Tacoma ProCharger
Discussion in 'Performance and Tuning' started by kiloromeo4, Nov 23, 2019.
  1. Jan 30, 2021 at 9:04 AM
    #361
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Did I read that correctly that the stock MAF sensor in a 3.5" housing is still maxing out? I picked up a 3.5 housing to fix that very issue
    Edit: with proper rescaling of course
  2. Jan 30, 2021 at 9:31 AM
    #362
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    Yes in my case, but I'm sure this is very particular to setup so YMMV. Where did you find a 3.5" housing? I ended up just making one due to fitment challenges with my setup but it didn't seem like there was a whole lot of them out there when I looked.
  3. Jan 30, 2021 at 11:32 AM
    #363
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Performance MRP, although after pulling mine back out and measuring it's only 3.25" ID but they have a 3.75"ID. Looks like they've updated the descriptions because when I bought mine, they only listed them as 3.5" or 4" with no indication if that was ID or OD.
    https://performancemrp.com/i-304976...th-air-straightener.html?ref=category:1389188
    Hawk373 likes this.
  4. Feb 8, 2021 at 5:59 PM
    #364
    VooDoo808
    VooDoo808 Well-Known Member
    Marc
    Hawaii
    2019 Voodoo Blue Tacoma TRD Pro
    With everyone jumping into the Magnuson supercharger for the 3rd gen, I’ve decided to pull the trigger on a Procharger kit for my 3rd gen. Should be seeing it around March.
  5. Feb 8, 2021 at 6:44 PM
    #365
    Smokehouse
    Smokehouse Procharged
    Zach
    Republic, Missouri
    2007 Super White Tacoma Sport
    Can't wait to see your kit!
  6. Feb 8, 2021 at 7:49 PM
    #366
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    This is Great! @SK808 is the first guy in hawaii with the Maggie. I think you'll be the first with Procharger. Eventually ill be TT... Would love to see the comparisons between the 3. Theres another guy on Kauai that has the Rotrex prototype but I think its in limbo for now.
    Very curious how the procharger will do with the 3rd gen. I almost changed my mind to pick one up but figured I waited this long, might as well wait longer.
    Biscuits, Smokehouse, SK808 and 3 others like this.
  7. Feb 26, 2021 at 7:16 AM
    #367
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Smokehouse likes this.
  8. Feb 28, 2021 at 1:05 PM
    #368
    Smokehouse
    Zach
    Republic, Missouri
    Unfortunately nothing as of late, I'm finishing my last semester of college before nursing school next year (hopefully) and I just got hired on as an EMT so I have been SLAMMED but I've got big ideas. I have actually been trying to find a shop around me that will do the Ratiotek kit but no one will touch it since its aftermarket. Lots of "oh we just replace whole transmissions" or "we don't do any custom work"
    Any suggestions??
    :annoyed:
    jamesepoop likes this.
  9. Feb 28, 2021 at 4:39 PM
    #369
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Send in the valve body to IPT... Ratiotek is only good for doing yourself.
  10. Feb 28, 2021 at 4:56 PM
    #370
    Smokehouse
    Zach
    Republic, Missouri
    I definitely want to do the IPT kit but for the time being would the ratiotek not be a good idea seeing as its only 30 dollars opposed to the 600 dollar IPT?
  11. Feb 28, 2021 at 6:23 PM
    #371
    RedLantern
    Honolulu, Hi
    Lord Helmet and Torspd like this.
  12. Mar 1, 2021 at 7:02 AM
    #372
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I must apologize. I was thinking of the Level 10 kit, as the Ratiotek kit. No knowledge on the Ratiotek kit.
  13. Mar 1, 2021 at 7:08 AM
    #373
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I have the ratiotek kit installed in my truck. With much reluctancy I got a mechanic at one of the local dealers to install it. (Keep in mind he is an absolute beast and also works on a top fuel sand drag rig which is why I trusted him). I think I ended up paying like $300 for it to be installed and thats including the price of new trans fluid to replace all the fluid that came out.
    I have been happy with the ratiotek kit, shifts are definitely a lot firmer and quicker. There is a write up on this forum on how to install it yourself here if you are up for it:
    https://www.tacomaworld.com/threads/ratiotek-transmission-upgrade-how-to.528378/#post-16878478
  14. Mar 1, 2021 at 1:59 PM
    #374
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    The full IPT valve body job should have more capability than just doing the Ratiotek. You could do either one just to find out it's still slipping because the TQ converter is roasted. (which is usually the case with a750)
    If you have power goals a fully built trans is the only logical option.
  15. Mar 1, 2021 at 2:53 PM
    #375
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This is true. I am only aware of two maybe three people to build their transmissions. @Lucario Runner , who did it himself with Raybestos clutch packs, and @loginfailed who had IPT build his.
    Kind of feel that there was another, but cannot remember where I saw it.
  16. Mar 1, 2021 at 4:13 PM
    #376
    Smokehouse
    Zach
    Republic, Missouri
    Does anyone make an upgraded torque converter for these trucks that you know of?
  17. Mar 1, 2021 at 4:20 PM
    #377
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
  18. Mar 1, 2021 at 4:26 PM
    #378
    Smokehouse
    Zach
    Republic, Missouri
  19. Mar 1, 2021 at 4:27 PM
    #379
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
  20. Mar 1, 2021 at 9:23 PM
    #380
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
