Tacoma Pinging Spark Knock Noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mattstaco97, May 17, 2022.
  1. May 17, 2022 at 11:23 PM
    mattstaco97
    mattstaco97 [OP] Member
    2005 Tacoma Pre-runner TRD-offroad
    I have a 2005 Tacoma Prerunner V6. So I noticed the "spark knock" for a while now and have continued to drive on it. Ive tried many things to eliminate the sound but none have really helped. My Catalytic Converter went out so I Bought OBX long tube headers and a URD 02 simulator. That didnt make a difference. I have Cleaned air filter, cleaned Maf sensor, Cleaned PCV. Ive tried fuel cleaner, injector cleaner. And none of that really helps. The spark knock sounds like BBs in a can or rattling. As soon as i let off the throttle it stops. The sound comes on only when the Engine is underload or climbing up hill. but it happens most the time when accelerating now. My Brother has a 2008 Tacoma and I notice it very slightly when his Tacoma shifts but it is nowhere near as loud as mine. I dont know if theres a tune that I can get to stop this. I got a Tune from JustDSM but that didnt help and was wondering if he could retard timing. Higher Octane gas helps a little. Im starting to think its something mechanically wrong with my truck. So my question is: What else can I do to get rid of spark Knock? How can I go about diagnosing it? Code Reader Live data?
    Here is a Video of the Pinging:
    https://www.youtube.com/shorts/4cUZxcAdxs0
  2. May 18, 2022 at 12:34 AM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    what kind of plugs are in?
  3. May 18, 2022 at 7:37 AM
    mattstaco97
  4. May 18, 2022 at 10:36 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you gotten back with @JustDSM with your logs and gotten his thoughts, he should be able to tell with the logs if the timing needs to be tweaked.
  5. May 18, 2022 at 11:15 AM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    I don't know if knocking is a potential problem for using Iridiums instead of copper in a V6.
  6. May 18, 2022 at 11:32 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Sounds like a valvetrain issue, not spark knock. How many miles are on the truck?
  7. May 18, 2022 at 7:49 PM
    mattstaco97
    119000
  8. May 18, 2022 at 7:50 PM
    mattstaco97
    I have a OBD2 reader. Would i need to set certain parameters when datalogging or just keep the default parameters?
  9. May 18, 2022 at 10:02 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Oh I was thinking you had a MPVI2 since you were tuned, I believe you want to look at knock feedback and knock learned value but I don't think you be able to see those data parameters on a generic scan tool.
    There was some discussion about knock feedback and normal values here.
  10. May 18, 2022 at 10:56 PM
    mattstaco97
    If I buy a mpv12 tuner would I be able to monitor it and send logs? Or should I just get in touch with JustDSM. I got the truck tuned about 6 months ago in Phoenix Arizona. It was a group tuning session ran by someone who works with JustDSM. Anyway I can monitor the feedback knock. I had a Subaru WRX and would always monitor those values on the Cobb accessport
  11. May 19, 2022 at 3:18 AM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    I've been using denso iridiums for years and it has never caused a problem with knock. Don't think that is the issue.
  12. May 19, 2022 at 8:32 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yes you would but it's not the only thing that can view those parameter, you need a scanner that can view manufacturer specific data.
    I would get in contact with JustDSM and get his thoughts, he knows a ton about the tuning in our trucks.
  13. May 19, 2022 at 11:49 AM
    BKinzey
    Beauford
    Hollywierd, CA
    There are plenty of threads on TW debating the use of iridiums vs copper in the V6. What I don't recall is if knocking is one of the potential problems.
  14. Apr 19, 2023 at 12:53 AM
    mattstaco97
    Truck is still pinging. Wonder if I should do the cam gear mod or try to get in touch with JustDSM again for tuning
