Tacoma Shock Relocation - Trail Series - 2.0 x 12 - 2nd/3rd gen
Discussion in 'Archive Garage' started by ARCHIVE, Feb 22, 2021.
  1. Sep 28, 2021 at 10:28 AM
    #261
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If you're working hard, semi-proficient at fabrication, and don't break down the leaf pack to cycle the suspension, it can be done in a day. About 8 solid hours of work. But it wouldn't hurt to plan on it taking two days in case any surprises pop up.
  2. Sep 28, 2021 at 10:44 AM
    #262
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I'm not done but working at a casual pace it is very comfortably a 2 day/weekend project with time to spare at the end. It took me about 4 hours to get the mounts off with just a sawzall, grinder, hammer, and chisel - would go WAY faster with a plasma cutter and/or air hammer.
    I also disassembled my leafs to cycle the suspension which probably took me about an hour once I got them off the truck to take apart and make spacers. Then some time to put them back on, to inevitably come off again, get put back together, and go back on again.
    Supr4Lo[QUOTED] and ARCHIVE[OP] like this.
  3. Sep 28, 2021 at 11:10 AM
    #263
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    I kind of figured it would be a 2 day job but just wanted to confirm.
    @ARCHIVE I have your U-Bolt flip with yellow bump stops. Is there a compressed measurement for the the bump stop to figure out the max up travel? I'm not sure if I'm going to separate the leaf pack to cycle the suspension.
  4. Sep 28, 2021 at 11:12 AM
    #264
    plurpimpin
    PDX
    I'm using the same bumps and going of his advice in this post from the flip kit thread:
    https://www.tacomaworld.com/threads...en-archive-garage.572629/page-5#post-25960416
    Sounds like the bumps compress 1.75"
  5. Sep 28, 2021 at 11:16 AM
    #265
    Supr4Lo
    Surprise, AZ
  6. Oct 4, 2021 at 2:31 PM
    #266
    plurpimpin
    PDX
    So I got my shock relocation done last week and am really happy with how it turned out.
    A few things I noticed during the install that may help others:
    Before putting it up on jack stands I parked my truck on level ground and played around with my digital angle finder. I found that on my truck (this will vary depending on your setup) the bottom of my frame rail was less than 0.5° off horizontal directly behind my bump stop perch (179.7°) so I used that as a reference to zero out my angle finder when setting the forward lean on the shock to 10°. You could do this with any fixed point on the truck if you play around and find a spot that's close to level to use as a reference.
    Also I initially tacked my upper mounts on with the shock centered in the mounts angled 10° forward at full droop (equal gaps between the shock body and tower on each side). When cycling the suspension this resulted in the shock body coming VERY close (~1/16" gap) to the shock tower when my bumps were just touching the frame. I'm sure they would have hit at full bump. As you compress the suspension the shock body moves rearward in the mount.
    To correct this issue I ground off my mounts and repositioned them with the shock still at a 10° but I biased the shock body forward in the mount at full droop. I found that the perfect position was with the shock body parallel to the forward edge of the tower with an equal gap at the top and bottom between the front edge of the tower and shock body. This worked out perfect and everything on the mount aligned much better with the shape of the frame rail. From how much better everything lined up I'd wager this is how Archive designed the shocks to sit in the tower. This setup allowed plenty of clearance between the shock body and tower at full bump.
    Lastly it was extra work but I'm really glad that I disassembled my leaf pack and cycled the suspension during my install. In my opinion this is the best way to be 100% sure that everything is in the right spot and you're maximizing your use of the shock. Without cycling the suspension I feel like I would have been guesstimating on my lower mount locations. By cycling the suspension I was able to get everything within 0.5° and 0.1" of where I wanted it which made my OCD happy hahaha.
    I also made what I'm calling my OEM+ shackles by drilling and tapping some new bare OEM Toyota shackles for M6x1.0 grease zerks and installing a set of poly bushings from Archive.
    +6” brake lines from crown performance were perfect. This pic shows the extended line next to OEM which was as tight as a guitar string at full droop.
    Sorry for the long post but I hope the info helps other folks out with their installs.
  7. Oct 4, 2021 at 4:43 PM
    #267
    Vegasstunts
    Vegasstunts Well-Known Member
    16 TRD sport
    All of them.
    I need to do the poly bushings. But building guns is more of a priority at the moment
  8. Oct 21, 2021 at 6:26 PM
    #268
    plurpimpin
    PDX
    Got out on some trails last weekend and finally got to test the relocation out. The extra articulation in the rear was great and made a lot of obstacles a lot easier. The ride was way better off-road. On road I noticed a slight difference but trails are where this setup really shines.
    I was also able to droop it out to where I had the bumps on the frame on one side and the wheel off the ground on the opposite side and was still able to fit my fingers between my tire and the shock body with no wheel spacers. I’m running 285/70r17 Duratracs on 17”x8.5” 4.30" backspace -10mm offset rims. Super stoaked to not need spacers!
    28D2F72A-6CE0-4CEC-8D70-DF7758EB3D98.jpg 47990725-652F-46E6-8973-73AEB009DA91.jpg 6A083E44-9481-430D-84E9-61419FD0C3BB.jpg
    CemenTRDgen, GHammer, wi_taco and 4 others like this.
  9. Oct 21, 2021 at 6:32 PM
    #269
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Thanks for posting results. Good to hear you didn't need spacers
  10. Oct 22, 2021 at 3:51 PM
    #270
    Abject4x4
    Abject4x4 Just another idiot on the internet
    Marcus
    White SR5 Access Cab
    So 255/80/r17 on 0 offset wheels should also fit without spacers, I guess.
  11. Oct 25, 2021 at 12:52 PM
    #271
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Are you guys depressurizing the shocks to make it easier?
  12. Oct 25, 2021 at 4:51 PM
    #272
    IvanhoeTaco
    Eastern NC
    Is there a way you can get your measurements and placement near perfect without breaking down the leaf packs?
  13. Oct 25, 2021 at 11:35 PM
    #273
    plurpimpin
    PDX
    nope. Leaf springs are way harder to compress than shocks
    Abject4x4 likes this.
  14. Oct 26, 2021 at 2:23 PM
    #274
    ARCHIVE
    Eric
    Yes, its virtually a 1:1 relationship, but you have to account for articulation since shock is outboard of the springs.
    if you have 5 inch of possible bump travel with axle horizontal, you should have 6" of shock uptravel left.
    If you get axle articulated, then whatever bump height you have left should equal the shock uptravel you have left.
    Pretty easy, like math haha :thumbsup:
    IvanhoeTaco[QUOTED] likes this.
  15. Oct 26, 2021 at 2:41 PM
    #275
    IvanhoeTaco
    Eastern NC
    But the only way to find how much up or down travel I have in the shock when its placed is probably easiest with the shock de-pressurized and leafs torn down? Other wise wouldnt I have to just guess where my axle tab is supposed to go, tack it, bolt shock to it and then use my other measurements to see where my tower needs to go? Im sure its probably very simple for someone who has done it, im just trying to get some good input from the experts.
  16. Oct 26, 2021 at 2:51 PM
    #276
    ARCHIVE
    Eric
    The shock is the shock, no magic. You always set the axle tabs off of max axle bump height. What springs?
  17. Oct 26, 2021 at 2:56 PM
    #277
    IvanhoeTaco
    Eastern NC
    Dakars
  18. Oct 27, 2021 at 6:06 AM
    #278
    IvanhoeTaco
    Eastern NC
    This may have already been covered but is axle wrap going to be an issue mounting both shocks on the front of the axle?
  19. Oct 27, 2021 at 12:28 PM
    #279
    ARCHIVE
    Eric
    No, in fact both shocks in front of axle would reduce power-on axle wrap
    MY50cal and IvanhoeTaco[QUOTED] like this.
  20. Nov 8, 2021 at 8:30 AM
    #280
    urmaker45
    urmaker45 Well-Known Member
    Brad
    Wise, va
    2017 tacoma trd offroad
    are they any instructions on these ? My install shop is good with fab just trying to determine where to put shock relocation bracket and tabs . I’m going king 2.0 with icon rxt stage 1
    @ARCHIVE
