Tacoma Rust Issue expanded to 2004??
Discussion in '1st Gen. Tacomas (1995-2004)' started by des kaiser, Jul 8, 2008.
  1. Jul 8, 2008 at 5:04 PM
    des kaiser
    des kaiser [OP] Member
    Just got a cell phone message from my dealer about my 2001 Tacoma frame rust concerns. They said my VIN is most definatley included and the free rust inspections have been expanded up to the 2004 model year. Take it for what it's worth but I have it saved on my cell phone and the Toyota delaer sent it marked URGENT.
  2. Jul 8, 2008 at 5:19 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    IMO Toyota oughta give WHAT YOU PAID FOR THE TRUCK NEW!!! My understanding is they give you one&12 times the KBB?? Theyre gettin off EASY for putting frames w/LOWGRADE steel on these trucks What did they do make a deal with CHINA?? Imagine the cost of you and your family members' medical if your truck broke in half doin 70!!
  3. Jul 8, 2008 at 5:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Thats reall strange. It has to be a problem with the way they are applying the anti rust coating. I understand the frames are made in the USA by Dana corp. :confused:
  4. Jul 8, 2008 at 5:27 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Yeah but wher'd they get the steel is what I wonder! Remember the problems with rust-thru in the early 70/s on GM cars cuz they were made with inferior steel from china:eek:
  5. Jul 8, 2008 at 5:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmmmm....I think your right. Not sure where they get it from. It could be out sorced from anywhere. :(
  6. Jul 8, 2008 at 5:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It seems Dana uses Recycled steel. Still cant find the origine of it.
  7. Jul 8, 2008 at 9:03 PM
    pittim
    pittim mittip backwards
    Pittsburghish
    Oil burning fuel sipper
    Permanent CEL
    But the frames are rusting from the inside out. Do manufacturers rust coat the inside of the frame? I thought they only coated the outside.
  8. Jul 9, 2008 at 4:24 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I better look at my frame and check it out... I really hope I dont got frame rust. I new the older Tacomas had this problem, But it sucks that they now extended it to the 01-04 models. :(
  9. Jul 9, 2008 at 4:30 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    I saw mine and there's not a hint of rust to be found! I think this whole thing is a batch of bad steel that got into a certain group of frames-which is why Toyota is addressing this according t VIN numbers....which PISSES me off cuz they know EXACTLY which batch it is:(
  10. Jul 9, 2008 at 4:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im not sure how people figured that the frames are rusting fom "the inside out". The frames are coated with an Anti corosion coating. They generally start to rust where the coating is the thinnest, or not applied well. Useually near the edges. Depending on the environment and other variables, the rust will travel. The frames are coated inside and out. From what I have learned it seems that the faultiy frames are due to some crap steel (what Ridgerunner said) that Dana received. Im still awaiting a reply from an e-mail I sent to them about the rust issue, and where they get their steel from.
  11. Jul 9, 2008 at 4:53 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Thats COOL Chris:thumbsup: if they say china Ima gonna fall off the chair!! Thatd be the straw that breaks it in my mind!
  12. Jul 11, 2008 at 2:56 AM
    des kaiser
    Conflciting info from the dealer on frame inspection. See my other post on Rust concerns 2001 Tacoma.
    Unless your Tacoma has PERFORATION OF THE FRAME to the point that you can hit it with a hammer and frame crumbles, your truck is considered FINE. That's what the teenager at the dealer, excuse me "specially trained corrosion technician" told me.
  13. Jul 11, 2008 at 4:53 AM
    Cburt
    Cburt Well-Known Member
    Kansas City
    SR5 4x4, White
    None currently,
    I recently looked at my 06 and it has exterior frame rust. I thought about painting it myself, then thought better of it.
    Not happy with seeing rust on my Toyota with only 12,000 miles.
  14. Jul 11, 2008 at 6:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    lmfao!!!!!
  15. Jul 11, 2008 at 2:23 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the 04 i just got is rusted all to hell underneath, but its from where the previous jackass owner always offroaded it and never cleaned underneath the truck.:rolleyes:
  16. Jul 11, 2008 at 2:32 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2002 Tacoma Xcab
    sounds like my truck...some jackass always takes it in the dirt and never bothers to really clean it :eek:
    its hard to tell if mine is rust or caked on mud though...theyre about the same color i think
  17. Jul 11, 2008 at 2:48 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    pressure washer and water are our friend:D:D!!!
  18. Jul 11, 2008 at 7:39 PM
    JimBeam
    JB
    2002 Tacoma Xcab
    ive hit it with the pressure washer...its pretty much stained mud colored under there now
  19. Jul 11, 2008 at 7:42 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the shape mine is in......im gonna get some primer and black paint under there to keep it from getting too bad., plus mud and crap will wash off alot easier then.
  20. Jul 11, 2008 at 7:48 PM
    Johnny_knox69
    Johnny_knox69 Well-Known Member
    I am not 100% but I don't think that carbon steel is the problem. If you want corrosion resistance say from Salt you would probably want steel with Ni or some exotic metal in it....High grade stainless steel area.
    All carbon steel will rust in a Ny Min with salt on it.
    I would say like most the Jap cars, they trim the weight ect.. to a "T", one little slip on something like corrosion protection and your in trouble.
    So it must be something with the coating. Just my guess.....
