Tacoma ProCharger
Discussion in 'Performance and Tuning' started by kiloromeo4, Nov 23, 2019.
  1. May 17, 2020 at 8:41 PM
    #41
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Check through the selection on www.urdusa.com
    I recommend something E85 rated. It will resist the effects of ethanol in most fuels. That is just me though.
    Sterling_vH111 likes this.
  2. May 19, 2020 at 5:16 PM
    #42
    Smokehouse
    Smokehouse Procharged
    Zach
    Republic, Missouri
    2007 Super White Tacoma Sport
    In an ideal world I'd love to go e85 but i frequent places enough that don't have e85 so it wouldn't be practical for me
  3. May 19, 2020 at 6:12 PM
    #43
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Oh no. Don't be mistaken, by the way I worded that. It's that the pump is more robust to handle the ethanol as well. As most fuels have ~10% ethanol in them.
  4. May 20, 2020 at 8:42 AM
    #44
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Looking at the pictures on Prochargers website, this type seems like a simpler install than a Magnuson unit. I’d be stoked on a relatively easy bolt on kit without having to mess with timing, electronics, or get into the top end of the engine.
    Also I’d question the transmission, if Hp is up close to 400, wouldn’t the trans need beefing up as well?
    I know of the valve body upgrade, anything else than can be done?
  5. May 20, 2020 at 9:09 AM
    #45
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I believe IPT sells a fully built trans. Also the fuel pump should be upgraded with that kit. The boost a pump setup may work short term but I think long term you will run into fueling issues.
    Another thing to consider since you are in California is getting the vehicle smogged, this kit will not pass the visual inspection.
    Overall it looks like a badass setup though. I wonder who is going to be the first to install one.
  6. May 20, 2020 at 2:32 PM
    #46
    Smokehouse
    Zach
    Republic, Missouri
    how would i go about upgrading an automatic transmission? I know there are lots of options for the manual but if i went through with this id rather not blow my tranny up
  7. May 20, 2020 at 2:47 PM
    #47
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    :pccoffee:
    I imagine that IPT's trans upgrades are at least the valve body and torque converter. There could be other internal clutches and stuff that they upgrade too..
  8. May 20, 2020 at 2:49 PM
    #48
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    No. No. No. I just read in the 4-cylinder thread that superchargers are a waste of money. We should just sell our trucks and buy the V6.
    Everyone in this thread should just sell their truck and buy a Tundra. The resale value will be better. /s
    BassAckwards and TacoJova like this.
  9. May 20, 2020 at 2:53 PM
    #49
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    Sounds like a bad idea. :laugh:
  10. May 20, 2020 at 5:06 PM
    #50
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Lol.
    Anyway, to upgrade, the valve body can be upgraded by IPT.
    The whole transmission can be upgraded by them.
    Clutch packs from Raybestos can be upgraded and increase torque capacity.
  11. May 21, 2020 at 5:22 PM
    #51
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    everyone should just get a honda ridgeline.
    BassAckwards and jowybyo[QUOTED] like this.
  12. May 21, 2020 at 5:25 PM
    #52
    Lucario Runner
    Robert
    06 Toyota 4Runner
    honestly a simple valvebody upgrade, trans tune, and bigger trans cooler will be more than enough for most peps w/autos.
  13. May 21, 2020 at 5:26 PM
    #53
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Torspd[QUOTED] likes this.
  14. May 21, 2020 at 7:16 PM
    #54
    Smokehouse
    Zach
    Republic, Missouri
    Realistically my truck is 12/13 years old at this point and its got 140k miles. Obviously anything you do to the engine is hurting reliability but I am a little concerned about putting the thing on and then my truck blows up a year later. How much stress is a supercharger (and supercharger driving) going to put on a truck.
  15. May 27, 2020 at 4:16 PM
    #55
    Smokehouse
    Zach
    Republic, Missouri
    welp pulled the trigger and I am bringing it to procharger the week of 6/15
  16. May 27, 2020 at 5:02 PM
    #56
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  17. May 27, 2020 at 5:08 PM
    #57
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If you want to make an omelette you gotta break a few eggs right?
    Smokehouse[QUOTED] likes this.
  18. May 28, 2020 at 3:04 PM
    #58
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    Not enough popcorn in the world.
    I had previously inquired about this for my FJ and they said it's coming. Honestly i'm really tempted to just buy the Taco "tuner" kit rather than wait for them to roll out direct fit. Making a couple brackets for the intercooler, etc is no big deal. Already hooked up on the HPtuner too, I can't really think of anything else that would be an issue.. :curls:
    JustDSM and BassAckwards[QUOTED] like this.
  19. May 28, 2020 at 4:35 PM
    #59
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Tuner kit for you mate. Save yourself the time.
    BassAckwards likes this.
  20. Jun 2, 2020 at 4:52 PM
    #60
    Smokehouse
    Zach
    Republic, Missouri
    What gauges would be most important to purchase first? I plan on starting with just the A pillar so what two would be a good start and eventually ill buy the one that goes right in front of your instrument panel. If this is a stupid question humor me this will be my first boosted vehicle!
