Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jul 22, 2017 at 7:25 PM
    #1941
    Ares32
    Ares32 Well-Known Member
    America
    2016 MGM TRD off road DCSB M/T
    Agree 100%, -10/+10 is usually the benchmark for what the ecu can easily compensate for adjustment. Is it idea, i would say no. I am anal though and like to be closer to 0 when i can even though its almost impossible to be always be @0. I have always personally used MAF tables for adjustment. They use stock mass air flow sensor over a voltage range of zero to 4, 5, etc volts depending on application. These tables represent the mass of fuel to the amount of air moving through the intake. The values allow the ecu to properly calculate the mass of fuel it needs to inject or remove to get the A/F value dictated in the Primary fuel table for closed loop WOT control targets. Ecu airflow adjustments table is usually based off the mass airflow, GS per second. The data in the MAF tables represent air in grams per second to voltage. Usually but no always this is the only table for the purpose of adjusting MAF cal values for intakes. Once you hit larger intake diameters then yes the calculation across the entire table needs to be scaled and then re adjusted and fine tuned based on air/fuel.
  2. Jul 22, 2017 at 7:26 PM
    #1942
    Ares32
    America
    Correction, i ment to say MAF tables not fuel trim table.
  3. Jul 22, 2017 at 7:35 PM
    #1943
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    so will you
    So after you get it tuned to compensate for the intake will you get more power over stock air box?
  4. Jul 22, 2017 at 7:38 PM
    #1944
    Ares32
    America
    Yes. Any time you can add more mass air flow and more fuel you gain more power. All in the tune...
    Tacoma2GR[QUOTED] likes this.
  5. Jul 22, 2017 at 7:41 PM
    #1945
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    Nice!
    Do you have the aem air filter size or part number ? I was thinking of getting the same AF Dynamica set up to save money over the K&N
  6. Jul 22, 2017 at 7:49 PM
    #1946
    Ares32
    America
    Unfortunately no part #. I had a few extra dryflows from old intake setups and found one that fit perfect. Pure luck haha. I will pull a measurement next time im in the bay.
  7. Jul 22, 2017 at 7:49 PM
    #1947
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    Thanks Bro!
    Ares32[QUOTED] likes this.
  8. Jul 22, 2017 at 8:40 PM
    #1948
    Egnaro
    Egnaro Watch this
    Brett
    AZ
    16 Inferno DCSB Offroad 4x4
    Ricochet full skids, Mobtown rear with swing-out, toytec boss 2.0, OV tuned
    So after a day of driving around town, on the freeway, in the city stop and go I have some impressions of the tune.
    To be quite honest the first few miles you could have fooled me, I even considered placebo effect maybe. Then after awhile I started to notice that I wasn't pushing down on the gas as much to get the acceleration I got from before the tune. That's about it. No huge changes. I'm not totally in tune with the shift points like some are but I did feel that the truck did seen to hold a gear longer. If I didn't install the tune myself I probably wouldn't have noticed any difference. It's not more power really, just less gas pedal to get the power.
    My biggest thing was that I liked the way power kicked in around 4k before the tune and I expected that to even out. Now it seems to maybe kick in around 3.5k but still after 4k the power feels good. If there was only a way to boost power under 3k this would be a fantastic truck. It feels like a 4 banger under 2.5k.
    Then I pushed the ECT button. That's when I could totally feel a difference. Very responsive throttle. I haven't really used that button before because I'm not fooled thinking this truck is a power house and was under the impression that button was just a gimmick. I bought the tacoma for off-road driving and you don't need gobs of power for the slow speed trail driving I like to do and a button that keeps you higher in the rpm range isn't what I want. Using ECT is where I see a difference with their tune though.
    Is this tune worth the money? It's not like adding a turbo. There is not a big power gain especially lower in the rpm range where I was hoping for. I know it's a little v6 but I'm still optimistic.I look forward to version 1.02 and their tranny update. Until then I'm not sure I would say "dude you gotta get it". Maybe after those updates.
  9. Jul 23, 2017 at 3:47 AM
    #1949
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    Thanks for posting the data. A bit concerning since I'm running a TRD Pro CAI and catback. BTW, how did you run the datalog? I would like to do the same after I upload my tune. Thanks.
    Ares32[QUOTED] and Egnaro like this.
  10. Jul 23, 2017 at 4:22 AM
    #1950
    Egnaro
    Egnaro Watch this
    Brett
    AZ
    I haven't ran datalog. I'll have to look into this. My truck is stock for all the engine stuff. I spent all my monies on skidplates and lift kit waiting for this tune.
    Ares32 likes this.
  11. Jul 23, 2017 at 4:42 AM
    #1951
    DontPanic
    DontPanic Well-Known Member
    VA
    Hopefully aggressive throttle tip in/"cam" factor comes back out as this tune moves out of "alpha". You see it all the time in the "Import Scene" tunes. Lots of throttle tip-in to make a vehicle feel faster to the customer. This can be done quickly without a lot of effort. Tunes like that will actually perform worse in track settings as abrupt throttle will "upset" a car and make weight transfer more difficult to control.
    Egnaro[QUOTED] likes this.
  12. Jul 23, 2017 at 7:25 AM
    #1952
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    I know exactly what you mean, but its apples to oranges... that really only comes into play on the track, or driving at or near the limits of the suspension. Who is going to be doing that in their Tacoma? Yes off road throttle control to not upset the suspension comes into play as well, but that's not about being fast just smooth and much lower in the power band where there's less power.
    $.02
  13. Jul 23, 2017 at 8:13 AM
    #1953
    Ares32
    America
    Personally I wouldnt run any tune without data logging and seeing exactly how my engine is running, engines are expensive. At the moment Im using the simple Torque app to monitor and datalog. Wish I could monitor more parameters, knock, fuel pressure, etc. OVtune is supposedly working on datalogging ability but I guess they are still figuring it out.
    dYL0n likes this.
  14. Jul 23, 2017 at 8:17 AM
    #1954
    speedtre
    speedtre Well-Known Member
    DirtySouth
    '17 DCLB TRD OR AT 4x4
    Thanks for posting, this is the sort of info I'm looking for. I think this motor makes plenty of power...I don't need more power. I'm just not digging the throttle response, low end power delivery, transmission shift points and the MPG. I'm not convinced it's an architectural issue with the motor/tranny (like the people who claim it's "not a truck motor") and I'm really crossing my fingers OV (or someone else) can sort this out in the next few months or I'm going to be trading in a very low mileage Tacoma on a Tundra or similar.
  15. Jul 23, 2017 at 9:15 AM
    #1955
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    The original Tacoma he tuned had a TRD intake and exhaust as I recall. You're fine.
    Deucer01[QUOTED] likes this.
  16. Jul 23, 2017 at 9:21 AM
    #1956
    su.b.rat
    su.b.rat broken truck
    is that right? i missed that. i have both but i also feel there's quite a bit of optimization available. up till now i figured it could be the intake/exhaust difference, but apparently not.
  17. Jul 23, 2017 at 11:38 AM
    #1957
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
  18. Jul 23, 2017 at 4:52 PM
    #1958
    Egnaro
    Egnaro Watch this
    Brett
    AZ
    So I keep hearing people talk about the ecu "learning" and I wonder how this plays into how the tune will work. Is learning just a subtle thing that happens or after a certain about of time will I notice the truck behaving different than my first day of driving with the new tune. I used about a half a tank of gas yesterday.
  19. Jul 23, 2017 at 5:51 PM
    #1959
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    it wont behave wildly different or anything no, but after all the learning phase for fuel and ignition the ecu will be able to run the most optimal settings.
    our Tacoma logger is almost complete as well. Also, we are considering...*something*... that a lot of toyota people are starting to request. I just talked about this a few days ago too lol
  20. Jul 23, 2017 at 5:55 PM
    #1960
    rnicholls
    rnicholls Well-Known Member
    2016 TRD OR DCLB
    :goingcrazy::goingcrazy::goingcrazy:
    Egnaro likes this.
Thread Status:
