Tacoma ProCharger
Discussion in 'Performance and Tuning' started by kiloromeo4, Nov 23, 2019.
  1. Oct 26, 2020 at 6:18 AM
    #281
    Smokehouse
    Smokehouse Procharged
    Zach
    Republic, Missouri
    2007 Super White Tacoma Sport
    Hey Rob, @JustDSM is the tuner you're referring too and he is who PhoS and I have been working with on our kits. He was able to do wonders on my truck and I'd recommend him to anyone.
    Welcome to tacomaworld!
    Lord Helmet, ebuyaer2002 and JustDSM like this.
  2. Oct 26, 2020 at 8:15 AM
    #282
    Bbp rob
    Bbp rob Member
    Rob
    2007 Tacoma
    URD TCAI Cam gears OBX headers/y-pipes Tuned with HP tuners It's a ripper!!
    Smoke House, are you still using the supplied booster pump? Or have you already installed a proper fuel pump?
    The procharger web page is not very clear on what one gets with the full kit, or with tuner kit?
    What tuner came with the tuner kit? And can it have new tunes programed into it? Can tunes be switched? On my 6.0 diesel, I had a few tunes, which was very nice, and I could switch when I wanted or needed.
  3. Oct 26, 2020 at 8:18 AM
    #283
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    Yes you can get it tuned here via Justin. The tuner kit doesn't include fuel injectors, fuel pump, or a tuning device(HPTuner). So you would need to buy those separately.
    Torspd likes this.
  4. Oct 26, 2020 at 12:21 PM
    #284
    Smokehouse
    Zach
    Republic, Missouri
    I do still have the fuel pump booster but I will be upgrading in the future. I'm a full time college student so the truck is on the back burner right now.
    The full kit gets the blower, airtake and inlet, all the tubing required, One of the two intercooler options (the winch interior cooler is taller but not as long as the non winch intercooler.), 525 cc FIC fuel injectors, fuel pump booster, and an HP tuners RTD device with a procharger tune.
    Tuning kit is the same exact kit just without the fuel injectors, fuel pump, or RTD device.
    If you get the full kit you will need to purchase an MPVII device as well as necessary credits (4) from HPtuners to get new tunes loaded by justin or any other tuner. You can have multiple tunes as they are just files but to switch them you'll need your laptop, internet, and the MPVII device everytime you change
    I believe @PhoS mentitioned he actually ended up spending more than the full kit once he bought the fuel pump, injectors, and tuning but if you were going to change them down the line anyway you might as well get the tuner kit
  5. Nov 21, 2020 at 12:14 PM
    #285
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Hypothetically, how much work would it be to change from a TRD supercharger to a Procharger setup?
  6. Nov 21, 2020 at 12:43 PM
    #286
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    The install guide is available on prochargers site. (To reference and see if you are missing anything)
    But I'd say the biggest thing is if you still have all the stock parts from pre s/c.
    But if you were changing injectors from the s/c ones to ones in the prochargers kit (or other ones) it wouldn't really be all that much work. Just instead of removing stock parts it's removing the s/c parts and replacing them with stock stuff.
    Imo at least. :)
  7. Nov 21, 2020 at 12:49 PM
    #287
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I do have my stock stuff. I’m curious what stock parts would need to be replaced for the Procharger setup.
  8. Nov 21, 2020 at 1:07 PM
    #288
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Probably upper and lower intake manifold has to go back on.
    JuanitoBonito[QUOTED] likes this.
  9. Nov 21, 2020 at 2:47 PM
    #289
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    This.
    Plus pulling the coolant manifold spacer off. Other than that, it should be an easy swap.
  10. Nov 21, 2020 at 2:48 PM
    #290
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Hypothetically, how long until this happens?
    Smokehouse likes this.
  11. Nov 21, 2020 at 2:49 PM
    #291
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I'd really like to see someone with a built engine, install this kit and push its limits.
    @81Trekker.
    RedLantern likes this.
  12. Nov 21, 2020 at 2:58 PM
    #292
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Who knows. Since I saw this kit in its infancy I liked it. However, I had my TRD blower already. I forgot about this thread and now after catching up it’s something I just thought of. Seems like I’d have to swap the fuel pump too from my 255 wahlbro.
    Torspd[QUOTED] likes this.
  13. Nov 21, 2020 at 3:20 PM
    #293
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That fuel pump would be fine.
  14. Dec 8, 2020 at 12:11 PM
    #294
    Smokehouse
    Zach
    Republic, Missouri
    Well this morning when I turned my truck on to leave I had a very concerning ticking sound that can be heard below. Popped the hood and I get to see a wonderful sight.
    It looks to me like I've got some belt damage issues :annoyed:
    https://youtu.be/6ns3ZARFB94
    oh and if anyone is wondering the procharger kit uses NGK 4902 spark plugs gapped to 32
  15. Dec 8, 2020 at 12:47 PM
    #295
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    I found that the pulley alignment is less than perfect out of the box. I ended up buying the Gates laser alignment tool and adding some spacers to some of the pulleys to correct it. You need to fix the alignment or it will keep chewing belts.
  16. Dec 8, 2020 at 1:25 PM
    #296
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Yikes hopefully they get that worked out with their kit. I imagine that would piss someone off to spend that much $$ only to have to buy spacers to fix alignment issues.
  17. Dec 8, 2020 at 1:34 PM
    #297
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    The only thing I'd be concerned with is fuel. I could see it running into a lean issue cause "injector" lol
    Zim
    I'm planning for this.
    daltondrose likes this.
  18. Dec 8, 2020 at 3:17 PM
    #298
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Their injectors they supply are pretty good.
    Tacman19[QUOTED] and 1slow4.0 like this.
  19. Dec 8, 2020 at 6:06 PM
    #299
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    Made some juice today. This build has been quite the saga but it was worth all the effort. :burp:
    HP 374.94 @ 5.58
    TQ 366.46 @ 4.95
    10.37PSI @ 5.52
  20. Dec 8, 2020 at 6:10 PM
    #300
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    That’s impressive, nice and flat torque curve. Is this @JustDSM tuned?:D
