Tacoma Power Antenna Install?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gronk, Aug 16, 2007.
  1. Aug 16, 2007 at 6:23 PM
    Gronk
    Gronk [OP] Member
    07 TACOMA TRD SR5
    Has any one installed a power antenna on an 07 Tacoma? If so is there any plug in or must power come from radio removal.......? Thanks
  2. Aug 16, 2007 at 10:15 PM
    pb2themax
    pb2themax Mod Master
    TRD Sport 4x4
    That would be a pretty custom job. Mounting it would require some modding, and some electrical work would be in order too.
  3. Aug 17, 2007 at 1:50 AM
    reid
    reid Well-Known Member
    Vancouver BC Canada
    2007 V6 Access Cab
    Magna Flow stainless cat-back, 3" Toytec Lift, 32" Mickey Thompsons
    I have done it on an old muscle car. It was easy. You can buy them almost anywhere. The one that I installed mounted in the original hole. It took power from the radio. When you turned on the radio the antenna would go up, then down when power went off.
    The secret is that radios use dual positive wires. One positive to run the radio when it is turned on and one positive to keep all of your preset stations and clock memory when it is turned off.
    The one I bought came with instructions and installation went smooth. The only thing to watch out for is you need about 8" of room below the antenna hole for the motor.
