like this.
  10. Jun 29, 2018 at 2:49 PM
    GoldenBrew
    Golden, Colorado
    I'd do the math but pretty sure I would make a bad guess. So added total of 12.2 quarts and drained 1.25?? So fluid volume left 10.7 quarts???
    Is your truck an OR 4x4 with tow package?? Auto ??
    EDIT: I will be taking this conversation to the 3rd gen transmission thread = Back on track here for OVTUNE !!!
  11. Jun 29, 2018 at 3:08 PM
    dagsamp
    dagsamp Unknown Member
    Marla
    16' TRDOR DCSB OV Tune
    OV Tune
    I just flashed V1.04. How do the updates work? Does Matt just send out the new updates or do I need to ask for it?
  12. Jun 29, 2018 at 4:04 PM
    Reypac24
    Reypac24 NRA Member
    Republic of Texas
    @dagsamp He will post when one is available
    dagsamp likes this.
  13. Jun 29, 2018 at 5:10 PM
    BlownOutTaco
    BlownOutTaco Well-Known Member
    Shane
    2018 Black DCLB OR
    :thumbsup:
  14. Jun 29, 2018 at 5:18 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Hey mat, if you could give a ballpark number on what the turbo thing would cost, that'd be great so I know how much money to hoard for the next few months
    Chipi3s, redrelyt12 and joey.taco like this.
  15. Jun 29, 2018 at 5:28 PM
    joey.taco
    Yup, same here.!!!! Plus is the OVtune Software package going to be compatible with the new F/I tune software?
  16. Jun 29, 2018 at 5:42 PM
    SpeySquatch
    2016 TRD OR DCSB
    @OVTune will 1.05 work well for people with a little armor and slightly bigger tires? I like 1.03 over 1.04 for the sole reason that my truck feels more nimble and lighter when driving or towing. I’ve driven both files for over 1000 miles each and 1.03 has me for now because it just drives with what feels like more power. Is one tune healthier for the vehicle over another?
  17. Jun 29, 2018 at 7:20 PM
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    Does any1 else just scroll through to fine OvTunes posts LOL :thumbsup:
    I mean, his posts are the most relevant anyway rights ;)
    Egnaro, peavey02, hr206 and 6 others like this.
  18. Jun 29, 2018 at 7:26 PM
    Taco16LB
    Taco16LB Well-Known Member
    Just search for them like below, I too do it .
    https://www.tacomaworld.com/search/6373117/
    2016trdtacoma[QUOTED] likes this.
  19. Jun 29, 2018 at 8:00 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    I'd consider it a greatly enhanced version of 1.03. lower RPM (1200 and up) will be a very big improvement.
    but it's not done yet. No eta on release yet. 1.05 will come with new version TCU file.
    Regarding turbo kit price I don't know yet sorry. I'd say expect around what other kits would cost. Ball park 5-6k
    sig916, jholc21, 2017TRDpro and 17 others like this.
  20. Jun 29, 2018 at 8:37 PM
    2016trdtacoma
    Trevor
    Utah
    VERY much looking forward to 1.05 based on your comments previously :)
    I would still like to get the lower RPM torque a bit higher and it sounds like you have it nailed down.
    Seriously Matt, well done and thank you for your efforts! This truck is an absolute dream compared to stock.
Thread Status:
