Tacoma Rear Disc Brakes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HotZTrain, Apr 24, 2017.
  1. May 17, 2017 at 9:32 PM
    #181
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    Bleeding the system can take a little patience, but the system requires far less continual maintenance/tuning than cantilever brakes. You really only have to bleed them when you replace the pads. Cantilever brakes fall out of spec much easier (when impacted, cable stretch, pivot points become loose, etc).
    They are simpler because they are a hydraulic pressure system mounted on the hub/frame that don't rely on cable tension, pivot points, and wheel truing.
    I'm actually excited about boost hubs and the extra stiffness of spoke/wheels.
    archerm3[QUOTED] likes this.
  2. May 17, 2017 at 9:44 PM
    #182
    archerm3
    archerm3 Well-Known Member
    Nebraska
    97LX (sold) 15DCSB BRM MT OR(RIP) 09 Tahoe
    Brake controller, Snugtop, Hellwig981, Gentex, custom frame bending and body removal by red light runner.
    I had to chuckle at myself... In recollection, I'm always working on other peoples bikes and mostly on cheap stuff because the cheaper bikes always have crap going out of adjustment. If I could only get my kids to understand that they can't lay their bikes down on the deraileurs. On my own bikes of higher quality (deore xt/105/600 this dates me) I can't ever recall having to adjust any of the brakes other for when the pads got wore out.
    2016_dbag[QUOTED] likes this.
  3. May 18, 2017 at 3:16 AM
    #183
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    no, what I meant by "all factors are controlled for" was that they are brand new cars, so all the factors you listed off, meaning the wear on all the different parts, was minimal if there was any, so the only differences between them are design differences, not current wear or maintenance history related issues. It means that the differences in stopping distance and pedal feel are a result of the tuning of the brake system basically. Tuning refers here to the choice of rotor/caliper size front & back, master cylinder size, brake booster function as you pointed out etc. Now when it comes to the tuning of the brakes, ive been able to surmise through my apparently very brief and insignificant amount of seat time that even the Porsche Cayenne, weighing in at just over 6000 lbs or roughly 1500 more than a taco, still brakes significantly better and with much more consistent feel. As I stated before, all I wanted to do was learn a little more about brakes, and maybe improve my stopping distances a little. With my suspension tuning where it is I've been noticing more how the brakes are the biggest thing still holding my truck back and figured this might be the thread to find out more. Thanks for the tip about the brake booster, oh and sorry to hear about your truck by the way.
  4. May 18, 2017 at 3:47 AM
    #184
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    You guys argue about the stupidest shit.. . You want rear disc brakes, buy something other than a taco.
    End of thread.
    NJtaco421, greg8765, Robb_D and 2 others like this.
  5. May 23, 2017 at 7:57 PM
    #185
    greg8765
    greg8765 Well-Known Member
    Greg
    Utah
    2023 Tacoma TRD Off-Road
    Tuff Country Lift, Smart Cap, Tint, Pop & Lock, Door Sill Decals, Rooftop Tent
    really??? i was wondering the same thing when i got mine, but i guess it makes sense
  6. May 23, 2017 at 8:24 PM
    #186
    Garrett75x
    Garrett75x Well-Known Member
    Torrance
    2017 TRDOR 4x4 JBL P&T
    Pro Grille, Shmellfab rock sliders, Carhartt seat covers
    I was being highly sarcastic
    greg8765[QUOTED] likes this.
  7. May 23, 2017 at 8:32 PM
    #187
    greg8765
    Greg
    Utah
    apparently, i'm slow... good to know.
  8. May 23, 2017 at 8:33 PM
    #188
    Garrett75x
    Torrance
    I haven't had any stopping issues I'm sure you will be fine
  9. May 25, 2017 at 11:19 AM
    #189
    archerm3
    Nebraska
    Im having fun with this discussion so I will keep it going.
    When you say the Cayenne has better braking, as in significantly better, what does that mean? Consistent feel is just that, a feeling which is subjective and not exactly related to stopping distance or performance.
    So when you say better, does that mean it stops sooner? in less amount of distance? With or without ABS activation? Because if it does stop in less distance, I will submit to you that is entirely because of tire selection. To control for all factors would mean that you would put the exact same tire, of the same age, on your Taco, and do the same braking test at the same temperature on the same exact surface from the exact same speed (speedo's calibrated perfectly???) as you did the Cayenne. I'm guessing you didn't do this, I'm guessing that you didn't have the same tires on each vehicle.
    Now, if you "had" controlled for the tires between the cayenne and the taco, and you had a difference in stopping DISTANCE, then you can start analyzing the differences in terms of ABS activation, ABS cycling rate, WHEEL WEIGHT, TIRE WEIGHT, suspension dive/spring rate/dampening, and then control for those, before I would even begin to make a conclusion on disc brake versus drum brake on a rear axle.
    IF you are talking about brake fade, after multiple high speed applications of brakes, and controlled for that ONLY AFTER the above were controlled for, then maybe you might get somewhere with finding out if drums are limiting your abilities in a racing scenario.
    If you want to improve your stopping distance, the first place you should look is your tires.
    If you can lock your brakes, and get the ABS to come on, then your brakes are working, and they won't work any harder than that.
    If you are having issues with the rears locking up and can't get the fronts to lock up, then you have a brake bias problem, and maybe need more stopping power in the front, definitely not the rear.
    Now, if you are having problems getting your brakes to even lock up at all, then only at that point should you be looking at brake piston size/disc size/ drum vs disc/ brake bias adjustments.
    gpb likes this.
  10. May 25, 2017 at 11:23 AM
    #190
    Sand_taco
    Sand_taco Well-Known Member
    2016 quicksand Trd off road
    A Cayman does not weigh 6,000 lbs
  11. May 25, 2017 at 11:25 AM
    #191
    stevotivo12
    Stephen
    I did, my taco is riding on Michelin premier ltxs on 20s as well.
    I said CAYENNE not CAYMAN. A Cayenne s weighs 6,005 lbs as delivered
  12. May 25, 2017 at 11:25 AM
    #192
    Sand_taco
    He probably means pedal feel, overall performance under high operating temps, initial bite from the pads, and how they feel the more you push down on the pedal
  13. May 25, 2017 at 11:26 AM
    #193
    Sand_taco
    :rofl:my bad, i was like dude your crazy!
  14. May 25, 2017 at 11:28 AM
    #194
    archerm3
    Nebraska
    Ok now we are getting somewhere. What are the stopping distances between the two vehicles?
    I'm guessing that the cayenne is much more tightly sprung so it doesn't throw it's weight on the fronts near as much as the Taco does. You're tuning your truck for offroad racing to, what has that done to your spring rates and nose dive characteristics.
    Im guessing your taco is going into abs activation in the rear and the fronts aren't at that point yet. Press harder on the brake pedal.
  15. May 25, 2017 at 11:42 AM
    #195
    stevotivo12
    Stephen
    Suspension tuning should be just about on point on the taco. Riding on fox 2.5 coilovers with dsc's and 2.5" shocks with dsc's in the rear. No appreciable nose dive or roll through corners present during normal driving and I really can't womp on the brakes hard enough to get them to lock up and that's essentially where I know they have more to give with this tire setup. One thing that just occurred to me is for running the Baja I'll likely be rocking some different tires which means both suspension and brake tuning will need a do-over at that point. I've been looking into the brake booster and it looks like the electric brake booster from the TRD Off-road would be the sort of upgrade I am looking for, I see now what you meant about how a diaphragm based brake booster is naturally going to let off the pressure while you're sitting there but to me this makes the brakes feel mushy and doesn't exactly give me a whole lot of confidence in their ability to withstand abuse, whether that's a legitimate gripe or not that's the feeling I get. Anyone know if that system would be as simple as a master cylinder and booster swap or if there would be a whole lot more that would go into it?
  16. May 25, 2017 at 11:48 AM
    #196
    Sand_taco
    Have you though about upgrading the pads and fluid?
  17. May 25, 2017 at 12:25 PM
    #197
    stevotivo12
    Stephen
    Pads are in the next mod group I'm going to try so I'll know more about that soon enough. Im trying some EBC greenstuff 'supreme' truck compound pads, cryo treated rotors, and installing the new and improved all pro sway bar end links which now supposedly won't come undone and murder CV axle boots. What fluid would be considered an upgrade, dot 4?
  18. May 25, 2017 at 12:58 PM
    #198
    Sand_taco
    ate type 200 would be a good way to go
  19. May 29, 2017 at 7:20 PM
    #199
    jsinher3
    jsinher3 Well-Known Member
    boston
    10 tacoma sport TRD
  20. Dec 2, 2018 at 10:14 AM
    #200
    tpauly86
    tpauly86 New Member
    Pauly
    2012 DCLB SR5
    None
    If mikes reasoning is they perform better for off roading then make all 4 wheels drums. how come the wrangler has discs ? Ohh wait I know I know !!!! It’s because they are saving money on building the truck that way. Toyota thinks everyone is an idiot
