Tacoma ProCharger
Discussion in 'Performance and Tuning' started by kiloromeo4, Nov 23, 2019.
  1. May 14, 2020 at 1:48 PM
    lemons6245
    lemons6245 Well-Known Member
    2012 Tacoma Prerunner 4x2
    LSK race long travel, King 2.5x10 coilovers, 2.5x10 bypasses and 2.0 bumps. 2.5 Tundra fox rear DSC shocks, Icon RXT pack, Icon bump stops. 4.88 w/ TruTrac. AFE Y Pipe, URD cat-back. CSF radiator, OVT 91 tune, Ripp coil packs.
  2. May 14, 2020 at 3:35 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Someone needs to hop on that!
    Biscuits likes this.
  3. May 14, 2020 at 8:04 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I'll tune the first person to get one for free! :D
  4. May 14, 2020 at 8:08 PM
    JustDSM
    Justin
    Ogden, UT
    I'm currently tuning one in FL. GT3584 w/ a .96AR turbine housing. We've just about got the MAF calibration dialed and will be converting to E85 here shortly.
  5. May 14, 2020 at 8:33 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    6k and not CARB’d. Dang
  6. May 14, 2020 at 8:47 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I'm glad he reached out. One more to get a tune of your advanced skills.
  7. May 15, 2020 at 10:29 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
  8. May 15, 2020 at 2:45 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I would check-in on ProCharger's website every now and then to see which models of Tacomas were included. I'm a bit surprised they decided to pursue another FI option for us 2nd Gen's being we already have an option and the 3rd Gen's would seem to benefit more. I'm glad to see this option though and always wanted to see a centrifugal type available for the 2.5 gens. I wanna hear how it sounds and see how it performs!
  9. May 15, 2020 at 3:13 PM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    i would love to see a supercharger option for the third gen. I do agree with @MESO , if they are gonna charge that, it better be carb legal.
    MESO likes this.
  10. May 16, 2020 at 1:21 PM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
  11. May 16, 2020 at 1:36 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    12TRDTacoma and Biscuits[QUOTED] like this.
  12. May 16, 2020 at 1:45 PM
    Biscuits
    Exactly!
    BassAckwards likes this.
  13. May 16, 2020 at 6:54 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    i think the fuel pump booster theyre using is pretty interesting. Curious how it does that black magic to support all that hp with the stock pump
  14. May 16, 2020 at 7:08 PM
    Biscuits
    I don't know why they wouldn't just replace the stock pump with an aftermarket pump, unless they were trying to keep costs down or they had already partnered with whoever makes that booster module.
    BassAckwards[QUOTED] likes this.
  15. May 16, 2020 at 8:02 PM
    #35
    BassAckwards
    Yeah im not sure why either. Seems like the aftermarket pump would be a better option, like you said, it probably came down to cost
    JustDSM likes this.
  16. May 17, 2020 at 7:42 AM
    #36
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    If you can get better/cleaner power to the fuel pump, it will run higher and flow more. It's like turning your amp up to 11 ;). This has been done for years of FI setups where the stock fuel pump is close enough to meet the demand. A new higher flowing pump seems like a safer solution though if you don't mind doing the work to install it.
    12TRDTacoma and BassAckwards like this.
  17. May 17, 2020 at 11:30 AM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    At 390 HP, the OEM pump is no where near adequate. Even at 16 volts(hypothetical), it is beyond the ragged edge.
    It is not barely adequate for the TRD with a pulley upgrade.
    More than one way to solve a problem. The pump upgrade is the safest and best method.
  18. May 17, 2020 at 1:58 PM
    #38
    Smokehouse
    Smokehouse Procharged
    Zach
    Republic, Missouri
    2007 Super White Tacoma Sport
    What pump would you recommend?
  19. May 17, 2020 at 4:52 PM
    #39
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Walbro 340?
  20. May 17, 2020 at 5:17 PM
    #40
    12TRDTacoma
    Rob
    Concordia
    Boosted
