Tacoma Rear Disc Brakes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HotZTrain, Apr 24, 2017.
  1. Apr 25, 2017 at 8:33 AM
    #41
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    :bowdown: This guy knows how brakes work....
  2. Apr 25, 2017 at 8:42 AM
    #42
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    They're "lower maintenance" because they go out of adjustment and you end up relying on the fronts for the vast majority of braking.
    That's why there are late 90s tacomas with 200k+ that have never touched the rear brakes. That's because they don't work.
    "Low maintenance". . . .
  3. Apr 25, 2017 at 8:57 AM
    #43
    GPsevinSixx
    Ros Angerus
    All our trucks have modern self adjustment levers that adjust the toothed wheel bolt. We're not in the 50's anymore, those drums required adjustment back then.
    Krucen 01, archerm3 and The hammer like this.
  4. Apr 25, 2017 at 9:12 AM
    #44
    duckytw
    duckytw Well-Known Member
    Toyota can cite all the reasons they want us to think they didnt put disks in the rear but the only one thats actually true is:
    They were lazy and cheap.
    They had a disk/drum setup from the older tacoma. They have a disk/disk setup from the 4runner/FJ which share the same general platform as the tacoma. They had 10 years to develop the new tacoma and could have picked either setup to go with...
    they took the path of least resistance and for the so-called all new truck, they cheaped out and did not spend one iota of brain power to use the disk/disk setup that is literally staring them in the face and superior in every way over the disk/drum. Even if only 20% of the brake power is in the rear, I would still hope that they would put in 100% effort into that 20% than not. Its nearly a 40K truck fully optioned, it can be used for towing more so than a corolla, yet the latter gets disk brakes (option, but at least its available).
    TacoRan and Low Range Off-Road like this.
  5. Apr 25, 2017 at 10:21 AM
    #45
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    jsinnard likes this.
  6. Apr 25, 2017 at 10:35 AM
    #46
    i_cappi
    i_cappi Well Known Membhair
    Canton, Oh
    2011 TX TuRD Pyrite DCSB
    No. 5 minutes of research would have told you most of your comment is made-up.
    JasonCz, Krucen 01, archerm3 and 3 others like this.
  7. Apr 25, 2017 at 10:47 AM
    #47
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Totally agree. If your going to do anything to your tacoma, it will be the front. I am plenty happy with the drums and power booster (i believe thats what they called it) on the rear.
    Krucen 01 likes this.
  8. Apr 25, 2017 at 11:04 AM
    #48
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    When I went from a disc front/rear drum Tundra to a "new and improved" front/rear all disc brakes Tundra, the all wheel disc brakes felt mushy and less firm than on the old disc/drum Tundra, and there was no improvement on stopping either.
    When I drive my LTD T4R all wheel disc brakes, I miss the solid brake feel of my '16 taco...Just thought I'd mention it
    Cheers!
  9. Apr 25, 2017 at 11:14 AM
    #49
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    *you're
    And yes. I have a '15 4Runner TE. The shorter wheelbase and better weight distribution make it much better to me on the trails. I'm sure.
    TireFire and (none) like this.
  10. Apr 25, 2017 at 12:44 PM
    #50
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    Apparently every other truck manufacture except Toyota sees the benefit.
    Joe D[QUOTED] and smitty99 like this.
  11. Apr 25, 2017 at 1:01 PM
    #51
    (none)
    (none) Well-Known Member
    Travis
    The anti-tacoma, aka 4runner
    You all are asking the wrong questions.
    Yep, Toyota screwed you with the archaic and ancient drum brakes. Even the Corolla has rear disks now! There is a reason semi trucks are slowly moving away from drums as well. In fact, I'm genuinely surprised it is cheaper to build and install drum brakes when most everything else around has disk brakes.
    That being said, why aren't you asking why Tacomas have smaller FRONT brakes than the comparable 4Runner? And not just a 1/4" smaller, over 2.5" smaller. 4runner front brakes are 25% larger diameter than Tacoma rotors. Sure, you get to run 16" wheels, but that doesn't get you much when 17s already have a much larger tire selection... A Tacoma (properly equipped) is rated to tow more than a 4runner, yet has smaller front brakes and drums in the rear. Well done.
    Data from Toyota:
    https://www.google.com/url?sa=t&rct...jcD0_gRH5aCbbDf3g&sig2=m3D23wK5gVDDxtj6ThpdXQ
    https://www.google.com/url?sa=t&rct...-9RqRE1bVRFMjJn0Q&sig2=fjGcPXLxIFvuARx1KO_S8g
    TacoRan, Joe D and smitty99 like this.
  12. Apr 25, 2017 at 1:03 PM
    #52
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    :popcorn:
  13. Apr 25, 2017 at 1:05 PM
    #53
    GPsevinSixx
    Ros Angerus
    Aww Fuc.... I should've bought a 4Runner....
    Gonna call my salesman about a T4R...
    Spare Parts, opentang and PROseur like this.
  14. Apr 25, 2017 at 1:24 PM
    #54
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
  15. Apr 25, 2017 at 1:29 PM
    #55
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Toyota fucked up their data sheets. Your front rotors are not 10.75"... that's laughable, that's SMALLER than Miata sized, anyone with functioning eyes can look at them and see that they are not 10 inches.
    Someone @ corporate stuffed it and made a huge typo.
    They are actually 319 mm, which works out to 12.5" - so about 3/4" smaller vs the 4runner's 338 mm rotors.
    I can't seem to find any confirmation whether or not 4runners have 13WL's up front, in which case it's just a matter of a bracket and you've got your bigger front rotors.
    GPsevinSixx likes this.
  16. Apr 25, 2017 at 1:30 PM
    #56
    T4RFTMFW
    T4RFTMFW Well-Known Member
  17. Apr 25, 2017 at 1:39 PM
    #57
    Nitori
    Maricopa AZ
    2021 T4R SR5
    Just confirmed via T4R.org that 5th gen 4runners have a 14WA as opposed to our 13WLs. They have slightly larger pistons to match the slightly larger rotors.
    Also keep in mind that T4R's are much fatter than Tacos:
    Taco curb weight range:
    3,980 to 4,480 lbs
    T4R curb weight range:
    4,400 to 4,805 lbs
    JasonCz, The hammer and Joe D like this.
  18. Apr 25, 2017 at 1:43 PM
    #58
    Joe D
    Joe D .
    There's more than one side of the cost/benefit equation I didn't feel I needed to detail because I didn't want to appear as a hater...even tho it's just facts. (We kinda have a small UC Berkeley contingent on here it seems).
    First, (and maybe most obvious) are that disc brake dissipate heat more efficiently than drum and are more affective especially during heavy use. That's the user part of the benefit.
    Second, is that Toyotas build cost is lower while still being able to sell the truck, a manufacturer benefit. As another (bright) user has already noted, there's more to disc brakes than just changing from a drum to a disc....reservoir size/pressure etc.
    In the EU disc brakes on heavy trucks are already required. In the US while FMVSS has strengthened the standard and required shorter stopping distance of heavy trucks (in the past ~ 5 years) manufactures have increased the drum size to help with fade resistance and thus somewhat avoided the cost impact. As the requirement tightens, I believe we will see more air operated disc on heavy trucks.
  19. Apr 25, 2017 at 1:45 PM
    #59
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Effective
    Joe D likes this.
  20. Apr 25, 2017 at 1:50 PM
    #60
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    I want rear disc brakes on my truck with better fronts too.
