Tacoma problem starting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mike06toyota, Mar 31, 2015.
  1. Mar 31, 2015 at 7:38 AM
    Mike06toyota
    Mike06toyota [OP] Well-Known Member
    Santa Clarita
    06 PreRunner TRD Sport
    K&N Intake Flow Master
    Hello all, I have been having problems starting my Toyota on and off for about two weeks. When I turn the key I get a quick sound like its trying to turn over then nothing, no clicking no turning over just nothing. So I turn the key to off and try again, then it starts up on the second attempt always. This has happened twice in about 2 to 3 weeks.
    What do you think this can be? I just changed the battery about a year ago and I have a good quality battery in there now.
    Thank you all in advance.
  2. Mar 31, 2015 at 7:42 AM
    TakoJim
    TakoJim Well-Known Member
    Chula Vista, Cali
    2015 PreRunner Limited
    TRD STICKER ON BEDSIDE
    How old is your battery? If it's fairly new, your starter is about to give up. I had the same experience, ended up replacing my starter. Problem solved.
  3. Mar 31, 2015 at 8:12 AM
    Mike06toyota
    Santa Clarita
    About a year old, thank you very much for your answer. How bad was the change out? Is there any way to test the starter?
  4. Mar 31, 2015 at 9:34 AM
    TakoJim
    Chula Vista, Cali
    I'm not sure how to test the starter, but by acting up like that it must be the starter. The change up took me about two hours I always take my time especially if its my first time. I took my old one to Pep Boys and they match it if they are the same shape like bolt location.
  5. Mar 31, 2015 at 12:02 PM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    I thought auto zone could check starters? Or is it alternators?
  6. Mar 31, 2015 at 5:54 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Any chance it is a key problem with the Toyota Immobilizer System?
  7. Apr 1, 2015 at 7:10 AM
    Mike06toyota
    Santa Clarita
    I don't think so because I try again right after and it starts right up.
    I really think it could be the starter and or starter relay.
  8. Apr 1, 2015 at 7:22 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    typically it is just the copper contacts on the starter eroding away
    the starter plunger is designed to slap those contacts together at lighting speed
    (literally) because the amps are huge and a big spark is created each time you start.
    despite the high-speed slap of the plunger...
    there is always a spark that vaporises some copper, and over time the contacts
    get cruddy/crappy/start to weld together and ....you need to change the copper contacts
    at a minimum.
    with some socket wrench extensions and a flea-bay copper plunger and contact kit, you can
    do this yourself. yank starter, replace contacts, good to go.
    something like this. be sure to cross-check for your exact starter as the kits are slightly different
    when you crack yours open you will see one of those (usually the dog-leg curved one) little contacts worn paper thin,
    and the plunger copper ring may also be a bit thin
    http://www.amazon.com/Starter-Rebui...=2013:toyota:tacoma&keywords=starter+contacts
  9. Apr 3, 2015 at 2:33 PM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
  10. Apr 3, 2015 at 3:16 PM
    jsmit357
    jsmit357 Active Member
    Jared
    TN
    TRD SPORT 4X4
    Give that starter a good smack
