Tacoma Rust Prevention Experiment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TerribleTT, Jan 12, 2014.
  1. Jan 13, 2014 at 11:52 AM
    #41
    junkman
    junkman Well-Known Member
    Erik
    Louisville
    '13 SR5 4x4 5 speed Access Cab
    Even better, treat the driver side and don't treat the passenger side. Paint a stripe down the middle.
    That would be an interesting experiment.
  2. Jan 13, 2014 at 12:18 PM
    #42
    QUE BALL
    QUE BALL Active Member
    I WILL NEVER APPLY WD40 TO ANY PART OF MY TACOMA!!!!!!!!!!!! This stuff deteriorates rubber. All of you users that have applied WD40 to the rubber parts under the truck will gradually find out what I am talking about. Yea I bet it looks shinny and clean and is easy to apply but wait till the rubber componet gradually falls apart and see what you have then.:eek: To remove I would recommend repeated washing with a pressure washer car wash with soapy water.
    pass the word
    que ball
    igno1tus likes this.
  3. Jan 13, 2014 at 12:57 PM
    #43
    evan
    evan Well-Known Member
    SK, Canada
    Which WD40 product do you mean?
  4. Jan 13, 2014 at 4:59 PM
    #44
    DannyD
    DannyD Well-Known Member
    Dan
    BC Canada
    2021 DCLB
    Did my truck today took 3 cans o fluid film at 15$ each. I could have gone 4-5 cans if I had a lift and could easily see everywhere. But the majority of parts got soaked in it for shur.
  5. Jan 13, 2014 at 6:19 PM
    #45
    billinwoodland
    billinwoodland Well-Known Member
    Bill
    N. Cal
    Agreed. Or one side fluid film and the other this motorcycle oil. Still need a non-treated control though.
  6. Jan 15, 2014 at 10:57 AM
    #46
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    This. I just ordered a case from my local Amsoil dealer. Will treat both the truck and my Subaru when all the snow and salt is gone from the roads.
  7. Jan 15, 2014 at 1:32 PM
    #47
    kylenotjon
    kylenotjon Well-Known Member
    Give it a good hose down and let it thoroughly dry. What little dirt is left will stay under the coating plus the it'll be picking up dirt anyway when you drive it while the amsoil is wet.
  8. Jan 16, 2014 at 4:45 PM
    #48
    TerribleTT
    TerribleTT [OP] Member
    Thomas
    Buffalo NY
    2013 TRD Sport
    TRD Supercharger, TRD Pro Wheels, BFG KO2 tires, 3" Toytec Boss Pro lift, Boss Pro rear leaf springs - comp assembly, Cree LED light bars in front, Toyota TRD pro grill, TRD OEM running boards, TRD bed mat, under hood + bed LED lighting, tailgate lock, Dimple magnetic drain plugs - rear + front diffs, trans case, transmission, oil pan, truxedo bed cover, 12,000 pound warn winch (not in pics yet, and some TRD emblems so far.
    I agree, that would be a much better test. The only problem is I don't want rust on either of the trucks. Maybe I should of tried two different products. I've been reading a lot of good idea's. Thank you all for the feedback.....
  9. Jan 16, 2014 at 4:50 PM
    #49
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I've used both the Amsoil HDMP and fluid film. The fluid film lasts longer since it stays waxy. The metal protector wore off after about 9 months of snow, rain, and washing. I would choose fluid film.
  10. Jan 16, 2014 at 8:22 PM
    #50
    Marcoc
    Marcoc Well-Known Member
    Connecticut
    2017 Tacoma TRD Off-Road LB
    2017 Tacoma TRD OR LB white w/tech package
    I use the Amsoil metal protectant as well here in CT. Works great but not sure how often to apply it. My 2010 looks good underneath with the second winter since I have owned it in CT.
  11. Jan 17, 2014 at 8:08 AM
    #51
    Smashing
    Smashing Well-Known Member
    Rochesterish NY
    2017 DCLB Sport
    I just bought my 2010 and it has some areas starting to show rust. Most of it is just bolt heads and stuff and mostly in the engine bay. Will fluid film cut the rust and stop it from getting worse? I thought about getting a spot blaster to knock the rust off but not sure I want to do that in the engine bay.
  12. Jan 17, 2014 at 2:32 PM
    #52
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    Thanks OP for this. I just ordered 6 cans, I only wanted one for testing but after seeing some testing done think I might switch next year from Corrosion Free 3K to this. Will have to see how the tests work out.
    The F-150's have the same frame rust issue we have. And those with Raptors have spent up to twice what we have for our Tacomas. There is a 29 page thread on the Raptor forum about clear undercoating and a lot of testing, looks like the HDMP is the best from the tests that have been done there.
    Here is one of the pictures comparing FF and HDMP (and T-9) after exposure outside in Fl. after a couple of weeks in high heat and humidity.
    I have done similar testing but with fewer products than they used. The Canadian military did a lot of testing including some of those products and Corrosion Free 3000 came out at the top of the pack. They did not use HDMP or FF in testing. The picture above mirrors some of my limited testing with steel wool and brine solution (3 applications) so far over a months time comparing FF and CF3K.
    Control (which has reached destruction, it separated)
    Fluid Film ("hole" rusted and blew threw it)
    CF3K
    The thought on the other site is that FF doesn't adhere for long periods and washes off too easily. I have been rinsing the steel wool samples for 30 sec. each in tap water before applying brine solution to test exactly that, and it does appear that may be the case.
    Once the HDMP comes in I will start a separate thread and do some more testing to include it. Thanks again for the heads up on this.
    GQ7227 likes this.
  13. Jan 17, 2014 at 8:11 PM
    #53
    DannyD
    Dan
    BC Canada
    2021 DCLB
    where you guys pick up that amsoil HDMP Any big name stores carry it? website claims not available in canada. Luckily I'm near the border :)
  14. Jan 18, 2014 at 5:22 AM
    #54
    RTD
    RTD Well-Known Member
    Taxachusetts
    +1
  15. Jan 18, 2014 at 6:04 AM
    #55
    RTD
    Taxachusetts
    I was doing body work and painting cars back in the '80s
    I do remember we had a waxing rustproofing substance we used before installing some panels, fenders, and we used a simple spray gun, basically a can with a nozzle, to shoot this stuff.
    Sorry I don't remember any more details, as all that lacquer wiped out a good part of my brain that is used for memory.
    I know a guy that ran his truck a lot on the beach, and he would spray his waste oil all over the undercarriage.
    I am using some of the different marine based products.
    Try looking at your local auto body supply shop
  16. Jan 18, 2014 at 6:21 AM
    #56
    drewp
    drewp Well-Known Member
    south Jersey
    '14 Sport/DCLB
    I just used a product called "Blaster Corrosion Stop" purchased in 11 oz. spray cans. On the can mentions that it: "prevents corrosion from..salt and chemicals, creates protective barrier", etc. Can be used on "automotive frames, driveshaft bolts, exhaust head", etc. I was in touch with the QA guy from the company regarding any problems with rubber components. He informed me the product is safe on rubber, etc. The product didn't necessarily leave a "waxy" coating, but a slick, translucent white residue. I'm not sure how long it will hold up. We'll see. For you guys who have tried FF and Amsoil product, during spraying, inevitably some of the product is going to get on exhaust system, etc. What happens to this? Does it basically melt/burn off?
  17. Jan 18, 2014 at 6:37 AM
    #57
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    I sprayed Fluid Film this past fall and it will burn off the exhaust. It does give off a smell, the Fluid Film smell, but I didn't find it obnoxious. The smell goes away over time. I will be respraying in the spring.
  18. Jan 18, 2014 at 7:14 AM
    #58
    n1dp
    n1dp Member
    Maine
    Tacoma Access TRD Sport
    Had the Fluid Film applied at a local garage/dealer for $200 for the first time. No lift here so it was worth it to keep old bones off the concrete. They said come back next fall and they'll touch it up. Cheap insurance. If I had a lift, and a fleet of cars, I'd buy it in bulk.
    We used a fluid film like substance on aircraft in the Coast Guard; very waxy. Good stuff.
  19. Jan 18, 2014 at 7:31 AM
    #59
    1of7627
    1of7627 Well-Known Member
    Mark
    Post Falls, ID
    '14 DCLB Ltd, '63 Corvair Spyder
    Things I need to tow.
    Don't know if it was mentioned here, but I'm going to treat the inside of the tailgate too. I had the cover off to install a Pop-and-Lock and the inside of the tailgate is easy to reach and no doubt would benefit.
  20. Jan 18, 2014 at 7:47 AM
    #60
    Soft Taco
    Soft Taco Team Oil Drop
    Tyler
    Colorado Springs, CO
    2016 4WD Auto DCLB TRD Sport
    Definitely doing this soon.
